I recently added 4 hue buttons to my hub using the inbuilt driver and one of them conflicts with an INNR outlet.
The other 3 work fine and no other devices seem to have issues.
The issue as that as soon as the button was added it and the outlet cannot be controlled by the hub and have not reported to the hub.
If I press the button, the outlet does turn off. This is not a rule it just happens.
Is there any way to resolve this type of issue?
I would expect if I added the buttons to the hue bridge this might solve it. But would the buttons show in hubitat? As I know the hue dimmer does not if added this way.
I thought I would reach out before I start experimenting with changing settings as this something I have little knowledge about.
Any help greatly appreciated.
Try power cycling the outlet, if that doesn't bring the outlet back, factory reset it, then re include it.
If the button doesn't start working after you get the outlet working, re include the button as well.
Thanks for the help.
I had to reset them both and rediscovered them.
Both are operating as expected.
I loved that I did not have to delete them from Hubitat, so I didn't have to redo the rules.
