Zooz32 Light control
Hi all,
Lets see if I can get help please.
I want to integrate my kitchen lights that I have with 2 meross 2 way switches (one each end) with a zooz32 i just bought and its located in the living room, I want to control 5 lights which I've accomplish 4 of them already because those lights I have aquara switches. All I need now is control the meross switches but I am lost there because i don’t see any integration with our beloved Hubitat Hub.
Any advice? Lutron switch maybe? any solution?
Thanks in advance
What is the exact model number? Naturally, you need to get the device added to Hubitat to be able to control it from the hub (whether by some automation or manually). And unfortunately, not every device is compatible with every hub just because the device says it's "smart," and many manufacutrers, including Meross, make a variety of different models, so this is key information -- some manufacturers only let you work within their own walled garden, directly integrated cloud services only, or other things, whether with their entire line or just specific models.
It's a bit late if you already have the device, but sticking to known compatible devices is usually easiest, though Hubitat can work with most Zigbee (ZHA 1.2 or Zigbee 3.0), Z-Wave, or Matter devices regardless, plus some other protocols if there's a documented, preferably local API or it happens to have been reverse-engineered. But hopefully whatever you have can work, then it's just a matter of figuring out the automation!
To expand on what @bertabcd1234 wrote:
Meross does make Apple Homekit compatible switches/dimmers. These can be paired with a Hubitat C-8 Pro hub, but not earlier versions.
Meross also makes Matter compatible switches. These can be paired with any Hubitat hub.
Finally, Meross makes switches that use Meross' cloud. Hubitat doesn't have built-in support for these switches, although there may be a community integration.
I don’t use apple. All I need is a 2 way switxh that I can control with alexa thru hubitat element.
What i u buy a Luton switxh and a Lutron wireless switch i can put on the other side of the wall?
