Zigbee control for step motor
I'm sorry, I am a little confused. I am good at software and programming but never as good in electronics.
Trying to understand , please bear me.
How many power adapters do I need ?
I understand that the motor will not be powered directly but through the A4988.
So one power input (most probably 12V) will go into there.
Then, shall I also need a power for Arduino board ? And it will be 5V ?
So 2 power adapters;
One for Arduino : 5V (can I power it with 12V as well ? since Uno has a 9-24V input separate from USB power input)
One for motor (connected through the driver board): 12V
is that correct ?
if yes, I don't need a power convertor. And if I can power Arduino using 12V, maybe 1 power adapter would be also sufficient provided that it has enough current.
I don't need much torque and I will use A4988.
