Does it matter if the repeater is in the "on" or "off" state? does it use the same amount of power in both states? what is a low ram repeater? which would be a high ram repeater?
Thank you!
Thank you!
Assuming you're referring to a plug-in smart outlet, no it does not matter what the state of the 'switch' is. The repeater is always on.
It should use about the same amount of power whether the smart outlet is on or off, assuming there is nothing plugged into it, of course. There are so many smart outlets on the market, it is hard to say without know the specific model number...and even then you'd probably need to measure the outlet's power usage with something like a Kill-A-Watt device.
Iβve never heard of these terms, though Iβm hardly any kind of zigbee expert.
However, my zigbee repeating devices all seem to work fine. So itβs not a spec that seems to matter much to me?
Here is the best explanation I've seen of that on the forums, or basically, the takeaway is that only the hub will be a "high RAM concentrator," assuming that's what you are referring to:
thanks you guys answered all my questions. I had one more important question but i cant remember it right now..
I have a few high ram repeaters, ie: XBee modules. They route many devices, like 28 or something
