I am trying to update the firmware of my Zooz ZSE44LR temperature sensor. Unfortunately, it does not show up in the list of devices to choose for updating.
I downloaded the ".gbl" files from zooz, uploaded it to the hub and tried the following:
Disabling the device,
Tapping the button 4 times
Removing and reinstalling the firmware updater app.
Shutting down the hub and powering it off for 30-seconds, remove battery from the ZSE44LR for 30-seconds, powering everything up and trying again.
Nothing seems to work -- it never shows up in the list of devices that have an available update.
@neonturbo and @bertabcd1234, thank you for responding so quickly! Here is the additional information you requested that I should have included in my original post:
The device is joined to the hub in LR mode.
I am using the built in device firmware updater app.
My hub is a C8-PRO, platform version 2.4.3.149
I am using the legacy z-wave stack, not ZWaveJS, as the latter destabilized my z-wave network.
A quick update that I worked around the problems by excluding the device and then including it as a non-LR device. It showed up immediately in the list of targets.
Adding @support-agent to the thread is this appears to be a bug...
My recent experience with some ZSE41s is that you can't be shy with the 4-press wakeup. LR firmware updates went smooth for me on the 6 I did it on.
edit: I missed that this was on ZIP, not ZWJS, sorry.
