Zooz ZEN20 Ver 2.0 Power Strip - Great Device
I just got my Zooz ZEN20 Power Strip and man am I impressed. The quality is high and the functionality is great! It looks and feels great and exudes quality from the packaging to the finish on the product.
Besides control of the 5 outlets, the power reporting is good and it also has 2 USB outlets (can't be controlled but report power values). It shows up in devices as the main strip and child devices for each outlet. Z-wave plus and repeater as well.
My application.... I have 4 POE switches that feed my cameras. Sometimes my cameras go offline and have to be power reset. Right now I have to unplug the ethernet cable and replug it to reset the camera. With this power strip, I have the POE switches plugged into the outlets. I have a tile on the dashboard that groups the camera names with the switch. I created a virtual button to turn off the switch, wait 30 second and turn it back on. That resets the failing camera (and the others on that switch). Works great. I am also monitoring the power on each outlet and can see when it drops below a normal value (different day and night due to IR lights) and can respond.
Thanks for sharing your application! We're happy to hear the strip is working well for you :slight_smile:
You may want to consider getting POE switches that allow for individual port control of POE output so as to independently power-cycle your cameras. Relatively cheap TP-link switches have this feature or consider the Cisco SG-350 line of switches which can be found fairly cheaply on Amazon for more professional-level options. Also, I have 8 Amcrest 4MP outdoor POE cameras-- they have been up 2 years and I have never needed to power cycle one. Why do yours keep needing to be reset?
I just picked one up and it was real easy to configure. It's on sale now at this site: Zooz Z-Wave Plus S2 Power Strip ZEN20 VER. 2.0 - The Smartest House
I know this is an old post, but I've just installed and paired a couple of these Zen20's, and I'd like to know what tile you are using on a dashboard to monitor power. What does the tile definition look like to display power consumption.
Using the latest rev ( 2.2.3.119) do I need to have the parent and children set up as both outlets and power / energy meters on separate tiles? Which one, btw, energy or power would be the better template to use for this device?
Said another way, can I use the Power Meter template and have it report energy consumption and function like an outlet (on/off) as well under a single tile?
