Zen32 with hub mesh
I have a zooz zen32 switch included with the hub in my barn. On the main hub in my house, i can see it on devices and include it on dashboards but it on and off do not respond. They work fine when i go into the barn hub. Is there an advanced setting or something i need to add to get it to work through hub mesh?
No, all commands, events, etc. should be passed through Hub Mesh once you share it from one hub and add it to the other (which it sounds like you have at this point). You may want to troubleshoot either general Hub Mesh problems (do you have any other Hub Mesh devices, and do they work OK? If you're using UDP, have you tried changing both hubs to TCP and seeing if that helps?) or a device-specific issue (any "ghosts" or Z-Wave problems on the barn hub? is it just coincidence that Hub Mesh is when it doesn't work because that's the only time you notice?).
You were right, it was a general hub mesh problem. The ip address on my house hub had jumped to a strange number.
