I have a handful of the Lutron Aurora dimmers (Z3-!BRL). For smartbulbs, they are a great little in-wall remote that I've found simple and reliable. Until now.
I decided to move my smartbulbs (and the remotes that control them) over to a second hub for reasons that are beyond the scope of this post. When I factory reset the Auroras and then added them to hub #2, they paired without a problem, but do not respond to any direct physical input to the device, not ON/OFF and not change in dimmer level. Weird.
The logs say, "Command off is not implemented on [devicename]". Same for On.
Then repeated: "skipped descMap:[raw:catchall: 0000 0013 00 00 0040 00 2049 00 00 0000 00 00 814920E96EFEE70F00FFFF80, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2049, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[81, 49, 20, E9, 6E, FE, E7, 0F, 00, FF, FF, 80]]" I don't know what to take away from either message.
I have already tried the following without success:
- replaced batteries
- made sure zigbee mesh on new hub is solid
- changed zigbee channel to make sure there's no interference with wifi
- removed, factory reset, and re-paired.
I have repeated the above pattern for 5 copies of the Aurora dimmer. I'm stumped. Any ideas?
EDIT: I just tried them on hub #1, and they work fine. But when I add to hub #2, I get the above problems. Both C7's, both on the latest hub version.
