Having reception issues with WiFi .
I had just moved a ZB plug to the area that had no prior problems.
By problems i meen... poor signal strength and an inability to get on the internet with a hotspot.
No.
Chan 26 is required to use a lower power because of it's adjacency to the RF allocation next to it.
Can you change the channels your WIFI AP's are using?
Based on many others' feedback, use channel 20 or 15 and set wifi to channel 1. Of course you'll want to do a wifi scan to see what's around you.
NetAnalyzer by JiriTechet-free
This - if you can, move Wi-Fi down to 1 or 6, and move Zigbee to 15, 20, or 25, that should help avoid problems. Just generally keep Wi-Fi and Zigbee from sitting on top of each other.
