Hi guys,
Before buying a Hubitat, I asked their support on Facebook about functionality of using ZigBee bulbs(in this case Hue) directly with Hubitat.
Unfortunately, I cannot achieve the functionality that I was informed was possible. When I add a Hue ambiance bulbs, they are added as generic RGB ZigBee bulbs. I can then change them to generic CT bulb, for the temperature part of ambiance bulbs to become adjustable by Kelvin temperature. I can then create scenes with the wanted color temperature and brightness. However if I turn of the bulb, and activate a scene, the bulb only turns on to its previous setting. If I hit “on” for the scene once again while the bulb is now on, it changes to the specified parameters. This is far from the behavior I was informed about.
With deCONZ I am able to save scenes, say, Scene 1: 5% brightness - warm, scene 2: 100% brightness: cold. If I activate either scene, the bulb turns on straight into these configured settings. With Athom Homey, this was seemingly not currently possible. I asked deCONZ developers about this functionality, and they say it has to do with using the persistent storage on the bulbs to save scenes, that can then be called directly with a single command. This is supposed to be the one and only way to make these kinds of bulbs work properly, as ZigBee can only accept a single command at a time.
Apparently, no one else has implemented ZigBee integration in this way yet, which I really do not understand. Especially given the fact that the deCONZ code is right there to be inspired from.
Is the Hubitat going into the ever growing pile of incapable home automation systems I regret having bought, or is there any good solutions?
