I like zigbee bulbs, I like color, I like color temperature and I like how color is implemented in the Zigbee spec, and I also like that Zigbee supports group commands.
I know specific manufacturer bulbs can cause routing issues on dense networks, this thread isn't about problem solving that, there are many threads with options for dealing with that problem.
This thread also isn't about which bulbs we support and or why...
This thread also isn't about Z-wave color support, its frustrating and in my opinion hopeless at the spec level for any serious deployments.
It also must be said that this is not a Hubitat engineering high priority, it is a personal quest that I've been trying to poke at for the past 6 months at least...
This thread is about brain storming ideas and control concepts for directly connected zigbee bulbs towards the following goals:
- Unify on off transition times across different brands. (Every manufacturer has a different transition time)
- Uniformly support setLevel(0,xx), ie transition to off.
- Implement default transition time preferences that uniformly work across the entire capability command set.
- Implement command transition time parameters for all color commands (currently only setLevel supports this)
- Implement level prestaging
My end goal for all of this specifically regarding levels and color temperatures is to only use on off in the various lighting automations, then create another app that specifically deals with staging levels and or color temperatures based on Lux, time of day, this would vastly simplify level and color temperature management if those are important to you.
Those are my thoughts, before I get started on some ideas I have on how to implement these, what are your thoughts?
