I am having a very tough time with these toggle switches and dimmers. I am getting a ton of repeated commands/traffic in the logs. Have excluded/included did the shutdown pull power trick, paired unsecured and still having issues. The devices pair but after a few toggles either manually or via the device page tons of messages start to appear in the logs and the responses get very delayed. Tried changing to generic drivers still an issue. The dimmer had even more issues - I could not get it to respond unless I clicked "refresh".. tried excluding/including and still had issues.
I have some paired already and they work fine (but slow) for the most part. I wonder if there is some sort of limit... have about 42 Z-wave+ devices.
Here's a recent log dump of device "86"
sys:12020-10-22 12:05:12.920 pm warnZ-Wave Network responded with Busy message.
dev:10052020-10-22 12:04:49.443 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:1, sequenceNumber:7, slowRefresh:true)
dev:10052020-10-22 12:04:49.439 pm debugparse description: zw device: 86, command: 5B03, payload: 07 84 01 , isMulticast: false
dev:10052020-10-22 12:04:48.868 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:04:48.858 pm infoBasicReport value: 0
dev:10052020-10-22 12:04:48.855 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:04:48.092 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:04:48.084 pm infoBasicReport value: 0
dev:10052020-10-22 12:04:48.081 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:04:46.694 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:04:46.687 pm infoBasicReport value: 0
dev:10052020-10-22 12:04:46.684 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:04:45.473 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:04:45.466 pm infoBasicReport value: 0
dev:10052020-10-22 12:04:45.463 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:04:45.409 pm infoFront Porch Side Light Switch 2 was turned off [digital]
dev:10052020-10-22 12:04:45.405 pm infoBasicReport value: 0
dev:10052020-10-22 12:04:45.402 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:04:43.413 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:2, sequenceNumber:6, slowRefresh:true)
dev:10052020-10-22 12:04:43.409 pm debugparse description: zw device: 86, command: 5B03, payload: 06 84 02 , isMulticast: false
dev:10052020-10-22 12:04:42.840 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:2, sequenceNumber:6, slowRefresh:true)
dev:10052020-10-22 12:04:42.836 pm debugparse description: zw device: 86, command: 5B03, payload: 06 84 02 , isMulticast: false
dev:10052020-10-22 12:04:25.151 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:1, sequenceNumber:5, slowRefresh:true)
dev:10052020-10-22 12:04:25.148 pm debugparse description: zw device: 86, command: 5B03, payload: 05 84 01 , isMulticast: false
dev:10052020-10-22 12:04:24.520 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:1, sequenceNumber:5, slowRefresh:true)
dev:10052020-10-22 12:04:24.517 pm debugparse description: zw device: 86, command: 5B03, payload: 05 84 01 , isMulticast: false
dev:10052020-10-22 12:04:24.043 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:1, sequenceNumber:5, slowRefresh:true)
dev:10052020-10-22 12:04:24.039 pm debugparse description: zw device: 86, command: 5B03, payload: 05 84 01 , isMulticast: false
dev:10052020-10-22 12:04:23.198 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:1, sequenceNumber:5, slowRefresh:true)
dev:10052020-10-22 12:04:23.195 pm debugparse description: zw device: 86, command: 5B03, payload: 05 84 01 , isMulticast: false
dev:10052020-10-22 12:04:23.195 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:1, sequenceNumber:5, slowRefresh:true)
dev:10052020-10-22 12:04:23.192 pm debugparse description: zw device: 86, command: 5B03, payload: 05 84 01 , isMulticast: false
dev:10052020-10-22 12:04:08.099 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:1, sequenceNumber:4, slowRefresh:true)
dev:10052020-10-22 12:04:08.096 pm debugparse description: zw device: 86, command: 5B03, payload: 04 84 01 , isMulticast: false
dev:10052020-10-22 12:04:07.297 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:1, sequenceNumber:4, slowRefresh:true)
dev:10052020-10-22 12:04:07.293 pm debugparse description: zw device: 86, command: 5B03, payload: 04 84 01 , isMulticast: false
dev:10052020-10-22 12:04:06.578 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:1, sequenceNumber:4, slowRefresh:true)
dev:10052020-10-22 12:04:06.575 pm debugparse description: zw device: 86, command: 5B03, payload: 04 84 01 , isMulticast: false
dev:10052020-10-22 12:04:05.987 pm debugskip: CentralSceneNotification(keyAttributes:4, sceneNumber:1, sequenceNumber:4, slowRefresh:true)
dev:10052020-10-22 12:04:05.983 pm debugparse description: zw device: 86, command: 5B03, payload: 04 84 01 , isMulticast: false
dev:10052020-10-22 12:03:28.486 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:03:26.901 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:26.883 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:26.835 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:26.502 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:26.389 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:26.180 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:25.668 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:25.462 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:25.413 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:25.408 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:24.835 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:24.641 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:24.542 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:24.519 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:24.418 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:24.397 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:11.581 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:11.578 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:11.479 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:11.476 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:11.322 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:11.320 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:11.296 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:11.293 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:11.118 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:11.115 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:11.107 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:11.104 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:11.016 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:11.013 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.992 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.989 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.869 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.866 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.787 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.784 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.726 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.723 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.660 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.657 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.597 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.594 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.571 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.567 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.542 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.539 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.371 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.367 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.290 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.286 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.241 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.238 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.099 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.095 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:10.052 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:10.049 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:09.994 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:09.990 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:09.476 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:09.472 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:09.393 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:09.390 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:09.339 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:09.336 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:09.336 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:09.332 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:08.981 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:08.978 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:08.805 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:08.803 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:08.794 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:08.792 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:08.722 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:08.718 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:08.641 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:08.637 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:08.610 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:08.607 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:08.562 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:08.549 pm debugskip: CentralSceneNotification(keyAttributes:0, sceneNumber:2, sequenceNumber:3, slowRefresh:true)
dev:10052020-10-22 12:03:08.548 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:08.507 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:08.491 pm debugparse description: zw device: 86, command: 5B03, payload: 03 80 02 , isMulticast: false
dev:10052020-10-22 12:03:06.262 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:05.933 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:05.686 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:05.534 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:05.311 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:05.179 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:05.138 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:05.113 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:04.978 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:04.894 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:04.668 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:04.522 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:04.260 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:04.200 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:04.171 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:03.708 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:03.370 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:03.195 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:03.075 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:03.030 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:03.002 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:02.896 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:02.829 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:02.765 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:02.763 pm debugparse description: zw device: 86, command: 2503, payload: FF , isMulticast: false
dev:10052020-10-22 12:03:00.300 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:03:00.293 pm infoBasicReport value: 255
dev:10052020-10-22 12:03:00.290 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:59.994 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:59.986 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:59.982 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:59.640 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:59.633 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:59.630 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:59.590 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:59.583 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:59.581 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:59.481 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:59.474 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:59.472 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:59.395 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:59.387 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:59.384 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:59.277 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:59.271 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:59.268 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:59.129 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:59.122 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:59.119 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:58.946 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:58.939 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:58.937 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:58.868 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:58.861 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:58.858 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:58.806 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:58.798 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:58.796 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:58.788 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:58.781 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:58.778 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:58.759 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:58.753 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:58.750 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:58.578 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:58.571 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:58.568 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:58.530 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:58.523 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:58.521 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:58.502 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:58.493 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:58.490 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:58.028 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:58.021 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:58.018 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:57.647 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:57.639 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:57.637 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:57.615 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:57.608 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:57.602 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:57.574 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:57.567 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:57.564 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:57.529 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:57.522 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:57.519 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:57.449 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:57.440 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:57.437 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:57.409 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:57.402 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:57.399 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:57.326 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:57.319 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:57.317 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:57.239 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:57.233 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:57.230 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:57.208 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:57.201 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:57.198 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:57.140 pm infoFront Porch Side Light Switch 2 is on [physical]
dev:10052020-10-22 12:02:57.133 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:57.131 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:57.089 pm infoFront Porch Side Light Switch 2 was turned on [physical]
dev:10052020-10-22 12:02:57.080 pm infoBasicReport value: 255
dev:10052020-10-22 12:02:57.076 pm debugparse description: zw device: 86, command: 2003, payload: FF , isMulticast: false
dev:10052020-10-22 12:02:53.840 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:53.731 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:53.518 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:53.245 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:53.155 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:53.145 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:53.135 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:52.845 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:52.817 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:52.768 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:52.068 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:51.862 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:51.777 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:51.547 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:51.484 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:51.459 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:51.345 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:51.338 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:02:51.331 pm infoBasicReport value: 0
dev:10052020-10-22 12:02:51.327 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:51.267 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:51.246 pm debugparse description: zw device: 86, command: 2503, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:50.742 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:02:50.735 pm infoBasicReport value: 0
dev:10052020-10-22 12:02:50.732 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:50.566 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:02:50.557 pm infoBasicReport value: 0
dev:10052020-10-22 12:02:50.552 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:46.497 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:02:46.488 pm infoBasicReport value: 0
dev:10052020-10-22 12:02:46.485 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:45.748 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:02:45.738 pm infoBasicReport value: 0
dev:10052020-10-22 12:02:45.735 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:45.444 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:02:45.435 pm infoBasicReport value: 0
dev:10052020-10-22 12:02:45.432 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:45.330 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:02:45.323 pm infoBasicReport value: 0
dev:10052020-10-22 12:02:45.320 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:45.162 pm infoFront Porch Side Light Switch 2 is off [physical]
dev:10052020-10-22 12:02:45.149 pm infoBasicReport value: 0
dev:10052020-10-22 12:02:45.142 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
dev:10052020-10-22 12:02:45.127 pm infoFront Porch Side Light Switch 2 was turned off [digital]
dev:10052020-10-22 12:02:45.114 pm infoBasicReport value: 0
dev:10052020-10-22 12:02:45.100 pm debugparse description: zw device: 86, command: 2003, payload: 00 , isMulticast: false
