Zigbee Group binding not working
C8Pro hub, trying to get Zigbee group messaging working between Inovelli Blue switch and Inovelli Blue fan canopy module, both zigbee devices. The canopy module creates two child devices, one for the light and one for the fan. I tried direct messaging without success, so I'm trying to get the group messaging working as I can test each function there more easily.
I have the group setup, and if I send power on to the group device directly in the hub UI both the switch and the fan light turn on. Using the switch it turns on the switch and the group device in the hub UI but not the light. If I power on the canopy light the group device turns on. So the group is accurately reflecting the status of either device, and the group can control both devices. But turning on the switch still won't turn on the canopy light, and vice versa.
The group shows Group_782, so I entered 782 in both the switch and the canopy module light child device group binding. Zigbee group messaging is enabled. I also enabled smart bulb mode on the switch so the fan module never loses power. Everything seems like it's setup correctly but I'm still unable to turn on the light from the switch, and commands sent to the canopy module from the hub UI are not reflected on the switch. What am I doing wrong?
I have also experimented with the Enable on/off optimization and the enable metering settings. No changes.
When the group works from the hub UI but not directly between the devices, the binding usually didn't get programmed into the device itself. After saving 782 in the group binding preference on both the switch and the canopy light child device, press Configure on each of them and check the logs to make sure the group commands actually go out. Also confirm that Zigbee group messaging is enabled on the group in the Groups and Scenes app. If it still doesn't respond, try removing both devices from the group and re-adding them, then re-saving the binding, since that clears most of the stubborn cases.
I tried adding and removing in every possible combination. In looking at the logs it looks like the inovelli driver expects the group binding in hex... it errors out if any other format is used. Tried that too. I even went back and tried the direct binding again. Nothing works. After spending 6+ hours on it now, I'm about ready to give up and just say it doesn't work.
With some help from ChatGPT I finally figured it out. I was selecting the child devices for the zigbee binding. That was the problem. I had to select the parent device and change the endpoint.
