Zemismart Zigbee 1/2/3/4 gang light switches
This is from the parent device is found in past logs.
:4092022-06-05 07:37:40.232 pminfo3 gang tuya switch Creatung device 409-02
dev:4092022-06-05 07:37:40.226 pminfo3 gang tuya switch Child device 409-01 already exists (3 gang tuya switch EP01)
dev:4092022-06-05 07:37:40.204 pmdebug3 gang tuya switch Parent createChildDevices
dev:4092022-06-05 07:37:40.201 pmdebug3 gang tuya switch model: TS0013 buttons: 3
dev:4092022-06-05 07:37:40.142 pmdebug3 gang tuya switch Parent deleteChildren
dev:4092022-06-05 07:37:40.139 pmdebug3 gang tuya switch Parent setupChildDevices
dev:4092022-06-05 07:37:39.946 pminfo3 gang tuya switch InitializeVars()... fullInit = true
dev:4092022-06-05 07:37:39.938 pmdebug3 gang tuya switch Initializing...
dev:4092022-06-05 07:12:47.828 pminfo3 gang tuya switch Creatung device 409-01
dev:4092022-06-05 07:12:47.811 pmdebug3 gang tuya switch Parent createChildDevices
dev:4092022-06-05 07:12:47.810 pmdebug3 gang tuya switch model: TS0013 buttons: 3
dev:4092022-06-05 07:12:47.799 pmdebug3 gang tuya switch Parent deleteChildren
dev:4092022-06-05 07:12:47.798 pmdebug3 gang tuya switch Parent setupChildDevices
dev:4092022-06-05 07:12:47.785 pminfo3 gang tuya switch InitializeVars()... fullInit = true
dev:4092022-06-05 07:12:47.784 pmdebug3 gang tuya switch Initializing...
dev:4092022-06-05 07:12:13.841 pmdebugZemismart ZigBee Wall Switch Multi-Gang UNPROCESSED EP: 01 cluster: 0000 attrId: FFDF
dev:4092022-06-05 07:12:13.838 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C701000076DFFF423714662F2A1315662F2A12DB6E2F2A12A8742F2A12E67B2F2A12857D2F2A124F802F2A1290812F2A1207AD2F2A1275AD2F2A1283AD2F2A16, dni:26C7, endpoint:01, cluster:0000, size:76, attrId:FFDF, encoding:42, command:0A, value:f/*f/*Ûn/*¨t/*æ{/*…}/*O€/*/*a­/*u­/*ƒ­/*, clusterInt:0, attrInt:65503]
dev:4092022-06-05 07:12:13.582 pmdebugZemismart ZigBee Wall Switch Multi-Gang UNPROCESSED EP: 01 cluster: 0000 attrId: 0001
dev:4092022-06-05 07:12:13.579 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C70100001801002043E2FF2033E4FF2000, dni:26C7, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1, additionalAttrs:[[value:33, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:4092022-06-05 07:12:13.454 pmwarnZemismart ZigBee Wall Switch Multi-Gang Child device 409-03 not found. Initialise parent device first
dev:4092022-06-05 07:12:13.451 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C70300061C0000100001402100000240210000, dni:26C7, endpoint:03, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]]]
dev:4092022-06-05 07:12:13.325 pmwarnZemismart ZigBee Wall Switch Multi-Gang Child device 409-02 not found. Initialise parent device first
dev:4092022-06-05 07:12:13.322 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C70200061C0000100001402100000240210000, dni:26C7, endpoint:02, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]]]
dev:4092022-06-05 07:12:13.196 pmdebugZemismart ZigBee Wall Switch Multi-Gang UNPROCESSED EP: 01 cluster: E001 attrId: D030
dev:4092022-06-05 07:12:13.194 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C701E0010830D03000, dni:26C7, endpoint:01, cluster:E001, size:08, attrId:D030, encoding:30, command:0A, value:00, clusterInt:57345, attrInt:53296]
dev:4092022-06-05 07:12:13.085 pmwarnZemismart ZigBee Wall Switch Multi-Gang Child device 409-01 not found. Initialise parent device first
dev:4092022-06-05 07:12:13.081 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C701000624000010000140210000024021000002803002, dni:26C7, endpoint:01, cluster:0006, size:24, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:02, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770]]]
dev:4092022-06-05 07:12:12.403 pmdebugZemismart ZigBee Wall Switch Multi-Gang UNPROCESSED EP: 01 cluster: E000 attrId: D003
dev:4092022-06-05 07:12:12.401 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C701E0002003D0420C414141414167414142414141, dni:26C7, endpoint:01, cluster:E000, size:20, attrId:D003, encoding:42, command:0A, value:AAAAAgAABAAA, clusterInt:57344, attrInt:53251]
dev:4092022-06-05 07:12:10.330 pmwarnZemismart ZigBee Wall Switch Multi-Gang Child device 409-03 not found. Initialise parent device first
dev:4092022-06-05 07:12:10.328 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C70300060800001000, dni:26C7, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:4092022-06-05 07:12:10.203 pmwarnZemismart ZigBee Wall Switch Multi-Gang Child device 409-02 not found. Initialise parent device first
dev:4092022-06-05 07:12:10.200 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C70200060800001000, dni:26C7, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:4092022-06-05 07:12:10.077 pmwarnZemismart ZigBee Wall Switch Multi-Gang Child device 409-01 not found. Initialise parent device first
dev:4092022-06-05 07:12:10.075 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C70100060800001000, dni:26C7, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:4092022-06-05 07:12:07.913 pmdebugZemismart ZigBee Wall Switch Multi-Gang UNPROCESSED EP: 01 cluster: 0000 attrId: FFDF
dev:4092022-06-05 07:12:07.911 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C701000076DFFF423714662F2A1315662F2A12DB6E2F2A12A8742F2A12E67B2F2A12857D2F2A124F802F2A1290812F2A1207AD2F2A1275AD2F2A1283AD2F2A16, dni:26C7, endpoint:01, cluster:0000, size:76, attrId:FFDF, encoding:42, command:0A, value:f/*f/*Ûn/*¨t/*æ{/*…}/*O€/*/*a­/*u­/*ƒ­/*, clusterInt:0, attrInt:65503]
dev:4092022-06-05 07:12:07.274 pmdebugZemismart ZigBee Wall Switch Multi-Gang UNPROCESSED EP: 01 cluster: 0000 attrId: 0001
dev:4092022-06-05 07:12:07.270 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C70100001801002043E2FF2033E4FF2000, dni:26C7, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:43, clusterInt:0, attrInt:1, additionalAttrs:[[value:33, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:4092022-06-05 07:12:04.626 pmdebugZemismart ZigBee Wall Switch Multi-Gang UNPROCESSED EP: null cluster: null attrId: null
dev:4092022-06-05 07:12:04.623 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:catchall: 0104 0006 01 01 0040 00 26C7 00 00 0000 07 01 00000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:26C7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00, 00, 00, 00]]
dev:4092022-06-05 07:12:02.577 pmdebugZemismart ZigBee Wall Switch Multi-Gang UNPROCESSED EP: null cluster: null attrId: null
dev:4092022-06-05 07:12:02.574 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:catchall: 0000 8021 00 00 0040 00 26C7 00 00 0000 00 00 7C00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:26C7, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[7C, 00]]
dev:4092022-06-05 07:12:02.509 pmwarnZemismart ZigBee Wall Switch Multi-Gang Child device 409-03 not found. Initialise parent device first
dev:4092022-06-05 07:12:02.507 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C70300060A00001000, dni:26C7, endpoint:03, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:4092022-06-05 07:12:02.483 pmwarnZemismart ZigBee Wall Switch Multi-Gang Child device 409-02 not found. Initialise parent device first
dev:4092022-06-05 07:12:02.480 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C70200060A00001000, dni:26C7, endpoint:02, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:4092022-06-05 07:12:02.474 pmwarnZemismart ZigBee Wall Switch Multi-Gang Child device 409-01 not found. Initialise parent device first
dev:4092022-06-05 07:12:02.468 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C70100060A00001000, dni:26C7, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:4092022-06-05 07:12:02.245 pmdebugZemismart ZigBee Wall Switch Multi-Gang UNPROCESSED EP: 01 cluster: 0000 attrId: 0004
dev:4092022-06-05 07:12:02.240 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:26C701000068040042105F545A333030305F797067726938797A0000002003010000204305000042065453303031330700003003FEFF003000, dni:26C7, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZ3000_ypgri8yz, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:43, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0013, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:4092022-06-05 07:12:02.233 pminfoZemismart ZigBee Wall Switch Multi-Gang InitializeVars()... fullInit = false
dev:4092022-06-05 07:12:02.227 pmdebugZemismart ZigBee Wall Switch Multi-Gang updating the settings from the current driver version null to the new version 0.2.7 2022/06/05 12:15 AM
dev:4092022-06-05 07:12:01.991 pmdebugZemismart ZigBee Wall Switch Multi-Gang sendZigbeeCommands received : [he raw 0x26C7 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he rattr 0x26C7 0xFF 0x0006 0x0, zdo bind 0x26C7 0x01 0x01 6 {A4C138F0086C122E} {}, delay 2000, he cr 0x26C7 0x01 6 0 16 0 600 {}, delay 2000]
dev:4092022-06-05 07:12:01.984 pmdebugZemismart ZigBee Wall Switch Multi-Gang refreshing
dev:4092022-06-05 07:12:01.979 pmdebugZemismart ZigBee Wall Switch Multi-Gang configure()..
dev:4092022-06-05 07:12:01.973 pmdebugZemismart ZigBee Wall Switch Multi-Gang Parent installed
