I'm not sure if you guys have seen my other posts but I have had months of Zigbee comms issues. In a total act of desperation, I decided to a soft reset and then rebuild from scratch. Devices are not being discovered well, they are not getting the right driver and now the logs are getting filled with the below errors. I am at a total loss. I HATE Smartthings but may need to move back if I can't get this resolved.
[dev:20](http://192.168.1.100/logs#dev20)2021-03-19 01:40:51.739 pm [error](http://192.168.1.100/device/edit/20)groovy.lang.MissingMethodException: No signature of method: GenericZigbeeOutlet.parseSDR() is applicable for argument types: (java.util.ArrayList) values: [[BC, 00, F8, 9A, 18, 01, 04, 01, 00, 01, 00, 06, 00, 00, 03, ...]] Possible solutions: parse(java.lang.String) (parse)
[dev:20](http://192.168.1.100/logs#dev20)2021-03-19 01:40:51.721 pm [error](http://192.168.1.100/device/edit/20)groovy.lang.MissingMethodException: No signature of method: GenericZigbeeOutlet.parseSDR() is applicable for argument types: (java.util.ArrayList) values: [[81, 00, F8, 9A, 18, 01, 04, 01, 00, 01, 00, 06, 00, 00, 03, ...]] Possible solutions: parse(java.lang.String) (parse)
[dev:20](http://192.168.1.100/logs#dev20)2021-03-19 01:40:51.657 pm [error](http://192.168.1.100/device/edit/20)groovy.lang.MissingMethodException: No signature of method: GenericZigbeeOutlet.parseSDR() is applicable for argument types: (java.util.ArrayList) values: [[BA, 00, F8, 9A, 18, 01, 04, 01, 00, 01, 00, 06, 00, 00, 03, ...]] Possible solutions: parse(java.lang.String) (parse)
[dev:20](http://192.168.1.100/logs#dev20)2021-03-19 01:40:51.646 pm [error](http://192.168.1.100/device/edit/20)groovy.lang.MissingMethodException: No signature of method: GenericZigbeeOutlet.parseSDR() is applicable for argument types: (java.util.ArrayList) values: [[A4, 00, F8, 9A, 18, 01, 04, 01, 00, 01, 00, 06, 00, 00, 03, ...]] Possible solutions: parse(java.lang.String) (parse)
Where do I go from here? Even after a soft reset I cant get these GE Zigbee Switches to work right.
