I have read about the Built-in Zigbee Thermostat driver - but maybe I am missing something - where do you find it? I have just installed one of the centralite pearl thermostats and paired it up.
But when I look at the device it says it's unknown and doesn't have any options.
I could use your help on this so this doesn't happen to the next customer, firstly let me know that the driver works as expected (and yes that is the correct one for that thermostat), which you should know in a jiffy, then, and this is the part that's optional, if you could remove the thermostat then re join it, but this time before moving off of the device discovery page, if you could click the more button, then copy/past that data here, then I can add that to the existing driver, and in the future we have this sorted correctly.
Also, when replacing drivers, particularly zigbee ones, be sure to hit configure in the driver page after changing the driver to be sure that the correct configuration parameters ect are pushed to the device.
Has there been any progress with the Zigbee thermostat driver? I have a centralite HA 3156105 and they go for about $25 and they are a killer deal, I plan I’m using them as simple physical thermostats for the keen home vents in different rooms. I cannot, however get the operating state to update. All other functions seem to work fine. I can change the operating state, but it just reports back as unknown.
Thanks Mike! Is this released or still in que? FYI, I somehow did manage to get to to finally sync. I had to change the driver then change back press configure and then I turned on the debug logging. Somehow, it actually seemed like activating the debug logging is what triggered the thermostatiperatingstate to actually update from unknown to actual operating state as nothing else seemed to work.
@rdstov Hey, I see you are using the HA 3156105 which is intriguing. I see these on eBay for about $30 which is a great deal if they work. Have you found them to be reliable?
These are often titled "CentraLite HA Thermostat 3156105 Zigbee for Xfinity" with the "for Xfinity" being the part that worries me. Is that the version that you have?
Have Honeywell cloud integration at the moment but it just is not cutting it.
@garyjmilne I do find it reliable (The $30 or less eBay price it why I tried it myself). It’s not wired at all, I simply use it as a physical thermostat for my wife to control a space heater connected to an IKEA zigbee outlet. I set the thermostat on the space heater to high. It works quite well. The interface via dashboard is somewhat slow and doesn’t always take the changes, but the recent update may have fixed this (I haven’t really used it much as it’s warm weather now).
It is pretty amazing how much they packed into this tiny and aesthetically pleasing thermostat. I have mine set (on c-wire) to never turn off the backlight because it's nice to glance over at it..
I agree. It is definitely one of the most aesthetically pleasing thermostats I've had. I used to have an ecobee3 in the same spot - this is a lot less noticeable and no less functional.
[quote="aaiyar, post:14, topic:5317"]
make suggestion, the Honeywell T6 Pro z-wave+ thermostat is an excellent thermostat
[/quote] Thanks for the suggestion. That would be my best case scenario but I installed HubConnect today and that seems to work well with my two TCC connected Honeywell’s.
