ZEN56 control methods
After many hours of frustration, I'm finally throwing in the towel and seeking help from the community. I purchased four ZEN56's to control four BTF-Lighting RGBW LED strips. I've tried using the Rule Machine, Scenes, and testing controlling the ZEN56's using the individual device pages for testing. The results have been disappointing because these devices seem to overwhelm the system when color changes are executed. Not always, seems random. Also, when a simple color changes are is executed, multiple color change commands are sent with all sorts of random colors. Or, it won't respond at all. Has anyone had success with these devices and what methods were used to control them?
[resolved - see below]
My opinion here:
Z-wave is not the best protocol for color change devices. It seems to be more crude and prone to issues in general than Zigbee or Wifi protocols, and even Matter for that matter. (pun intended).
It isn't that it can't work, but I don't think that rapid color change and RGB light shows were ever intended by the Z-wave designers. If you are just turning on a blue light at dawn, and a red light at dusk, then Z-wave is OK.
This is also my opinion, but fancy scenes and fast RGB color changes might even overwhelm the most powerful C8Pro if you aren't careful about how you meter commands. I think that if you are into that sort of stuff, then something like Hue, Govee, and other dedicated RGB systems (WLED or Pixelblaze and others) are a much better choice.
I did Hue for my all-day indoor color scenes, and it really reduced the Hubitat hub load, and it was much easier to implement with their assortment of color scenes. I also have Govee for outdoor lighting, and it also has a wild variety of scenes far beyond what a simple LED controller, Zooz or otherwise, can even think of doing.
Not doing any rapid color changes. I'm just setting one of three "tinted/warm" light colors and level hours apart. One action that seems to consistently lock up or severely slow down the system (resulting in a permanent hourglass symbol on the device mode icon) is if I try to turn off the RGB device from its dashboard button or the device page. Could it have something to do with the fact that it operates as a parent (RGB) channel and a child (white LED)?
Looks like it may be an issue with one of the ZEN56's not having joined properly, likely due to an error on my part doing the smart start. When that one was excluded, the others seem to be operating properly using the device command pages. I'll post when done determining best results in creating a control dashboard. Zooz support has been very helpful in troubleshooting. These dimmers seem to work well with the BTF-Lighting RGBW LED strips.
Final resolution on control problems was removal the one of four ZEN56'S that kept flooding the ZWave network. The three remaining are responding perfectly using a legacy dashboard with the RGB side of the controllers added as color bulb tiles and the child white LED added as a dimmer.
So each color strip is managed with two dashboard tiles. The color is set with sliders or discrete numbers on the pop-up RGB window that tile generates. The brightness is set with the white LED slider tile.
The Easy dashboard seems to only allow creation of two dimmers for this device which does not allow you to alter color. I mostly use legacy anyway so did not explore further.
Will post results following setting up scenes and groups.
Thanks to Zooz and SmartestHouse for quick resolution and replacement of troubled unit.
Got everything working great. Using Rule Machine to setup scenes. Set all ZEN56's to zero delay for dimming transition and using mostly 3-second delays between commands. Setting dimming transition times (I picked 7 seconds) in the action setting of the rule. There may be simpler ways to generate scenes with these but I wanted to be able to tweak each of the four light strips based on the colors needed to match due to proximity to ceiling and strip length differences.
