used these in the past. .the latest i just paired.. seems to have paired incorrectly in latest firmware as a multi point switch ... it is not.. device info same as ones that previous paired as generic zigbee switch..
it really should be using the generic zigbee outlet, drivers are almost exactly the same, just different advertised capabilities. can you try the outlet driver and let me know how it works?
You might want to look at the driver I modded [RELEASE] Zigbee eWeLink-CMARS-Seedan Outlet Driver/Switch
I specifically added the fingerprint for that unit. Initially I had problems with the generic driver due to the outlet not being used for days at a time and it would flag with Watchdog. This has a presence ping built in, and I've added more features as well.
*Edit 12-11-2022 - modded driver - it now reflects support also for eWelink Switch under same model line - * manufacturer: eWeLink * model: SA-003-Zigbee
