Custom Driver [Zooz ZSE44 Temperature Humidity XS Sensor]
periodically generates next error message:
Well that is very odd, that line is just a debug logging line, right before that is a check for a null value in one of the variables and even if the values were null it should still work.
How often are you getting this?
This happened only few times during past couple weeks on C8 hub.
Frankly before upgrading to C8 I didn't check logs because C7 was running very well.
So, I have no idea if these errors ever showed on C7.
Unfortunately C8 is not happy with many different things. That is why I started to monitor logs and observed these errors few times.
