@bcopeland
Whenever I want to assist you in a debug/trace issue for a specific device it is always hard to trap the exact instance something is needed for capture; there is so much ZW chaff.
Can we get a filter for the device ID on the ZW Logs screen?
I am testing to see if the iBlinds driver is fixed on 2.4.4.135 or still requires some poking and prodding.
Paste the whole thing into AI and ask it to filter it to a specific device ID. You can also ask it to analyze the logs and tell you what is going on. AI is well trained on Zwave JS logging.
You know what would be cool is if Hubitat had built in support to send logs (regular and zwave) to a logging server. I have a driver that connects to the local websocket and sends the logs to a server but it is sort of a hack.
All it takes is a simple bash script tbh
Don't make me go back 25 years and learn it again. ![]()
It was fine when I used to play with Linux.
All the knowledge turned into Scotch when I retired.
