Needing some help here all my contact sensors have some reason quit reporting I've tried with unplugging the hub, manually waking the sensors up as well I'm using the custom driver for the sensor as well and even with the manual update still not updating status
What does your Z-wave mesh look like? It sounds like you might have weak mesh, ghosts, or other Z-wave issues.
Post a screenshot showing all columns and rows of your Z-wave table. You might have better luck doing so on a desktop rather than the phone. The last column is important, the phone often chops off this in screenshots.
I'll have to grab one from a laptop later. Mesh is good I have a repeater 2ft from the hub and then every zse41 has a repeater next to it as well it's been working perfectly for the last month
