ZEN34 to ON/OFF and DIM (GL-C-009P)
Hi folks,
I created 2 [Simple Automation Rules] to Turn ON/OFF my Deck LED buy ZEEN34 + GL-C-009P.
My questions: Is it possible to use only ONE RULE to ON/OFF and to DIM the LED when I hold the ZEN34?
Not with Simple Automation Rules, but you could use the Button Controller app to get it all in one if you want (each button action will technically be a separate "grandchild" app, but in the editor, you can get to them all in one place).
In Button Controller, you can also use the "Start raising/lowering dimmer level" (and the "Stop changing...") actions to do the smooth dimming you want in response to hold and release, respectively, of the button paddles.
Thank you very much works perfect!
