Driver for Makegood MG-AUZG01 Double GPO with power reporting.
Based on the work of Richard Laxton: Zigbee reporting on multi-endpoint devices
Bought from eBay: Zigbee Double Power Point | eBay
Looks like:
Identifying manufacturer string: _TZ3000_dd8wwzcy
* Copyright 2021 Richard Laxton, based on work by Steve White
* Modifications copyright 2023 Dan Murphy
* Licensed under the Apache License, Version 2.0 (the "License"); you may not
* use this file except in compliance with the License. You may obtain a copy
* of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS, WITHOUT
* WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the
* License for the specific language governing permissions and limitations
* under the License.
metadata
// Automatically generated. Make future change here.
definition(name: "Makegood MG-AUZG01 Double GPO", namespace: "community", author: "Dan Murphy")
capability "Actuator"
capability "Switch"
capability "PowerMeter"
capability "Voltage Measurement"
capability "CurrentMeter"
capability "Configuration"
capability "Refresh"
capability "Sensor"
attribute "ACFrequency", "number"
attribute "RMSCurrent", "number"
command "toggle"
command "identify"
command "resetToFactoryDefault"
fingerprint profileId: "0104", inClusters: "0004,0005,0006,0702,0B04,E001,0000", outClusters: "0004,0005,0006", manufacturer: "_TZ3000_dd8wwzcy", model: "Double Power Point", deviceJoinName: "Smart GPO"
preferences
section()
input "intervalMin", "number", title: "Minimum interval (seconds) between power, current and voltage reports:", defaultValue: 5, range: "1..600", required: false
input "intervalMax", "number", title: "Maximum interval (seconds) between power, current and voltage reports:", defaultValue: 600, range: "1..600", required: false
input "minDeltaW", "enum", title: "Amount of power (W) change required to trigger a report:", defaultValue: "5", options: ["1", "5", "10", "20", "50", "100", "500", "1000"], required: false
input "minDeltaV", "enum", title: "Amount of voltage (V) change required to trigger a report:", defaultValue: "1", options: ["1", "2", "5", "10"], required: false
input "minDeltaA", "enum", title: "Amount of current (A) change required to trigger a report:", defaultValue: "0.1", options: ["0.1", "0.5", "1", "2", "3", "5"], required: false
section
input "enableTrace", "bool", title: "Enable trace logging?", description: "Show high-level activities during the operation of the device?", defaultValue: false, required: false, multiple: false
input "enableDebug", "bool", title: "Enable debug logging?", description: "Show detailed responses to device commands?", defaultValue: false, required: false, multiple: false
installed
def installed()
logInfo "Installed"
initialize()
Called when the preferences are saved
Doesn't do much other than call configure().
def updated()
logInfo "Configuration saved"
initialize()
initialize
def initialize()
logInfo "Initialize"
state.lastSwitch = 0
if (enableTrace || enableDebug)
logInfo "Verbose logging has been enabled for the next 30 minutes."
runIn(1800, logsOff)
configure()
parse
Processes incoming zigbee messages
def parse(String description)
logTrace "Msg: Description is ${description}"
def event = zigbee.getEvent(description)
def msg = zigbee.parseDescriptionAsMap(description)
logTrace "Parsed data... Evt: ${event.name}, msg: ${msg}"
// Hubitat does not seem to support power events
if (event)
if (event.name == "power")
def value = (event.value.parseInt()) / 10
event = createEvent(name: event.name, value: value, descriptionText: "${device.displayName} power is ${value} watts")
logTrace "${device.displayName} power is ${value} watts"
else if (event.name == "switch")
def descriptionText = event.value == "on" ? "${device.displayName} is On" : "${device.displayName} is Off"
event = createEvent(name: event.name, value: event.value, descriptionText: descriptionText)
// Since the switch has reported that it is off it can't be using any power. Set to zero in case the power report does not arrive, but do not report in event logs.
if (event.value == "off") sendEvent(name: "power", value: "0", descriptionText: "${device.displayName} power is 0 watts")
// Pass the switch event to the appropriate child device. Endpoint is identified by different properties depending on whether switching is initiated from the child device
// or from a physical button press
logDebug "Looking for device ${getChildNetworkId(msg.sourceEndpoint ?: msg.endpoint)}"
def cd = getChildDevice(getChildNetworkId(msg.sourceEndpoint ?: msg.endpoint))
if (cd)
logDebug("Passing event to child ${cd.displayName}")
cd.parse([event]);
// DEVICE HEALTH MONITOR: Switch state (on/off) should report every 10 mins or so, regardless of any state changes.
// Capture the time of this message
state.lastSwitch = now()
// Handle interval-based power reporting
else if (msg?.cluster == "0B04")
// Volts
if (msg.attrId == "0505")
def value = Integer.parseInt(msg.value, 16)
event = createEvent(name: "voltage", value: value, descriptionText: "${device.displayName} voltage is ${value} volts")
logTrace "${device.displayName} voltage is ${value} volts"
// Current and power are in additional attributes
log.debug "msg = $msg"
log.debug " in additionalAttrs"
def additionalAttrs = msg?.additionalAttrs
additionalAttrs.each
log.debug "it=${it}"
log.debug "itVal=${it.value}"
log.debug "itAttrId=${it.attrId}"
// Watts
if (it.attrId == "050B")
def value = Integer.parseInt(it.value, 16)
sendEvent(name: "power", value: value, descriptionText: "${device.displayName} power is ${value} watts")
//event = createEvent(name: "power", value: value, descriptionText: "${device.displayName} power is ${value} watts")
// RMS Current
else if (it.attrId== "0508")
def value = Integer.parseInt(it.value, 16) / 1000 // Current is measured in mA for the outlet
sendEvent(name: "amperage", value: value, descriptionText: "${device.displayName} RMS current is ${value} A")
//event = createEvent(name: "amperage", value: value, descriptionText: "${device.displayName} RMS current is ${value} A")
logTrace "${device.displayName} RMS current is ${value} A"
// Handle everything else
else
def cluster = zigbee.parse(description)
if (cluster?.clusterId == 0x0006 && (cluster.command == 0x07 || cluster.command == 0x0B))
if (cluster.data[0] == 0x00 || cluster.data[0] == 0x02)
// DEVICE HEALTH MONITOR: Switch state (on/off) should report every 10mins or so, regardless of any state changes.
if (cluster.data[0] == 0x00) logDebug "ON/OFF REPORTING CONFIG RESPONSE: " + cluster
if (cluster.data[0] == 0x02) logDebug "ON/OFF TOGGLE RESPONSE: " + cluster
else
logError "ON/OFF REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
event = null
else if (cluster?.clusterId == 0x0B04 && cluster.command == 0x07)
logDebug "POWER REPORTING CONFIG RESPONSE: " + cluster
else
logError "POWER REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
event = null
else if (cluster?.clusterId == 0x0003 && cluster.command == 0x04)
logInfo "LOCATING DEVICE FOR 30 SECONDS"
// Handle bind responses
else if (cluster?.clusterId == 0x8021)
logInfo "Bind response"
// Handle general cluster events
else if (cluster?.clusterId == 0x8001)
logInfo "General cluster event"
else
logWarn "DID NOT PARSE MESSAGE for description : $description"
logDebug "${cluster}"
return event ? createEvent(event) : event
private onOffClusterCommand(int destEndpoint, int command)
logInfo("onOffCLusterCommand(${destEndpoint}, ${command})")
if (destEndpoint < 0x01 || destEndpoint > 0x02)
logError("Unknown target endpoint ${destEndpoint}")
return;
if (command < 0x00 || command > 0x02)
logError("Unknown command for onOffCluster")
return;
// Send command to on/off cluster (0x0006) on the appropriate target
return "he cmd 0x${device.deviceNetworkId} 0x${destEndpoint} 0x${zigbee.ON_OFF_CLUSTER} 0x${command} {}, delay 200"
on
Turns the specific targetEndpoint of the device on .
Uses standard Zigbee on/off cluster.
def on(int destEndpoint)
onOffClusterCommand(destEndpoint, 0x01);
off
def off(int destEndpoint)
onOffClusterCommand(destEndpoint, 0x00);
toggle
def toggle(int destEndpoint)
onOffClusterCommand(destEndpoint, 0x02);
* Turn on all endpoints
def on()
[on(0x01), on(0x02)]
* Turn off all endpoints
def off()
[off(0x01), off(0x02)]
Toggle all endpoints
def toggle()
[toggle(0x01), toggle(0x02)]
identify
Flashes the blue LED on the plug to identify it.
def identify()
zigbee.writeAttribute(0x0003, 0x0000, DataType.UINT16, 0x00A, [:], 200)
Resets the plug to factory defaults but does not unpair the device.
def resetToFactoryDefault()
logWarn "Resetting device to factory defaults..."
zigbee.command(0x0000, 0x00, [:], 200)
runIn(1, configure)
refresh
Refreshes the device by requesting manufacturer-specific information.
Note: This is called from the refresh capbility
def refresh()
def cmd = []
// Switch states
for (endpoint = 1; endpoint <= 2; endpoint++)
cmd += ["he rattr 0xB77D ${endpoint} 6 0 {}", "delay 1000"]
cmd += zigbee.electricMeasurementPowerRefresh(1000) // Watts
cmd += zigbee.readAttribute(0x0B04, 0x0505, [:], 1000) // Volts
cmd += zigbee.readAttribute(0x0B04, 0x0508, [:], 1000) // Amps
return cmd
def getDestinationEndpoint(childDevice)
def epId = childDevice.deviceNetworkId.split('-')[1]
return Integer.parseInt(epId, 16)
def getChildNetworkId(destinationEndpoint)
def destEndpoint = (destinationEndpoint instanceof Integer) ?
destinationEndpoint :
Integer.parseInt(destinationEndpoint, 16)
return "${device.deviceNetworkId}-${destEndpoint}"
def getChildLabel(destinationEndpoint)
switch (destinationEndpoint)
case 2:
return "Left socket"
break;
case 1:
return "Right socket"
def componentOn(child)
logDebug("componentOn(${child.deviceNetworkId}")
sendHubCommand(new hubitat.device.HubAction(on(getDestinationEndpoint(child)), hubitat.device.Protocol.ZIGBEE))
def componentOff(child)
logDebug("componentOff(${child.deviceNetworkId})")
sendHubCommand(new hubitat.device.HubAction(off(getDestinationEndpoint(child)), hubitat.device.Protocol.ZIGBEE))
def componentRefresh(child)
logDebug("componentRefresh(${child.deviceNetworkId})")
refresh()
def deleteChildDevices()
for (child in getChildDevices())
deleteChildDevice(child.deviceNetworkId);
def createChildDevices()
def childDeviceNetworkId = getChildNetworkId(endpoint)
def childLabel = getChildLabel(endpoint)
def cd = getChildDevice(childDeviceNetworkId)
if (!cd)
cd = addChildDevice("hubitat", "Generic Component Switch", childDeviceNetworkId, [label: childLabel, isComponent: true])
else
// Update the names of the child device in case the device labelling rules changed
cd.name = "Generic Component Switch"
cd.label = childLabel
configure
Configures the device, creates children and sets up any reporting
def configure()
logDebug "Configure called..."
def cmd = []
// On/Off reporting of 0 seconds, maximum of 15 minutes if the device does not report any on/off activity
cmd += ["zdo bind ${device.deviceNetworkId} ${endpoint} 0x01 0x0006 {${device.zigbeeId}} {}",
"delay 1000",
"he cr 0x${device.deviceNetworkId} ${endpoint} 6 0 16 0 900 {}",
"delay 1000"]
cmd += powerConfig()
cmd += refresh()
return cmd
powerConfig
Set power reporting configuration for devices with min reporting interval as 5 seconds and reporting interval if no activity as 10min (600s),
if not otherwise specified.
def powerConfig()
// Calculate threshold
int powerDelta = (int) (Float.parseFloat(minDeltaW ?: "1") * 10) // Power is in tenths of a watt
int currentDelta = (int) (Float.parseFloat(minDeltaA ?: "0.1") * 1000) // Current is in mA
int voltageDelta = (int) (Float.parseFloat(minDeltaV ?: "10") * 10) // Voltage is in tenths of a volt
def cfg = []
// All reporting shares the same interval between 5 seconds and 3 minutes by default, override in settings
cfg += zigbee.configureReporting(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x050B, DataType.INT16, (int) (intervalMin ?: 5), (int) (intervalMax ?: 600), powerDelta, [:], 1000) // Wattage report
// Voltage report trigger level does not seem to work so set minimum interval to 120 seconds
cfg += zigbee.configureReporting(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0505, DataType.UINT16, 120, (int) (intervalMax ?: 600), voltageDelta, [:], 1000) // Voltage report
cfg += zigbee.configureReporting(zigbee.ELECTRICAL_MEASUREMENT_CLUSTER, 0x0508, DataType.UINT16, (int) (intervalMin ?: 5), (int) (intervalMax ?: 600), currentDelta, [:], 1000); // RMS Current
return cfg
getEndpointId
Helper function to get device endpoint (hex) as a String.
private getEndpointId()
new BigInteger(device.endpointId, 16).toString()
logError
Displays dewarningbug output to IDE logs based on user preference.
private logError(msgOut)
log.error msgOut
logWarn
private logWarn(msgOut)
log.warn msgOut
logDebug
Displays debug output to IDE logs based on user preference.
private logDebug(msgOut)
if (settings.enableDebug)
log.debug msgOut
logTrace
Displays trace output to IDE logs based on user preference.
private logTrace(msgOut)
if (settings.enableTrace)
log.trace msgOut
logInfo
Displays informational output to IDE logs.
private logInfo(msgOut)
log.info msgOut
logsOff
Disables debug logging.
def logsOff()
logWarn "debug logging disabled..."
device.updateSetting("enableTrace", [value:"false",type:"bool"])
device.updateSetting("enableDebug", [value:"false",type:"bool"])
