Zooz Zen25 - clicking sound/turning off-on
Hello - I have two Zen25 double plugs from 2020 and one of them has recently started making a clicking sound and turning the connected devices off and on again at random intervals (within less than a second). I don’t see anything in the logs except the original “on” event. The other plug is working just fine, so I suspect that this plug is on its way out.
Has anyone run into this? And is the plug going bad or could it be something else?
Thanks for your help.
I've now got the same problem with mine.
Did you ever solve it?
Unfortunately not. I reached out to Zooz support and they said it had most likely gone bad. I switched to the Enbrighten Zigbee dual outlet
Enbrighten Zigbee Switch, Dual Outlet Control Plug-In, Pairs Directly with Echo 4th Gen/Echo Show 10 (All)/Echo Studio/Echo Plus (All)/Eero Pro 6, White, 43094 https://a.co/d/4EyZliE
