I’m using ZMC to aggregate ~15 motion sensors into a single virtual whole house motion sensor for a variety of purposes. It’s configured as Motion Aggregation with 5 min activity timeout.
I keep getting this error continuously. Any ideas?
errorjava.lang.Exception: Unable to aquire lock to schedule run once for zoneOff on line 257 (inactiveHandler)
I built a similar set on my production hub with 24 sensors, it's been running since this morning with no errors.
What platform version are you on, and when was the last time you rebooted?
@mike.maxwell@bobbyD
Guys, I've temporarily disabled this app since it's messing with the hub. But I'm kinda dead in the water without it. Anything I can try?
That error message seems strange for motion. Lock?
Anyway, if the error is easy to produce I would start again from scratch and introduce a couple of sensors at a time.
Wait awhile and introduce a couple more. Keep going until the error starts. Might help pinpointing a device that is causing it.
It does seem strange for motion, but @mike.maxwell confirmed above in the thread that it indicates that the scheduler crapped out -- it's not specific to ZMC. I've even disabled ZMC completely annd I'm still getting the errors and behavior described above. There is something going wrong with this hub. Thankfully it's my one hub that has very little or no custom code. Hoping someone from Hubitat will help.
one of these is causing the errors, i suppose it could be a device too, but lets start with disabling these:
Device and Hub watchdog, Konnected, Maker API.
As far as the others, we're looking for apps that are running a pile of schedules, you can see these by clicking the info icon in the apps list...
If still erroring, then please post a list of user device types, or PM me your hub id.
OK, disabled those 4 apps. Also re-enabled ZMC so that we'd have a clean HE install to work with.
It's still throwing lots of errors. Will PM you the hub ID in a sec.
Also FWIW, I use this as my "coordinator" hub---i.e., 4 other hubs have the zwave, zigbee, wifi, and cloud devices which are then hub-meshed to this hub for any cross-hub automation or dashboards. So I have basically no native devices on this hub, only virtual stuff. There could be 1 or 2 zwave devices and that's it. With that said, there are a LOT of virtual devices.
