before i get these installed, im hoping to confirm they will work with hubitat?
They are UIS Zigbee Pro ?
thank you
thank you
Zigbee pro defines the network stack, there is no mention in the link as to the application layer.
Hubitat supports zha 1.2.
Ah thanks. So if this device is zb 2.0 or 3.0 it will only work on HE if it falls back to 1.2?
never heard of this, 3.0 should fall back to ZHA 1.2
Check for a device listing here:
https://zigbee.org/zigbee-products-2/
If you can find it, it will likely work, if not it likely won't...
Hey, when you get one of those controllable relays, please advise if those switch contacts are “dry” - that they have have isolated terminals and are NOT directly switching mains 240vAC. Thx
If so I could use one of them, to provide me with a means of deactivating the Siren and flashing light independently, in an old but loud siren box I have .
@joel_dj, looks like it’s on the list....
Jaycar “remote switch”
looks like there is a bit more info on the wiring too for you
thanks for that. it's very very similar and is called jaycar. that's like calling the switch a bestbuy switch. (tho jaycar is a very small company comparably)
Yeah, it looks like it’ll work for me although I had to take a second look at their wiring diagram as I think they made a poor choice of wire colours.
The diagram is correct so long as you pay attention to the connections first and colour coding 2nd.
I’ll grab one in the next few weeks and have a play.
Sorry guys, No luck so far getting anything from one of these devices.
Can’t get a peep out of it.
I did find a Link to the Zigbee board inside
It hasn't helped me "pair" the unit though. XBTZBM-220
Seriously? Bummer. I am getting these installed today !
Yep. Identical.
They power up about 4 sec later a Red LED flashes.
I press the Setup button and get 5 Green LED flashes then nothing for about 5 seconds and then a Red LED flash, which appears to indicate Not Paired.
I’m getting nothing detected in HE.
I’ve tried pairing as Zigbee AND as Zigbee Iris v1.
Nothing.
Oh and that’s with the units within 1m of the HE Hub.
do you only have the one device? (could be faulty? I have 3 so hopefully one works!)
ill report back in 5 or so hours how mine go but that is a bit odd... considering they are cert @mike.maxwell any tips here? guessing not until you try one
Yes, I have just the single unit.
Good luck man. Hope you have better success.
for pairing LOL, no, if it eventually makes it's way and is discovered as something, I might try the Nue Zigbee Switch driver which has muiti endpoint discovery bits wired into the configure method...
if it gets discovered yeah. these are certified devices tho so i don't see why they would not work unless they are not certified correctly - tho i don't know what that means
will report back
will try catch all if it doesn't come up . i'm assuming @njanda did this
yep same outcome on two of these - no response at all from hub. nothing on logs either.
may just return them.. still leaves me with my fans not automated. medieval.
any other ideas what i could use instead anyone? EDIT: Looking at my fans when electrician had them out - they are plug in. so i can just use a couple of my spare swannone smart plugs! Easy.
Yeah, I tried everything, to get something out of the little devils !
So at least you've got a single speed solution, straight away. Better than nothing
