Zigbee LED light strip recommendations?
I installed some Govee LED strips under bathroom toe kick. They work well but don’t turn on instantly with motion like I want. Going to repurpose those elsewhere and go for zigbee LED strips instead, so that I can use zigbee association with my Inovelli red series dimmer. Thing is, I don’t know which of the many options to choose. Any recommendations?
Anyone have these Sengled strips?
https://a.co/d/3oAm8Ep
I recently bought these two types of strips and both work very well.
https://www.aliexpress.com/item/1005004868774670.html?spm=a2g0o.order_list.order_list_main.5.54a31802mGwIDx
https://www.aliexpress.com/item/1005001496577263.html?spm=a2g0o.order_list.order_list_main.32.54a31802mGwIDx
Connected them to this controller:
https://www.aliexpress.com/item/1005008554319757.html?spm=a2g0o.order_list.order_list_main.11.54a31802mGwIDx
Fyi:not everyone will be able to see those links. They are geo blocking.
I have the Sengled as under-shelf lighting in my butler's pantry (motion activated), automatic lighting around the inside of my closet doors (contact activated), and as TV backlighting (power use activated) on my main big screen. They work very well. They are all controlled with webcore pistons.
Great. And they come on instantly? Also, it’s a bit unclear whether I have to also have the Sengled hub or if these would connect directly to Hubitat without going through their hub? Hopefully direct to Hubitat….
For ZigBee there's always Hue strips, they work great but are very expensive.
Fast, reliable and durable.
I did pick up an IKEA ORMANÄS strip but have yet to try it out.
Well that’s annoying! Not sure how to share without…
Yes, they connect directly to Hubitat. I use the Advanced Zigbee RGBW Bulb driver. I do not appreciate a delay in turning on. So they work fast enough for us.
