Just installed a new Zen77 dimmer. I set it up in HE with the Zen Advanced Dimmer driver. At first it seemed great. I was able to set everything as expected and it all worked. But then as I made some changes, it kept showing Status Syncing or pending changes, and doesn't seem to ever finish. I'm also seeing significant lags (a minute? two minutes? ) to HE actions - and even problems with the switch responding to physical paddle presses.
Most of this started after I set the advanced parameter to disable programming from the paddle - which I thought was necessary to be able to get reports of double, triple taps on the paddles.
The other weird thing - after I set the driver to the advanced one - after a bit of a delay, all the advanced preference settings became visible - which I believe is the expected behavior. But now they've all disappeared again. Hitting Configure, Refresh, waiting a while - none of that has brought back the advanced setting. I switched the driver to the standard Zen77 , saved device, switched back to the advanced dimmer - still not getting advanced settings back.
(Interestingly - I have two other Zen 77 switches - also with the advanced driver. The advanced settings disappeared on those as well - and i never changed the paddle programming setting for those.)
What's going on here? Any thoughts?
