Currently, I only have Zwave devices and Hue lights running through a Hue hub. My wifi APs are using channels 1 and 6 and I have Hue using channel 25.
I plan to add some ZigBee motion sensors. I'm thinking I should make sure they are not using the same channel as the Hue correct? I was thinking of setting HE to use channel 24 or does it need to be further away from Hue?
Channel 15 worked very well for me. In fact I was on 22 with my WiFi AP on 1 and switched HE to channel 15 and my AP to 11 and my Rssi signal strength improved a good deal for all devices.
Here are all the 2.4GHz APs in my neighborhood. With some ID-10-T running on channel 8 so they step on both channel 6 and channel 11. Luckily for me it's a weak signal.
I found that zigbee was more reliable on channel 15. I also ended up getting a couple of xbees as whatever channel I used I seemed to suffer with problems. Never quite got to the bottom of it as the same setup worked ok on ST. See my story here.
