Zigbee devices not working (none)
Title tells it all. Got up this morning and none of the zigbee devices on my C7 are working. My C5 is fine. I still have a few zigbee devices on the C5. Had an extra samsung motion sensor and it paired immediately to the C5. Rebooted the C7 and still no zigbee. Z-wave seems to be fine.
OK, shutdown for a few minutes. After restart everything seems to be working. I read something about zigbee firmware updates. How does that work?
Zigbee firmware updates are for individual devices... and the whole process is kind of a pain.
Were there any indications in the logs that the zigbee radio shut down? If your hub becomes overloaded the Zigbee radio is usually the first to go south...
Also check out this thread:
I only have 13 zigbee devices. This is the first time this has happened. nothing in the hub events except for a few zigbee devices that joined over the last week. (4 actually) the most recent was 4 days ago and everything was fine until last night apparently.
Hmmm. Out of curiosity what were those four you just added? Some "zigbee" devices are "sort of zigbee" and they make a mess.
Do you have anything monitoring CPU and memory?
The last device added was on 8/10 I am trying out a zigbee button so I can turn on/off my stair lights at night without speaking to Madam A. This is a third reality device. I have a few of their motion sensors and have not had problems with them. Interestingly the 3 before that were joined on 8/8. I went through all 13 devices and there were none that showed they were created that day. The latest one was 8/7. All the other devices were created long before these dates.
When you say cpu and memory, do you mean on the Hub?
Is the term "joined" the same as "created"? The log shows devices as joined. The device info shows a create date. Just curious.
Yes, on the hub. You can use @thebearmay's excellent Hub Info device driver to query the hub or alert you on high CPU or low memory,
You can also check your logs and look at the device stats. It will show you how much CPU each device driver is consuming, either as a % of busy time or overall. If anything stands out that might be somewhere to look.
The Third Reality stuff appears to be on the official HE compatibility list. While this is not a prerequisite for the device to work, it is reassuring to know HE has tested the devices and given them a thumbs up for compatibility.
Not the same. The driver is created the first time a device joins the radio, but if a device doesn't have a good connection with the radio it will keep "joining" every time it drops off the radio.
Good to know! So a device that shows multiple joins in the log might have a marginal connection?
I can't see any way to determine from the hub log events which device joined.
I wouldn't worry about that for the moment. It sounds like you are looking at Zigbee logs, and not at the Logs (past Logs) page. If you'd like, you can send me your hub's MAC address and we can take a look at your hub's engineering log (assuming your hub is connected to the cloud) to make sure you are not dealing with a hardware malfunction. Few questions, though, what made you think that none of your Zigbee devices were working? Did you have a notification saying that radio went offline? And have you tested all 13 devices and none responded as expected?
None of the zigbee devices responded. I tested them all. They work now after the shutdown and have worked before last night.
Did a search in past logs for" zigbee" and nothing showed up. Yes I was looking at the zigbee logs.
So no notification that Zigbee went offline? That would be very strange if it didn't, and none of the devices were working. If you'd like me to take a look at what happened, send me a PM.
PM sent
Back to cpu usage. All of the top values are basically kitchen lights and motion sensors. Lots of activity in the kitchen on sunday morning. The only zigbee devices in the kitchen are 2 third reality motion sensors. Neither of which were working this morning.
Unless you are a power user performing heavy tasks via custom apps and drivers for sophisticated automation, I wouldn't worry one bit about CPU and memory utilization. A hub can run hundreds of devices and apps without a hitch.
As @bobbyD said, for apps and devices, worry about the numbers in the blue box (screenshot below) only if the number in the red oval is high.
Verifying this assumption is step 1 in diagnosing a scenario like this. Depending on how the mesh is configured, behavior of a single device can make it appear as if no devices are functioning and derail your troubleshooting efforts. Failure of the hub's Zigbee radio (or stack, if it's software related) could be the root cause but may not be the most likely; it's often accompanied by a 'Zigbee Off' event appearing in Logs > Location events.
It helps if you can visualize what the mesh looks like, keeping in mind that end devices (sensors, buttons) will rely on their parents (repeaters) to communicate, unless they are directly connected as child devices of the hub. If so, they'd be listed in the Child section of the getChildandRouteInfo page (yourhubsIP/hub/zigbee/getChildAndRouteInfo). If they're not directly connected, failure of a single device can make it appear as if no devices are working.
The Neighbor Table is also useful for indicating which repeaters the hub depends on to communicate with the rest of the mesh.
For example, if your mesh is configured as follows, if repeater A dies (hard fail or SoC hang), all 13 Zigbee devices will appear to be dead , even though a dozen of them are 100% functional:
                          repeater B - end devices (6)
                   Hub -  repeater A - end devices (5)
Without mapping tools (like Xbee/XCTU) you can only make a guess as to what your mesh might look like, but even a guess can be helpful in a possible reason for a failure like you're experiencing.
Not only that is accompanied by a 'Zigbee Off', but also you'd have a notification in the upper right hand corner alerting that the "Zigbee radio is offline".
Working with @billybobmc this weekend, it turned out that most devices appeared to be routing through one smart outlet, so yes, checking the getChildAndRouteInfo is critical in troubleshooting Zigbee issues.
