Zooz Power Strip (ZEN20) - keeps Forgetting preferences, no power reporting
Just started another configure and it is getting the out of memory errors again for the power strip.
Also it started with 20 something pending changes and is slowly going down. Should it do that every time or only perform updates on parameters that were in fact changed?
I am not sure it is really worth messing with if the energy reading for a child device is only reporting back the total energy reading for the power strip. It's really useless info.
The error I am getting during the configure:
java.lang.OutOfMemoryError: Java heap space on line 1281 (method parse)
This also caused the hub to become very sluggish, had to reboot again.
After the reboot the MeterEPs now shows, [0,null,null,null,4,5]. CH1 is still the only child device reporting power, however.
When you run a configure and settings are already synced up, it will then redo the entire config like a freshly paired device. So its not something you normally do on a regular basis. Also, it should run quick enough that it says says Syncing... for a little bit and then completes. With it pausing that is telling me there is a delay in zwave messages or the hub processing them very slowly.
Sounds like maybe you have something else going on with your hub if memory is getting low so quickly. I do see the memory tanking a little on my hub possibly when I ran the configure. That line 1281 is something that is in all my drivers. Possibly there is something wrong with the current hub firmware using that specific function. I will see if there is another way I can do it.
On my ZEN25 it looks like the energy and power readings are independent for each channel.
I will just do a fixed list for the metering detection which will reduce some of the device commands and ensure the metering is being used on the proper endpoints.
It's my oldest, actually my first hub, down in my shop. It's a C5. My plan was to replace it with a C7 when I got my C8. I found out after purchasing the C8, however, that the C8 does not work well with my old Iris V1 devices. I only have a few in the house but until I replace them I have to keep my C7 here to run those.
All that to say it is an older hub, so maybe that is it.
I added a preconfigured list for the endpoints that have metering, so it will not need to probe for that anymore. I also moved that inspect() call to another place which will only run at the end of a sync instead of every parameter change.
Added some (possibly temporary) code to force the 5 settings I am not showing, to enable the power reporting on all 5 channels in case some other bad driver shut them off.
Same place for the code: GIST LINK REMOVED - Driver added to Github/HPM
Installed the new driver. The meterEPs now shows [0,1,2,3,4,5], but still only CH1 is shows a energy reading. Once updated I did a configure and the sync went a bit faster, but still hung up on the last three syncs and took a while but it did sync. Then I got a an error the Zigbee radio was offline, and I had to reboot.
Something is going on with this hub. It seems to have started after installing this driver, but I can't be sure. Could just be a coincidence, also this is the hub in my shop and I have not been keeping an eye on it lately. This driver has had me pay more attention as of late, so it could be I just had not noticed the issue until now. Several times over the last few days I have seen a severe hub load error on it. Goes away after a reboot.
I would do a local backup and then a restore on it which will also do a soft reset. Should be a smooth and simple process to do.
There have been numerous cases with the 2.3.6 firmware with memory issues where this seems to fix it (no idea why).
See if that helps.
Once that is sorted out, I would try the configure one more time with DEBUG on, and check the logs, you should see some confirmation at the very end (top) showing parameters 29 - 33 being set to 1. That will confirm that power reporting is at least enabled for all 5 channels.
Then with Debug still on, try a refresh again. Hopefully more reports will come back for all 5 channels and show in the logs.
Last time you tried the refresh it was not asking for the meters on all the channels due to the probe not working but that should be resolved now. Although they still should be reporting on their own outside of the refresh unless it is disabled with those parameters.
Did a restore and I thought maybe it helped. It synced pretty quickly. Didn't show a hub load error. Then I looked at channel 5 and it showed energy so I thought that was it.
Then I got a hub load elevated error and now only CH5 shows energy . none of the others do. Think I will try a soft reset and then restore and see what happens.
@cuirbear @terminal3
I have added this driver to my HPM plugs driver package:
A matchup should link your manually installed driver to my package if you want to.
