@mike.maxwell I found that my Sengled Element Plus bulbs weren’t dimmable via the driver settings. I’m using the Zigbee White Color Temperature Bulb driver and discovered I must have a value saved in the Transition Time field of the driver or they won’t respond to dimming by the driver settings, even though Rules are able to adjust the brightness level with a fade time. Must have at least a 0, but I chose 1 second, because the results are then smooth.
Is this a normal requirement of the driver or a unique requirement of these unique bulbs?
