ZigBee Wireless Scene Switch
Make sure you are using the latest dev. branch version 2.6.3. or never. There are doubts that the previous versions starting from 2.5.0 up to 2.6.2 may cause extensive battery drain for some of the scene switches. You will need to pair the TS004F/TS0044 switch again to HE, to ensure the battery reporting is left as it is set by default from the manufacturer.
