@mike.maxwell is there any major differences between the Zen Thermostat driver and the Generic Zigbee Thermostat driver? Usually at least once a day now for some reason my A/C shuts off mid cycle even though it's still calling for cooling Thereby it has to wait the 5 minute short cycle protection and comes right back on. I've tracked it down to for some reason I'm getting a battery report of -200% (I guess from the driver?) right when the A/C gets shut off. The batteries are less than a month old.
I was going to try switching to the Generic Zigbee Thermostat driver and see if the problem still occurs but I wanted to check with you first to make sure there isn't any major differences between the 2 drivers?
Here is the log of it happening then the 5 minute delay and the unit comes back on.
