Having issues with trying to update some Inovelli Blue switch firmwares. Seems like it should be simple enough to click the button and have the firmware updates. When I do it brings up a dialog stating that the it is at the users own risk. I click OK and nothing happens. Check the logs and notice it is stating to double click due to the firmware being beta. Every time I click the same dialog comes up and the same log message shows up but nothing ever happens. Have tried with 4-5 different switches.
I just tried (single-tap) the firmware update button on one of my Blues and it worked -- it didn't update since I'm already on 2.15, but it responded as such (as would be expected).
What driver version are your Blues on? The latest is the 2023-10-14 version.
They (Inovelli) haven't required the double-tap for f/w updates for a while now.
Make sure you are looking at live unfiltered logs. The firmware update messages get logged from sys:1 so if you are filtered to the devices you are updating you wont see anything.
You should see a couple of log messages when you first click the update button and then if it starts updating you will get a log message every 10%
Exactly my experience. I didn't report it, hoping it would iron itself out, it did not. I have several of the Blue switches, 2 updated with no issue, one keeps giving me the stupid "firmware is beta, double click" and nothing happens
HE staff would need to let us know why. Could be a signal strength issue...maybe
