Need a little advice.
I have some six wire Led strips. Will this work to change worm white colors? I only see four color connections.
If not, what would you recommend? Im trying to stay on the zwave side.
Thanks.
Zooz Z-Wave Plus S2 12/24 V DC RGBW Dimmer ZEN31 for LED Strips and DC Lighting, Work as a Network Repeater (Z-Wave Hub Required) https://a.co/d/g3tVonY
Yes that can work also, I considered suggesting it but it makes things more complicated to control. You basically have to manually set the channels with RM at that point.
