Dose anyone know of any duel relays which have auto off? I'm looking to replace a fibro
Ideally UK or ali express
There's a 2 channel version of this relay that I can't find right now ....
Didn't look to see if it is available in UK, but at least you have a reference of what it looks like and so on.
Thanks found this one, how do you set them up between on/off switching and momentarily, is it on the driver? Which driver do they use?
MHCOZY Ewelink WiFi Relay Switch,Self-Locking/Momentary Timer WiFi Switch Module,Compatible with Alexa Google Assistant (2CH) https://www.amazon.co.uk/dp/B084DQZKK5/ref=cm_sw_r_apan_glt_i_9F70XQ7TDEE38S8C05EW
Careful - That one is WiFi, not zigbee.
The switching mode is set up from a push button on the board.
Currently there is no specific driver in HE for these devices, the relays are controlled from the built-in stock 'Generic Zigbee Multi Endpoint Switch driver.
Thanks good spot
What about this one, I get nervous with compatability when it says tuya
2 Channel Zigbee Smart Relay Switch, AC/DC 7-24V RF433 ZigBee Relay Module Receive, Tuya & eWeLink Smart Relay Module Compatible with Alexa Google Home, ZigBee Hub Required https://www.amazon.co.uk/dp/B09MF9R89F/ref=cm_sw_r_apan_glt_i_8TQE24AAG2XZY8EGPTTA
Or
MHCOZY 2 Channel 5V 12V ZigBee Dry Contact Relay Switch, Adjustable Self-Lock and Momentary Lock Working Mode, Works with Philips Hue, SmartThings, Alexa and Google Home https://www.amazon.co.uk/dp/B08YY7XFS3/ref=cm_sw_r_apan_glt_i_NDGT97DHY0KHBXZ508QT
I know the second one works.
It arrived today, but the instructions a a bit weak, do you have any telling me what the buttons do and how to set mode to auto off
The "switch model button" will toggle between inching and latched modes. I don't remember what I did to initiate pairing, but I'll take a look at my relay later today.
I think I just put the Hubitat into pairing mode, and plugged in the microUSB cable to power the relay. Paired right away.
