Hi, I had this problem once recently with a CT bulb by Aduro / Eria. I think it was a faulty bulb because when I replaced it with another (same type), it's now working reliably.
It just feels like it's no longer coincidence, as now I'm trying to pair a BTF Zigbee 3.0 RGBWW controller to my Hubitat. It pairs super easily, and it's in a spot between the hub and other devices so it must have a clear signal to the hub.
Between 5 and 10 seconds after it pairs with the hub, it just simply stops responding, until I pair it again and it'll work for another 5-10 secs
Oddly, as I was writing this post, it's now been working for 10 minutes without error. But it still doesn't appear below, should it?
The device is called Shelf LED Strip
Parent child parameters
EzspGetParentChildParametersResponse [childCount=1, parentEui64=0000000000000000, parentNodeId=65535]
Child Data
child:[Sun Room Long Remote, 13D7, type:EMBER_SLEEPY_END_DEVICE]
Neighbor Table Entry
[Spotty Lamp Left, 042B], LQI:255, age:0, inCost:1, outCost:0
[Table Lamp 1, 1B66], LQI:254, age:4, inCost:1, outCost:1
[Luke's Bedside Lamp 1, 3824], LQI:80, age:6, inCost:7, outCost:0
[Living Room Lamp 2, 40A6], LQI:253, age:4, inCost:3, outCost:1
[Bedside Lamp 4, 4270], LQI:215, age:5, inCost:5, outCost:0
[Rear Yard Outlet, 5128], LQI:255, age:4, inCost:1, outCost:1
[Stereo Outlet, 5ECE], LQI:249, age:5, inCost:3, outCost:5
[Penny Light 1, 5F7F], LQI:57, age:0, inCost:7, outCost:0
[Landing Monkey Lamp, 69D9], LQI:241, age:6, inCost:5, outCost:0
[Landing Cabinet Outlet, 6A38], LQI:198, age:4, inCost:7, outCost:0
[Closet LED strip, 9EC8], LQI:231, age:6, inCost:5, outCost:0
[Large Lamp, B688], LQI:251, age:4, inCost:3, outCost:0
[Bedside Lamp 3, DCB8], LQI:211, age:5, inCost:5, outCost:0
[Spotty Lamp Right, E41B], LQI:246, age:3, inCost:5, outCost:0
[Hot Water Dispenser, E654], LQI:254, age:3, inCost:1, outCost:1
[Living Room Lamp 1, EEBA], LQI:248, age:4, inCost:3, outCost:0
Route Table Entry
status:Active, age:64, routeRecordState:0, concentratorType:None, [Hot Water Dispenser, E654] via [Hot Water Dispenser, E654]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Jay's TV, FF82] via [Hot Water Dispenser, E654]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Spotty Lamp Left, 042B] via [Table Lamp 1, 1B66]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Penny Light 1, 5F7F] via [Hot Water Dispenser, E654]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Jay's Bedside Lamp 1, 79B0] via [Hot Water Dispenser, E654]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Luke's Bedside Lamp 2, EF0B] via [Table Lamp 1, 1B66]
status:Active, age:32, routeRecordState:2, concentratorType:Low Ram, [Bookshelf Outlet, EF23] via [Hot Water Dispenser, E654]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Closet LED strip, 9EC8] via [Table Lamp 1, 1B66]
status:Active, age:0, routeRecordState:2, concentratorType:Low Ram, [Rear Yard Outlet, 5128] via [Rear Yard Outlet, 5128]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Bedside Lamp 2, FDB0] via [Table Lamp 1, 1B66]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Infrared Panel, 45DE] via [Table Lamp 1, 1B66]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Outdoor Spots, 4E8E] via [Rear Yard Outlet, 5128]
status:Active, age:64, routeRecordState:0, concentratorType:None, [Penny Light 2, 299B] via [Rear Yard Outlet, 5128]
status:Active, age:64, routeRecordState:0, concentratorType:None, [null, 559E] via [Hot Water Dispenser, E654]
status:Unused
status:Unused
