So, I've read this is a problem kinda. It seems that a flash of power will unpair or unregister a zigbee bulb as it need a song on off on to get them into pairing mode.
The good news is that they are easy to repair to my HE. But man, I have some 20 bulbs and it's a mess. Any ways to fix this issue short of replacing all the bulbs with something else?
I've never had this issue either, though my configuration is slightly different. All of my zigbee bulbs are on a Hue hub and I use the Hue integration to control them from HE. I think it's a better solution but of course everyone's circumstances are different.
You can connect non-Hue bulbs to a Hue hub. Not all of them... but a lot of them. I use Cree bulbs - the cheapest pieces of sh** around. They actually work pretty well.
Never ever had an issue except when I had a power flash. I simply just out the HE in pairing mode and everything was back.. not all of them are cree, but I guess when you get a quick flash of power they just need to be repaired. Either way,
The issue is that they make really bad repeaters/messengers. If you have them in the same network as other zigbee devices (sensors and what not) Your mesh can collapse. This is due to the fact that shitty bulbs like cree use ZLL whereas sensors (contact, temp, humidty etc) use ZHA. The exception to this are Sengled bulbs (they do not repeat) or Zigbee 3.0 bulbs. Even the HE Dev's reccomend putting them on their own hub (such as HUE or another Hubitat) As long as they're not intermixed with other zigbee devices they'll be fine.
It's repeating is far from my issue, I don't have any problems with devices turning on or off. Just had an issue when I lost power and they all lost their knowledge of the hub
Why is hue the end all be all answer. I have no interest in another hub. I'll assume that everyone is saying it's either the bulbs are junk, I'll look for a zwave or another brand, or there is a fault in how HE Handles the bulbs of the choice.
I got the he cause I wanted one hub, telling me to get hue basically is telling me that HE is a dud.
Anywho, no hue. I'll look for another brand that I know will work with the he
