I have a couple of Kwikset HomeConnect 620 locks that I am connecting (new) to a hub. I was able to get the first device connected with no issues, however, when connecting to the second lock I ran into a problem. During the initialization process the device appeared to connect and gave me the prompt to continue with or without security, during this time period I got distracted and the whole process eventually timed out with the inclusion process ultimately failing.
Initially I tried a zwave exclusion and then eventually went to a factory reset on the lock itself (which I had done before starting the entire process so this was the second factory reset), all to no avail. At this point, when I begin the inclusion process it says that it has located a zwave device, but then never goes beyond that point. I went through several rounds of doing a general exclusion and finally factory resets, but never had any success getting beyond the device location process.
After doing some digging on my zwave network I see a phantom node that is labeled as a "specific_type_door_lock" but it is not an active device and under the column where it gives the name of all my devices, this one has a "discover" button. Under the status section it reads as "Ok" and gives me the "repair" and "refresh" button options.
I believe it is this unassigned/unnamed device that it causing issues with adding the new lock, but I cannot figure out how to get rid of it. I figure there is something simple that I am missing, but I cannot for the life of me guess what. I have tried a reboot and a reboot/power down of the hub itself, but cannot get the device removed from the list. I also updated my firmware (post encountering this issue).
It appears to me that the hub is recognizing this as a connected and legitimate device, but it clearly is not. How do I get this "device" removed?
