Zooz zen 30 buttons
Both tapping up on the dimmer portion on my zen 30 as well as pressing the relay switch both send "button 1" to hubitat. Is there any way to change this?
Ask Zooz for beta firmware 1.07. Assuming you're using 2.2.4.147 or later, the driver was written against the 1.07 firmware and fixes this issue. Other issues exist, however. For basic use (no double-tap / scene control) you should be all set with this fix.
