Zemismart Smart Energy Sensor
Hello, can anyone help me with the settings and driver for the zemismart SPM01 power meter?
Have you tried the Tuya Zigbee Metering Plug driver?
Install the driver first, then pair the device again to the HE hub.
If this doesn’t work, post the device model and manufacturer as seen on the device details section.
Thank you for your support. When I pair it, it installs the driver "Tuya Zigbee Contact Sensor++ w/ healthStatus" then I change it to "Tuya zigbee metering plug, but it's not working
Current States
• healthStatus: online
• switch: off
• power: 6553.3
• energyCost: 0.0
• energy: 0.0
• energyDuration: 0
• hourlyEnergy: 0
State Variables
• deviceProfile : UNKNOWN
• lastTx: {"battCfgOK":true,"cfgTimer":0}
• lastRx: {"battCfg":"-1,-1,-1"}
• isDigital: false
• stats: {"rejoins":0,"rxCtr":331,"txCtr":1}
• driverVersion: 1.9.12024/01/24 10:52 AM
• lastSwitchState: off
• notPresentCounter : 0
• switchDebouncing: true
:black_circle: comment: works with Tuya TS0601, TS0203, BlitzWolf, Sonoff
• configState: 0
Device Details
Create Time
2024-03-02 08:50:43 AM UTC
Last Update Time
2024-03-02 08:54:09 AM UTC
Last Activity At
Controller Type
ZGB
• endpointId: 01
• application: 44
Data
• manufacturer: _T ZE200_qhlxve78
• model: TS0601
In Use By
This device is too new. The only reference that I could find for it in GitHub is from just two weeks ago - "not supported yet"
No new info for this device yet.
If you enable the debug logs in the 'Tuya metering plug' driver, do you see anything in the live logs?
I have one with one phase and three phase. None is working, unfortunately, as Claudio said.
It's working on Z2M right now.
This is the I found on GitHub about it:
It works in ZHA with a quirk. I had to revert agomezfabian's "fix" to divide voltage by 10 as it was reporting 123V as 12.3V. There could be a firmware difference.
I'm unable to post a link, so look at zigpy/zha-device-handlers issue 3045 on GitHub.
I'd much rather have this working directly on Hubitat though.
I tried the previously posted SPM01 quirk but it's for "_TZE200_bcusnqt8", which differs quite a bit from my "_TZE200_qhlxve78".
All the needed info for this device is available now. Please wait a few more days, and I will add it to the Tuya driver, it was on top of the TODO list...
The last missing piece of information that I needed for the SP01 was shared on GitHub yesterday, thanks to user [dpetrini].
Please update the driver to ver. 1.9.7 2024-07-03 - (dev.branch) W.I.P. - added SPM01 TS0601 _TZE200_qhlxve78
If this doesn't work, I will need one minute of Debug logs - please select/copy/paste as a text, hidden in a Summary section (use the forum editor Cog wheel tool).
@vctgomes @claudiofdtavares1979 please try the latest version with your devices as well.
Driver TimeStamp '2024/07/03 8:13 AM'
I wasn't able to get any stats to come through. Here's the log as requested.
Summary
dev:9422024-07-03 18:44:23.675infoHVAC Fan Not Found (0x8b) Read Reporting Configuration Response for cluster:0006 attribute:0000, data=[86, 00, 00, 00] (Status: Failure)
dev:9422024-07-03 18:44:23.672debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 2AAB 00 00 0000 09 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2AAB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:09, direction:01, data:[86, 00, 00, 00]]
dev:9422024-07-03 18:44:23.667debugHVAC Fan parse: description is catchall: 0104 0006 01 01 0040 00 2AAB 00 00 0000 09 01 86000000
dev:9422024-07-03 18:44:23.430infoHVAC Fan Received Configure Reporting Response for cluster:0006 , data=[86, 00, 00, 00] (Status: Failure)
dev:9422024-07-03 18:44:23.427debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 2AAB 00 00 0000 07 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2AAB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 00, 00]]
dev:9422024-07-03 18:44:23.423debugHVAC Fan parse: description is catchall: 0104 0006 01 01 0040 00 2AAB 00 00 0000 07 01 86000000
dev:9422024-07-03 18:44:23.170infoHVAC Fan Received bind response, data=[75, 00] (Sequence Number:75, Status: Success)
dev:9422024-07-03 18:44:23.167debugHVAC Fan parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 2AAB 00 00 0000 00 00 7500, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2AAB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[75, 00]]
dev:9422024-07-03 18:44:23.157debugHVAC Fan parse: description is catchall: 0000 8021 00 00 0040 00 2AAB 00 00 0000 00 00 7500
dev:9422024-07-03 18:44:23.113infoHVAC Fan Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:9422024-07-03 18:44:23.110debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 2AAB 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2AAB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:9422024-07-03 18:44:23.106debugHVAC Fan parse: description is catchall: 0104 0000 01 01 0040 00 2AAB 00 00 0000 04 01 00
dev:9422024-07-03 18:44:23.005debugHVAC Fan attribute report: cluster=0000 attrId=0005 value=TS0601 status=null data=null
dev:9422024-07-03 18:44:23.003debugHVAC Fan attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9422024-07-03 18:44:23.002debugHVAC Fan attribute report: cluster=0000 attrId=0000 value=03 status=null data=null
dev:9422024-07-03 18:44:23.000debugHVAC Fan attribute report: cluster=0000 attrId=0004 value=_TZE200_qhlxve78 status=null data=null
dev:9422024-07-03 18:44:22.996debugHVAC Fan parse: Desc Map: [raw:2AAB01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni:2AAB, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_qhlxve78, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:9422024-07-03 18:44:22.989warnHVAC Fan parse: exception caught while trying to getEvent... description: read attr - raw: 2AAB01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 2AAB, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9422024-07-03 18:44:22.955debugHVAC Fan parse: description is read attr - raw: 2AAB01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 2AAB, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9422024-07-03 18:44:22.891traceHVAC Fan sendZigbeeCommands : [he raw 0x2AAB 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x2AAB 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0x2AAB 0x01 0x01 0x0006 {B43522FFFE75D4DE} {}, delay 251, he cr 0x2AAB 0x01 6 0 16 0 900 {}, delay 251, he raw 0x2AAB 1 0x01 0x0006 {10 00 08 00 0000}, delay 251]
dev:9422024-07-03 18:44:22.889infoHVAC Fan Automatic reporting configuration is disabled and will be skipped!
dev:9422024-07-03 18:44:22.886debugHVAC Fan configureReporting operation=Write, measurement=Switch, minTime=0, maxTime=900, delta=0 )
dev:9422024-07-03 18:44:22.870debugHVAC Fan ep=01 isF2=false
dev:9422024-07-03 18:44:22.803infoHVAC Fan configure()..
dev:9422024-07-03 18:44:22.801infoHVAC Fan configuring the switch and energy reporting..
dev:9422024-07-03 18:44:22.800infoHVAC Fan Auto polling is disabled
dev:9422024-07-03 18:44:22.789infoHVAC Fan Debug logging will be automatically switched off after 24 hours
dev:9422024-07-03 18:44:22.731infoHVAC Fan Debug logging is true Description text logging is true
dev:9422024-07-03 18:44:22.730infoHVAC Fan Updating HVAC Fan (Tuya Zigbee Metering Plug) model TS0601
dev:9422024-07-03 18:43:46.354debugHVAC Fan attribute report: cluster=0000 attrId=FFE4 value=00 status=null data=null
dev:9422024-07-03 18:43:46.353debugHVAC Fan attribute report: cluster=0000 attrId=FFE2 value=1F status=null data=null
dev:9422024-07-03 18:43:46.351debugHVAC Fan attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9422024-07-03 18:43:46.348debugHVAC Fan parse: Desc Map: [raw:2AAB0100001801002044E2FF201FE4FF2000, dni:2AAB, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:44, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:9422024-07-03 18:43:46.342debugHVAC Fan Cluster 0000 Tuya specific attrId FFE4 value 00)
dev:9422024-07-03 18:43:46.340debugHVAC Fan Cluster 0000 Tuya specific attrId FFE2 value 1F)
dev:9422024-07-03 18:43:46.334debugHVAC Fan parse: description is read attr - raw: 2AAB0100001801002044E2FF201FE4FF2000, dni: 2AAB, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF201FE4FF2000
dev:9422024-07-03 18:42:28.622infoHVAC Fan Initialization finished
dev:9422024-07-03 18:42:28.621infoHVAC Fan energyPollingSupported = false
dev:9422024-07-03 18:42:28.619infoHVAC Fan powerPollingSupported = false
dev:9422024-07-03 18:42:28.617infoHVAC Fan currentPollingSupported = true
dev:9422024-07-03 18:42:28.616infoHVAC Fan voltagePollingSupported = true
dev:9422024-07-03 18:42:28.614infoHVAC Fan switchPollingSupported = false
dev:9422024-07-03 18:42:28.574infoHVAC Fan Not Found (0x8b) Read Reporting Configuration Response for cluster:0006 attribute:0000, data=[86, 00, 00, 00] (Status: Failure)
dev:9422024-07-03 18:42:28.570debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 2AAB 00 00 0000 09 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2AAB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:09, direction:01, data:[86, 00, 00, 00]]
dev:9422024-07-03 18:42:28.566debugHVAC Fan parse: description is catchall: 0104 0006 01 01 0040 00 2AAB 00 00 0000 09 01 86000000
dev:9422024-07-03 18:42:28.337infoHVAC Fan Received Configure Reporting Response for cluster:0006 , data=[86, 00, 00, 00] (Status: Failure)
dev:9422024-07-03 18:42:28.334debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 2AAB 00 00 0000 07 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2AAB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 00, 00]]
dev:9422024-07-03 18:42:28.329debugHVAC Fan parse: description is catchall: 0104 0006 01 01 0040 00 2AAB 00 00 0000 07 01 86000000
dev:9422024-07-03 18:42:28.104infoHVAC Fan Received bind response, data=[70, 00] (Sequence Number:70, Status: Success)
dev:9422024-07-03 18:42:28.097debugHVAC Fan parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 2AAB 00 00 0000 00 00 7000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2AAB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[70, 00]]
dev:9422024-07-03 18:42:28.093debugHVAC Fan parse: description is catchall: 0000 8021 00 00 0040 00 2AAB 00 00 0000 00 00 7000
dev:9422024-07-03 18:42:28.078infoHVAC Fan Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:9422024-07-03 18:42:28.073debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 2AAB 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2AAB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:9422024-07-03 18:42:28.066debugHVAC Fan parse: description is catchall: 0104 0000 01 01 0040 00 2AAB 00 00 0000 04 01 00
dev:9422024-07-03 18:42:27.949debugHVAC Fan attribute report: cluster=0000 attrId=0005 value=TS0601 status=null data=null
dev:9422024-07-03 18:42:27.946debugHVAC Fan attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9422024-07-03 18:42:27.944debugHVAC Fan attribute report: cluster=0000 attrId=0000 value=03 status=null data=null
dev:9422024-07-03 18:42:27.942debugHVAC Fan attribute report: cluster=0000 attrId=0004 value=_TZE200_qhlxve78 status=null data=null
dev:9422024-07-03 18:42:27.918debugHVAC Fan parse: Desc Map: [raw:2AAB01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni:2AAB, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_qhlxve78, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:9422024-07-03 18:42:27.910warnHVAC Fan parse: exception caught while trying to getEvent... description: read attr - raw: 2AAB01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 2AAB, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9422024-07-03 18:42:27.878debugHVAC Fan parse: description is read attr - raw: 2AAB01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 2AAB, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9422024-07-03 18:42:27.784traceHVAC Fan sendZigbeeCommands : [he raw 0x2AAB 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x2AAB 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0x2AAB 0x01 0x01 0x0006 {B43522FFFE75D4DE} {}, delay 251, he cr 0x2AAB 0x01 6 0 16 0 900 {}, delay 251, he raw 0x2AAB 1 0x01 0x0006 {10 00 08 00 0000}, delay 251]
dev:9422024-07-03 18:42:27.782infoHVAC Fan Automatic reporting configuration is disabled and will be skipped!
dev:9422024-07-03 18:42:27.777debugHVAC Fan configureReporting operation=Write, measurement=Switch, minTime=0, maxTime=900, delta=0 )
dev:9422024-07-03 18:42:27.751debugHVAC Fan ep=01 isF2=false
dev:9422024-07-03 18:42:27.661infoHVAC Fan configure()..
dev:9422024-07-03 18:42:27.656infoHVAC Fan configuring the switch and energy reporting..
dev:9422024-07-03 18:42:27.652infoHVAC Fan Auto polling is disabled
dev:9422024-07-03 18:42:27.626infoHVAC Fan Debug logging will be automatically switched off after 24 hours
dev:9422024-07-03 18:42:27.586infoHVAC Fan Debug logging is true Description text logging is true
dev:9422024-07-03 18:42:27.583infoHVAC Fan Updating HVAC Fan (Tuya Zigbee Metering Plug) model TS0601
dev:9422024-07-03 18:42:19.112warnHVAC Fan Switch polling is not supported -> Switch polling will be disabled.
dev:9422024-07-03 18:42:19.109debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 2AAB 00 00 0000 01 01 000086, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2AAB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 00, 86]]
dev:9422024-07-03 18:42:19.105debugHVAC Fan parse: description is catchall: 0104 0006 01 01 0040 00 2AAB 00 00 0000 01 01 000086
dev:9422024-07-03 18:42:18.916warnHVAC Fan Energy measurement is not supported! -> Energy polling will be disabled.
dev:9422024-07-03 18:42:18.911debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0702 01 01 0040 00 2AAB 00 00 0000 01 01 000086, profileId:0104, clusterId:0702, clusterInt:1794, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2AAB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 00, 86]]
dev:9422024-07-03 18:42:18.884debugHVAC Fan parse: description is catchall: 0104 0702 01 01 0040 00 2AAB 00 00 0000 01 01 000086
dev:9422024-07-03 18:42:18.689warnHVAC Fan Power polling is not supported! -> Power polling will be disabled.
dev:9422024-07-03 18:42:18.685debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0B04 01 01 0040 00 2AAB 00 00 0000 01 01 0B0586050586080586, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2AAB, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[0B, 05, 86, 05, 05, 86, 08, 05, 86]]
dev:9422024-07-03 18:42:18.681debugHVAC Fan parse: description is catchall: 0104 0B04 01 01 0040 00 2AAB 00 00 0000 01 01 0B0586050586080586
dev:9422024-07-03 18:42:18.589traceHVAC Fan sendZigbeeCommands : [he raw 0x2AAB 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200, he raw 0x2AAB 1 0x01 0x0702 {10 00 00 00 00}, delay 200, he rattr 0x2AAB 0x01 6 0 {}, delay 2000]
dev:9422024-07-03 18:42:18.537debugHVAC Fan polling all 0x0B04 attributes
dev:9422024-07-03 18:42:18.535debugHVAC Fan polling.. refreshAll is true
dev:9422024-07-03 18:42:18.532infoHVAC Fan refresh()...
And state:
Summary
State Variables
rxCounter : 14
energyPollingSupported : false
lastResetDate : 2024-07-03 18:42:17.509
lastEnergyRaw : 0.0
isDigital : true
rejoinCounter : 0
lastSwitchState : unknown
txCounter : 5
isRefreshRequest : false
lastEnergyCost : 0.0
lastHourlyEnergy : 0.0
switchPollingSupported : false
powerPollingSupported : false
lastResetEnergy : 0.0
voltagePollingSupported : true
driverVersion : 1.9.7 2024/07/03 8:13 AM
switchDebouncing : false
currentPollingSupported : true
model : TS0601
destinationEP : 01
Thanks! :slight_smile:
These devices will not respond to any Refeesh and Configure commands (I should skip sending any zigbee commands for this device in the next version). The energy monitor should send automatically power usage updates every 10 seconds or so..
Did you have the driver already installed when you paired the device for a first time, or you installed and assigned the driver later?
Pair the device again to your hub. You should see debug logs coming without clicking on any buttons in the driver web page.
If re-pairing doesn’t work, delete the device (from the ‘REMOVE DEVICE’ red button) and pair it again as a new one. This driver must be selected automatically during the pairing.
That's good to know. I had two versions of the driver installed and it initially used the older unsupported version. I've re-paired with only the new beta driver available.
Here's an updated log:
Summary
dev:9432024-07-04 07:23:21.115warnHVAC Fan Unprocessed global command: cluster=EF00 command=11 attrId=null value=null data=[00, 07, D1]
dev:9432024-07-04 07:23:21.112debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 5081 01 00 0000 11 01 0007D1, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[00, 07, D1]]
dev:9432024-07-04 07:23:21.108debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 5081 01 00 0000 11 01 0007D1
dev:9432024-07-04 07:23:09.715infoHVAC Fan Not Found (0x8b) Read Reporting Configuration Response for cluster:0006 attribute:0000, data=[86, 00, 00, 00] (Status: Failure)
dev:9432024-07-04 07:23:09.706debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 5081 00 00 0000 09 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:09, direction:01, data:[86, 00, 00, 00]]
dev:9432024-07-04 07:23:09.696debugHVAC Fan parse: description is catchall: 0104 0006 01 01 0040 00 5081 00 00 0000 09 01 86000000
dev:9432024-07-04 07:23:09.594infoHVAC Fan Initialization finished
dev:9432024-07-04 07:23:09.592infoHVAC Fan energyPollingSupported = false
dev:9432024-07-04 07:23:09.591infoHVAC Fan powerPollingSupported = false
dev:9432024-07-04 07:23:09.589infoHVAC Fan currentPollingSupported = true
dev:9432024-07-04 07:23:09.585infoHVAC Fan voltagePollingSupported = true
dev:9432024-07-04 07:23:09.583infoHVAC Fan switchPollingSupported = false
dev:9432024-07-04 07:23:09.397infoHVAC Fan Received Configure Reporting Response for cluster:0006 , data=[86, 00, 00, 00] (Status: Failure)
dev:9432024-07-04 07:23:09.394debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 5081 00 00 0000 07 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 00, 00]]
dev:9432024-07-04 07:23:09.390debugHVAC Fan parse: description is catchall: 0104 0006 01 01 0040 00 5081 00 00 0000 07 01 86000000
dev:9432024-07-04 07:23:09.143infoHVAC Fan Received bind response, data=[36, 00] (Sequence Number:36, Status: Success)
dev:9432024-07-04 07:23:09.140debugHVAC Fan parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 5081 00 00 0000 00 00 3600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[36, 00]]
dev:9432024-07-04 07:23:09.136debugHVAC Fan parse: description is catchall: 0000 8021 00 00 0040 00 5081 00 00 0000 00 00 3600
dev:9432024-07-04 07:23:09.114infoHVAC Fan Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:9432024-07-04 07:23:09.111debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 5081 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:9432024-07-04 07:23:09.107debugHVAC Fan parse: description is catchall: 0104 0000 01 01 0040 00 5081 00 00 0000 04 01 00
dev:9432024-07-04 07:23:09.097debugHVAC Fan attribute report: cluster=0000 attrId=0005 value=TS0601 status=null data=null
dev:9432024-07-04 07:23:09.096debugHVAC Fan attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9432024-07-04 07:23:09.094debugHVAC Fan attribute report: cluster=0000 attrId=0000 value=03 status=null data=null
dev:9432024-07-04 07:23:09.093debugHVAC Fan attribute report: cluster=0000 attrId=0004 value=_TZE200_qhlxve78 status=null data=null
dev:9432024-07-04 07:23:09.088debugHVAC Fan parse: Desc Map: [raw:508101000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni:5081, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_qhlxve78, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:9432024-07-04 07:23:09.081warnHVAC Fan parse: exception caught while trying to getEvent... description: read attr - raw: 508101000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 5081, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9432024-07-04 07:23:08.900debugHVAC Fan parse: description is read attr - raw: 508101000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 5081, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9432024-07-04 07:23:08.811traceHVAC Fan sendZigbeeCommands : [he raw 0x5081 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x5081 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0x5081 0x01 0x01 0x0006 {B43522FFFE75D4DE} {}, delay 251, he cr 0x5081 0x01 6 0 16 0 900 {}, delay 251, he raw 0x5081 1 0x01 0x0006 {10 00 08 00 0000}, delay 251]
dev:9432024-07-04 07:23:08.808infoHVAC Fan Automatic reporting configuration is disabled and will be skipped!
dev:9432024-07-04 07:23:08.732debugHVAC Fan configureReporting operation=Write, measurement=Switch, minTime=0, maxTime=900, delta=0 )
dev:9432024-07-04 07:23:08.712debugHVAC Fan ep=01 isF2=false
dev:9432024-07-04 07:23:08.638infoHVAC Fan configure()..
dev:9432024-07-04 07:23:08.636infoHVAC Fan configuring the switch and energy reporting..
dev:9432024-07-04 07:23:08.634infoHVAC Fan Auto polling is disabled
dev:9432024-07-04 07:23:08.623infoHVAC Fan Debug logging will be automatically switched off after 24 hours
dev:9432024-07-04 07:23:08.582infoHVAC Fan Debug logging is true Description text logging is true
dev:9432024-07-04 07:23:08.580infoHVAC Fan Updating HVAC Fan (Tuya Zigbee Metering Plug) model TS0601
dev:9432024-07-04 07:23:04.140debugHVAC Fan Cluster 0000 Tuya specific attrId FFDF value )
dev:9432024-07-04 07:23:04.135debugHVAC Fan parse: description is read attr - raw: 508101000026DFFF420F000000000500000000120000000012, dni: 5081, endpoint: 01, cluster: 0000, size: 26, attrId: FFDF, encoding: 42, command: 0A, value: 0F000000000500000000120000000012
dev:9432024-07-04 07:23:03.905debugHVAC Fan attribute report: cluster=0000 attrId=FFE4 value=00 status=null data=null
dev:9432024-07-04 07:23:03.903debugHVAC Fan attribute report: cluster=0000 attrId=FFE2 value=1F status=null data=null
dev:9432024-07-04 07:23:03.901debugHVAC Fan attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9432024-07-04 07:23:03.898debugHVAC Fan parse: Desc Map: [raw:50810100001801002044E2FF201FE4FF2000, dni:5081, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:44, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:9432024-07-04 07:23:03.892debugHVAC Fan Cluster 0000 Tuya specific attrId FFE4 value 00)
dev:9432024-07-04 07:23:03.890debugHVAC Fan Cluster 0000 Tuya specific attrId FFE2 value 1F)
dev:9432024-07-04 07:23:03.879debugHVAC Fan parse: description is read attr - raw: 50810100001801002044E2FF201FE4FF2000, dni: 5081, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF201FE4FF2000
dev:9432024-07-04 07:23:01.375debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 5081 00 00 0000 0B 01 2400, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[24, 00]]
dev:9432024-07-04 07:23:01.370debugTuya Zigbee Metering Plug parse: description is catchall: 0104 EF00 01 01 0040 00 5081 00 00 0000 0B 01 2400
dev:9432024-07-04 07:23:01.290debugTuya Zigbee Metering Plug sending time data : [he cmd 0x5081 0x01 0xEF00 0x24 {00086686942566864DD5}, delay 2000]
dev:9432024-07-04 07:23:01.289debugTuya Zigbee Metering Plug now is: 1720095781288
dev:9432024-07-04 07:23:01.282debugTuya Zigbee Metering Plug time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 5081 01 00 0000 24 01 0005, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 05]]
dev:9432024-07-04 07:23:01.281debugTuya Zigbee Metering Plug Tuya time sync
dev:9432024-07-04 07:23:01.278debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 5081 01 00 0000 24 01 0005, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 05]]
dev:9432024-07-04 07:23:01.274debugTuya Zigbee Metering Plug parse: description is catchall: 0104 EF00 01 01 0040 00 5081 01 00 0000 24 01 0005
dev:9432024-07-04 07:23:00.123warnTuya Zigbee Metering Plug Switch polling is not supported -> Switch polling will be disabled.
dev:9432024-07-04 07:23:00.119debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 5081 00 00 0000 01 01 000086, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 00, 86]]
dev:9432024-07-04 07:23:00.114debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0006 01 01 0040 00 5081 00 00 0000 01 01 000086
dev:9432024-07-04 07:22:59.881warnTuya Zigbee Metering Plug Energy measurement is not supported! -> Energy polling will be disabled.
dev:9432024-07-04 07:22:59.877debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0702 01 01 0040 00 5081 00 00 0000 01 01 000086, profileId:0104, clusterId:0702, clusterInt:1794, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 00, 86]]
dev:9432024-07-04 07:22:59.873debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0702 01 01 0040 00 5081 00 00 0000 01 01 000086
dev:9432024-07-04 07:22:59.700warnTuya Zigbee Metering Plug Power polling is not supported! -> Power polling will be disabled.
dev:9432024-07-04 07:22:59.691debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0B04 01 01 0040 00 5081 00 00 0000 01 01 0B0586050586080586, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[0B, 05, 86, 05, 05, 86, 08, 05, 86]]
dev:9432024-07-04 07:22:59.686debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0B04 01 01 0040 00 5081 00 00 0000 01 01 0B0586050586080586
dev:9432024-07-04 07:22:59.542traceTuya Zigbee Metering Plug sendZigbeeCommands : [he raw 0x5081 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200, he raw 0x5081 1 0x01 0x0702 {10 00 00 00 00}, delay 200, he rattr 0x5081 0x01 6 0 {}, delay 2000]
dev:9432024-07-04 07:22:59.488debugTuya Zigbee Metering Plug polling all 0x0B04 attributes
dev:9432024-07-04 07:22:59.486debugTuya Zigbee Metering Plug polling.. refreshAll is true
dev:9432024-07-04 07:22:59.480infoTuya Zigbee Metering Plug refresh()...
dev:9432024-07-04 07:22:58.796infoTuya Zigbee Metering Plug Energy (total:0.0 kWh) was reset on 2024-07-04 07:22:58.435
dev:9432024-07-04 07:22:58.732infoTuya Zigbee Metering Plug hourlyEnergy is 0 kWh
dev:9432024-07-04 07:22:58.726infoTuya Zigbee Metering Plug energy is 0.0 kWh (refresh), energyCost=$0.0 (rate=$0.21326), duration=0.0 Mins
dev:9432024-07-04 07:22:58.578debugTuya Zigbee Metering Plug energy_total=0, state.lastResetEnergy=0.0
dev:9432024-07-04 07:22:58.434debugresetEnergy() : state.lastEnergyRaw = 0.0
dev:9432024-07-04 07:22:57.401debugTuya Zigbee Metering Plug destinationEP = 01
dev:9432024-07-04 07:22:57.241debugTuya Zigbee Metering Plug state.lastResetEnergy = null, resetting it back to 0.0!
dev:9432024-07-04 07:22:57.239debugTuya Zigbee Metering Plug model = TS0601
dev:9432024-07-04 07:22:57.237debugTuya Zigbee Metering Plug preservedResetEnergy = 0.0
dev:9432024-07-04 07:22:57.236debugTuya Zigbee Metering Plug clearing states and preferences ...
dev:9432024-07-04 07:22:57.234infoTuya Zigbee Metering Plug InitializeVars()... fullInit = true
dev:9432024-07-04 07:22:57.195debugTuya Zigbee Metering Plug Initialize()...
dev:9432024-07-04 07:22:53.316infoTuya Zigbee Metering Plug Not Found (0x8b) Read Reporting Configuration Response for cluster:0006 attribute:0000, data=[86, 00, 00, 00] (Status: Failure)
dev:9432024-07-04 07:22:53.312debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 5081 00 00 0000 09 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:09, direction:01, data:[86, 00, 00, 00]]
dev:9432024-07-04 07:22:53.307debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0006 01 01 0040 00 5081 00 00 0000 09 01 86000000
dev:9432024-07-04 07:22:53.042infoTuya Zigbee Metering Plug Received Configure Reporting Response for cluster:0006 , data=[86, 00, 00, 00] (Status: Failure)
dev:9432024-07-04 07:22:53.038debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 5081 00 00 0000 07 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 00, 00]]
dev:9432024-07-04 07:22:53.033debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0006 01 01 0040 00 5081 00 00 0000 07 01 86000000
dev:9432024-07-04 07:22:52.789infoTuya Zigbee Metering Plug Received bind response, data=[2B, 00] (Sequence Number:2B, Status: Success)
dev:9432024-07-04 07:22:52.782debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 5081 00 00 0000 00 00 2B00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[2B, 00]]
dev:9432024-07-04 07:22:52.775debugTuya Zigbee Metering Plug parse: description is catchall: 0000 8021 00 00 0040 00 5081 00 00 0000 00 00 2B00
dev:9432024-07-04 07:22:52.750infoTuya Zigbee Metering Plug Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:9432024-07-04 07:22:52.742debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 5081 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:5081, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:9432024-07-04 07:22:52.736debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0000 01 01 0040 00 5081 00 00 0000 04 01 00
dev:9432024-07-04 07:22:52.726debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0005 value=TS0601 status=null data=null
dev:9432024-07-04 07:22:52.724debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9432024-07-04 07:22:52.722debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0000 value=03 status=null data=null
dev:9432024-07-04 07:22:52.720debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0004 value=_TZE200_qhlxve78 status=null data=null
dev:9432024-07-04 07:22:52.697debugTuya Zigbee Metering Plug parse: Desc Map: [raw:508101000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni:5081, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_qhlxve78, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:9432024-07-04 07:22:52.690warnTuya Zigbee Metering Plug parse: exception caught while trying to getEvent... description: read attr - raw: 508101000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 5081, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9432024-07-04 07:22:52.491debugTuya Zigbee Metering Plug parse: description is read attr - raw: 508101000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 5081, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9432024-07-04 07:22:52.324traceTuya Zigbee Metering Plug sendZigbeeCommands : [he raw 0x5081 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x5081 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0x5081 0x01 0x01 0x0006 {B43522FFFE75D4DE} {}, delay 251, he cr 0x5081 0x01 6 0 16 0 900 {}, delay 251, he raw 0x5081 1 0x01 0x0006 {10 00 08 00 0000}, delay 251]
dev:9432024-07-04 07:22:52.318infoTuya Zigbee Metering Plug Automatic reporting configuration is disabled and will be skipped!
dev:9432024-07-04 07:22:52.314debugTuya Zigbee Metering Plug configureReporting operation=Write, measurement=Switch, minTime=0, maxTime=900, delta=0 )
dev:9432024-07-04 07:22:52.267debugTuya Zigbee Metering Plug ep=01 isF2=false
dev:9432024-07-04 07:22:52.205infoTuya Zigbee Metering Plug configure()..
dev:9432024-07-04 07:22:51.971infoTuya Zigbee Metering Plug Installed()...
I should note that the agocsdaniel quirk for _TZE200_bcusnqt8 didn't work at all when retargeted to _TZE200_qhlxve78. My version of the SPM01 doesn't appear to report ZEMISMART_VCP_ATTR = 0x0006 that the earlier driver depends upon.
I see now that the nazmang posted driver depends on the non-working VCP attribute. The corrected version posted by stast1, without the division factor added by agomezfabian, is what's working for _TZE200_qhlxve78.
Hi M,
The Tuya driver as it is now, should decode the data structures as defined in both agocsdaniel and nazmang quirks.
The problem is, that there is nothing coming from the device... And from your log I see that the driver was installed correctly and the device was sent the 'TuyaMagic' sequence and it replied correctly.
Do you have any active power load? Is the clamp installed over one of the AC circuit wires?
I think the load was inactive for that test. In this log I started with the load off, turned it on, then off again. After re-pairing to Home Assistant and powering up the load, I get:
AC frequency 60.0 Hz
Current 1.3A
Power 91W
Power factor 57%
Summation delivered 5.05 kWh
Voltage 122V
Hubitat reports only these current states:
Current States
  • energy : 0.0
  • energyCost : 0.0
  • energyDuration : 0
  • healthStatus : online
  • hourlyEnergy : 0
Summary
dev:9442024-07-04 08:34:21.305debugHVAC Fan attribute report: cluster=0000 attrId=FFE4 value=00 status=null data=null
dev:9442024-07-04 08:34:21.304debugHVAC Fan attribute report: cluster=0000 attrId=FFE2 value=1F status=null data=null
dev:9442024-07-04 08:34:21.302debugHVAC Fan attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9442024-07-04 08:34:21.298debugHVAC Fan parse: Desc Map: [raw:EE3A0100001801002044E2FF201FE4FF2000, dni:EE3A, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:44, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:9442024-07-04 08:34:21.292debugHVAC Fan Cluster 0000 Tuya specific attrId FFE4 value 00)
dev:9442024-07-04 08:34:21.290debugHVAC Fan Cluster 0000 Tuya specific attrId FFE2 value 1F)
dev:9442024-07-04 08:34:21.282debugHVAC Fan parse: description is read attr - raw: EE3A0100001801002044E2FF201FE4FF2000, dni: EE3A, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF201FE4FF2000
dev:9442024-07-04 08:32:05.302warnHVAC Fan Unprocessed global command: cluster=EF00 command=11 attrId=null value=null data=[00, 08, D1]
dev:9442024-07-04 08:32:05.298debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 EE3A 01 00 0000 11 01 0008D1, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[00, 08, D1]]
dev:9442024-07-04 08:32:05.294debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 EE3A 01 00 0000 11 01 0008D1
dev:9442024-07-04 08:31:53.557infoHVAC Fan Initialization finished
dev:9442024-07-04 08:31:53.555infoHVAC Fan energyPollingSupported = false
dev:9442024-07-04 08:31:53.554infoHVAC Fan powerPollingSupported = false
dev:9442024-07-04 08:31:53.552infoHVAC Fan currentPollingSupported = true
dev:9442024-07-04 08:31:53.550infoHVAC Fan voltagePollingSupported = true
dev:9442024-07-04 08:31:53.548infoHVAC Fan switchPollingSupported = false
dev:9442024-07-04 08:31:53.534infoHVAC Fan Not Found (0x8b) Read Reporting Configuration Response for cluster:0006 attribute:0000, data=[86, 00, 00, 00] (Status: Failure)
dev:9442024-07-04 08:31:53.531debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 EE3A 00 00 0000 09 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:09, direction:01, data:[86, 00, 00, 00]]
dev:9442024-07-04 08:31:53.527debugHVAC Fan parse: description is catchall: 0104 0006 01 01 0040 00 EE3A 00 00 0000 09 01 86000000
dev:9442024-07-04 08:31:53.263infoHVAC Fan Received Configure Reporting Response for cluster:0006 , data=[86, 00, 00, 00] (Status: Failure)
dev:9442024-07-04 08:31:53.259debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 EE3A 00 00 0000 07 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 00, 00]]
dev:9442024-07-04 08:31:53.255debugHVAC Fan parse: description is catchall: 0104 0006 01 01 0040 00 EE3A 00 00 0000 07 01 86000000
dev:9442024-07-04 08:31:53.065infoHVAC Fan Received bind response, data=[86, 00] (Sequence Number:86, Status: Success)
dev:9442024-07-04 08:31:53.062debugHVAC Fan parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 EE3A 00 00 0000 00 00 8600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[86, 00]]
dev:9442024-07-04 08:31:53.058debugHVAC Fan parse: description is catchall: 0000 8021 00 00 0040 00 EE3A 00 00 0000 00 00 8600
dev:9442024-07-04 08:31:53.034infoHVAC Fan Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:9442024-07-04 08:31:53.032debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 EE3A 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:9442024-07-04 08:31:53.028debugHVAC Fan parse: description is catchall: 0104 0000 01 01 0040 00 EE3A 00 00 0000 04 01 00
dev:9442024-07-04 08:31:52.899debugHVAC Fan attribute report: cluster=0000 attrId=0005 value=TS0601 status=null data=null
dev:9442024-07-04 08:31:52.897debugHVAC Fan attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9442024-07-04 08:31:52.895debugHVAC Fan attribute report: cluster=0000 attrId=0000 value=03 status=null data=null
dev:9442024-07-04 08:31:52.894debugHVAC Fan attribute report: cluster=0000 attrId=0004 value=_TZE200_qhlxve78 status=null data=null
dev:9442024-07-04 08:31:52.888debugHVAC Fan parse: Desc Map: [raw:EE3A01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni:EE3A, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_qhlxve78, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:9442024-07-04 08:31:52.881warnHVAC Fan parse: exception caught while trying to getEvent... description: read attr - raw: EE3A01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: EE3A, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9442024-07-04 08:31:52.835debugHVAC Fan parse: description is read attr - raw: EE3A01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: EE3A, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9442024-07-04 08:31:52.670traceHVAC Fan sendZigbeeCommands : [he raw 0xEE3A 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0xEE3A 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0xEE3A 0x01 0x01 0x0006 {B43522FFFE75D4DE} {}, delay 251, he cr 0xEE3A 0x01 6 0 16 0 900 {}, delay 251, he raw 0xEE3A 1 0x01 0x0006 {10 00 08 00 0000}, delay 251]
dev:9442024-07-04 08:31:52.668infoHVAC Fan Automatic reporting configuration is disabled and will be skipped!
dev:9442024-07-04 08:31:52.665debugHVAC Fan configureReporting operation=Write, measurement=Switch, minTime=0, maxTime=900, delta=0 )
dev:9442024-07-04 08:31:52.647debugHVAC Fan ep=01 isF2=false
dev:9442024-07-04 08:31:52.572infoHVAC Fan configure()..
dev:9442024-07-04 08:31:52.570infoHVAC Fan configuring the switch and energy reporting..
dev:9442024-07-04 08:31:52.568infoHVAC Fan Auto polling is disabled
dev:9442024-07-04 08:31:52.557infoHVAC Fan Debug logging will be automatically switched off after 24 hours
dev:9442024-07-04 08:31:52.521infoHVAC Fan Debug logging is true Description text logging is true
dev:9442024-07-04 08:31:52.519infoHVAC Fan Updating HVAC Fan (Tuya Zigbee Metering Plug) model TS0601
dev:9442024-07-04 08:31:49.880debugHVAC Fan Cluster 0000 Tuya specific attrId FFDF value )
dev:9442024-07-04 08:31:49.874debugHVAC Fan parse: description is read attr - raw: EE3A01000026DFFF420F000000000500000000120000000012, dni: EE3A, endpoint: 01, cluster: 0000, size: 26, attrId: FFDF, encoding: 42, command: 0A, value: 0F000000000500000000120000000012
dev:9442024-07-04 08:31:49.574debugHVAC Fan attribute report: cluster=0000 attrId=FFE4 value=00 status=null data=null
dev:9442024-07-04 08:31:49.572debugHVAC Fan attribute report: cluster=0000 attrId=FFE2 value=1F status=null data=null
dev:9442024-07-04 08:31:49.570debugHVAC Fan attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9442024-07-04 08:31:49.567debugHVAC Fan parse: Desc Map: [raw:EE3A0100001801002044E2FF201FE4FF2000, dni:EE3A, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:44, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:9442024-07-04 08:31:49.561debugHVAC Fan Cluster 0000 Tuya specific attrId FFE4 value 00)
dev:9442024-07-04 08:31:49.559debugHVAC Fan Cluster 0000 Tuya specific attrId FFE2 value 1F)
dev:9442024-07-04 08:31:49.552debugHVAC Fan parse: description is read attr - raw: EE3A0100001801002044E2FF201FE4FF2000, dni: EE3A, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF201FE4FF2000
dev:9442024-07-04 08:31:45.548debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 EE3A 00 00 0000 0B 01 2400, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[24, 00]]
dev:9442024-07-04 08:31:45.544debugTuya Zigbee Metering Plug parse: description is catchall: 0104 EF00 01 01 0040 00 EE3A 00 00 0000 0B 01 2400
dev:9442024-07-04 08:31:45.406debugTuya Zigbee Metering Plug sending time data : [he cmd 0xEE3A 0x01 0xEF00 0x24 {00086686A44166865DF1}, delay 2000]
dev:9442024-07-04 08:31:45.404debugTuya Zigbee Metering Plug now is: 1720099905404
dev:9442024-07-04 08:31:45.398debugTuya Zigbee Metering Plug time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 EE3A 01 00 0000 24 01 0006, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 06]]
dev:9442024-07-04 08:31:45.396debugTuya Zigbee Metering Plug Tuya time sync
dev:9442024-07-04 08:31:45.393debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 EE3A 01 00 0000 24 01 0006, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 06]]
dev:9442024-07-04 08:31:45.389debugTuya Zigbee Metering Plug parse: description is catchall: 0104 EF00 01 01 0040 00 EE3A 01 00 0000 24 01 0006
dev:9442024-07-04 08:31:44.075warnTuya Zigbee Metering Plug Switch polling is not supported -> Switch polling will be disabled.
dev:9442024-07-04 08:31:44.072debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 EE3A 00 00 0000 01 01 000086, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 00, 86]]
dev:9442024-07-04 08:31:44.067debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0006 01 01 0040 00 EE3A 00 00 0000 01 01 000086
dev:9442024-07-04 08:31:43.891warnTuya Zigbee Metering Plug Energy measurement is not supported! -> Energy polling will be disabled.
dev:9442024-07-04 08:31:43.887debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0702 01 01 0040 00 EE3A 00 00 0000 01 01 000086, profileId:0104, clusterId:0702, clusterInt:1794, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 00, 86]]
dev:9442024-07-04 08:31:43.882debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0702 01 01 0040 00 EE3A 00 00 0000 01 01 000086
dev:9442024-07-04 08:31:43.681warnTuya Zigbee Metering Plug Power polling is not supported! -> Power polling will be disabled.
dev:9442024-07-04 08:31:43.672debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0B04 01 01 0040 00 EE3A 00 00 0000 01 01 0B0586050586080586, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[0B, 05, 86, 05, 05, 86, 08, 05, 86]]
dev:9442024-07-04 08:31:43.668debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0B04 01 01 0040 00 EE3A 00 00 0000 01 01 0B0586050586080586
dev:9442024-07-04 08:31:43.536traceTuya Zigbee Metering Plug sendZigbeeCommands : [he raw 0xEE3A 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200, he raw 0xEE3A 1 0x01 0x0702 {10 00 00 00 00}, delay 200, he rattr 0xEE3A 0x01 6 0 {}, delay 2000]
dev:9442024-07-04 08:31:43.494debugTuya Zigbee Metering Plug polling all 0x0B04 attributes
dev:9442024-07-04 08:31:43.492debugTuya Zigbee Metering Plug polling.. refreshAll is true
dev:9442024-07-04 08:31:43.486infoTuya Zigbee Metering Plug refresh()...
dev:9442024-07-04 08:31:42.847infoTuya Zigbee Metering Plug Energy (total:0.0 kWh) was reset on 2024-07-04 08:31:42.451
dev:9442024-07-04 08:31:42.789infoTuya Zigbee Metering Plug hourlyEnergy is 0 kWh
dev:9442024-07-04 08:31:42.782infoTuya Zigbee Metering Plug energy is 0.0 kWh (refresh), energyCost=$0.0 (rate=$0.21326), duration=0.0 Mins
dev:9442024-07-04 08:31:42.589debugTuya Zigbee Metering Plug energy_total=0, state.lastResetEnergy=0.0
dev:9442024-07-04 08:31:42.449debugresetEnergy() : state.lastEnergyRaw = 0.0
dev:9442024-07-04 08:31:41.423debugTuya Zigbee Metering Plug destinationEP = 01
dev:9442024-07-04 08:31:41.258debugTuya Zigbee Metering Plug state.lastResetEnergy = null, resetting it back to 0.0!
dev:9442024-07-04 08:31:41.256debugTuya Zigbee Metering Plug model = TS0601
dev:9442024-07-04 08:31:41.254debugTuya Zigbee Metering Plug preservedResetEnergy = 0.0
dev:9442024-07-04 08:31:41.253debugTuya Zigbee Metering Plug clearing states and preferences ...
dev:9442024-07-04 08:31:41.251infoTuya Zigbee Metering Plug InitializeVars()... fullInit = true
dev:9442024-07-04 08:31:41.215debugTuya Zigbee Metering Plug Initialize()...
dev:9442024-07-04 08:31:37.207infoTuya Zigbee Metering Plug Not Found (0x8b) Read Reporting Configuration Response for cluster:0006 attribute:0000, data=[86, 00, 00, 00] (Status: Failure)
dev:9442024-07-04 08:31:37.202debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 EE3A 00 00 0000 09 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:09, direction:01, data:[86, 00, 00, 00]]
dev:9442024-07-04 08:31:37.198debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0006 01 01 0040 00 EE3A 00 00 0000 09 01 86000000
dev:9442024-07-04 08:31:36.959infoTuya Zigbee Metering Plug Received Configure Reporting Response for cluster:0006 , data=[86, 00, 00, 00] (Status: Failure)
dev:9442024-07-04 08:31:36.955debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 EE3A 00 00 0000 07 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 00, 00]]
dev:9442024-07-04 08:31:36.951debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0006 01 01 0040 00 EE3A 00 00 0000 07 01 86000000
dev:9442024-07-04 08:31:36.847infoTuya Zigbee Metering Plug Received bind response, data=[7B, 00] (Sequence Number:7B, Status: Success)
dev:9442024-07-04 08:31:36.840debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 EE3A 00 00 0000 00 00 7B00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[7B, 00]]
dev:9442024-07-04 08:31:36.836debugTuya Zigbee Metering Plug parse: description is catchall: 0000 8021 00 00 0040 00 EE3A 00 00 0000 00 00 7B00
dev:9442024-07-04 08:31:36.824infoTuya Zigbee Metering Plug Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:9442024-07-04 08:31:36.817debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 EE3A 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:EE3A, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:9442024-07-04 08:31:36.812debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0000 01 01 0040 00 EE3A 00 00 0000 04 01 00
dev:9442024-07-04 08:31:36.803debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0005 value=TS0601 status=null data=null
dev:9442024-07-04 08:31:36.801debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9442024-07-04 08:31:36.800debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0000 value=03 status=null data=null
dev:9442024-07-04 08:31:36.798debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0004 value=_TZE200_qhlxve78 status=null data=null
dev:9442024-07-04 08:31:36.790debugTuya Zigbee Metering Plug parse: Desc Map: [raw:EE3A01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni:EE3A, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_qhlxve78, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:9442024-07-04 08:31:36.678warnTuya Zigbee Metering Plug parse: exception caught while trying to getEvent... description: read attr - raw: EE3A01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: EE3A, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9442024-07-04 08:31:36.569debugTuya Zigbee Metering Plug parse: description is read attr - raw: EE3A01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: EE3A, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9442024-07-04 08:31:36.349traceTuya Zigbee Metering Plug sendZigbeeCommands : [he raw 0xEE3A 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0xEE3A 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0xEE3A 0x01 0x01 0x0006 {B43522FFFE75D4DE} {}, delay 251, he cr 0xEE3A 0x01 6 0 16 0 900 {}, delay 251, he raw 0xEE3A 1 0x01 0x0006 {10 00 08 00 0000}, delay 251]
dev:9442024-07-04 08:31:36.344infoTuya Zigbee Metering Plug Automatic reporting configuration is disabled and will be skipped!
dev:9442024-07-04 08:31:36.339debugTuya Zigbee Metering Plug configureReporting operation=Write, measurement=Switch, minTime=0, maxTime=900, delta=0 )
dev:9442024-07-04 08:31:36.291debugTuya Zigbee Metering Plug ep=01 isF2=false
dev:9442024-07-04 08:31:36.234infoTuya Zigbee Metering Plug configure()..
dev:9442024-07-04 08:31:36.015infoTuya Zigbee Metering Plug Installed()...
For some reason this device does not send automatically the power measurements to the HE hub...
I will very carefully review the ZHA implementation during the coming weekend.
Can you confirm that this TS0601 _TZE200_qhlxve78 stays connected to your hub?
If you switch to the HE inbuilt driver named 'Device' and click on the 'Get Info' button, do you see the fingerprint in the live logs?
Well, this is interesting. I cut and restored power to this hardwired device shortly after pairing it to my HE hub, and it started giving me data! This step wasn't needed on ZHA, but HE seems to need it for an unknown reason.
A couple observations now that it's communicating:
  • The voltage spikes to > 5 kV every 5 seconds. I've captured two of these spikes in the log.
  • The power is off by a factor of 10- 95W reads as 9.5W
I greatly appreciate your time and effort on this. Thank you!
Here's the bottom half of the log. It exceeds the character limit so I'll post it in two sections.
Summary
dev:9452024-07-04 12:57:30.968debugHVAC Fan (02) Reverse Energy : 0 raw
dev:9452024-07-04 12:57:30.965debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00310202000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 31, 02, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:30.960debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00310202000400000000
dev:9452024-07-04 12:57:30.889debugHVAC Fan HVAC Fan energy is 5.15 kWh (no change)
dev:9452024-07-04 12:57:30.887debugHVAC Fan energy_total=5.15, state.lastResetEnergy=0.0
dev:9452024-07-04 12:57:30.884debugHVAC Fan (01) Forward/Real Energy : 515 raw
dev:9452024-07-04 12:57:30.880debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00300102000400000203, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 30, 01, 02, 00, 04, 00, 00, 02, 03]]
dev:9452024-07-04 12:57:30.875debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00300102000400000203
dev:9452024-07-04 12:57:30.315warnHVAC Fan Unprocessed global command: cluster=EF00 command=11 attrId=null value=null data=[00, 05, D1]
dev:9452024-07-04 12:57:30.312debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 11 01 0005D1, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[00, 05, D1]]
dev:9452024-07-04 12:57:30.308debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 11 01 0005D1
dev:9452024-07-04 12:57:26.650debugHVAC Fan ignored power 0 W (change from 0.0 is less than 1 W)
dev:9452024-07-04 12:57:26.648debugHVAC Fan (104) SPM01 power : 0 raw (0)
dev:9452024-07-04 12:57:26.643debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002E6802000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2E, 68, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:26.638debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002E6802000400000000
dev:9452024-07-04 12:57:26.626debugHVAC Fan ignored amperage 0.0 A (change from 0.0 is less than 25 mA)
dev:9452024-07-04 12:57:26.609debugHVAC Fan (103) Amperage HOCH : 0.0 A (raw 0)
dev:9452024-07-04 12:57:26.605debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002D6702000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2D, 67, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:26.597debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002D6702000400000000
dev:9452024-07-04 12:57:26.393infoHVAC Fan voltage is 122 V
dev:9452024-07-04 12:57:26.388debugHVAC Fan (102) SPM01 voltage : 122.5 raw (1225)
dev:9452024-07-04 12:57:26.379debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002C66020004000004C9, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2C, 66, 02, 00, 04, 00, 00, 04, C9]]
dev:9452024-07-04 12:57:26.371debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002C66020004000004C9
dev:9452024-07-04 12:57:26.358debugHVAC Fan ignored frequencyEvent (59.98) - reportFrequency is disabled
dev:9452024-07-04 12:57:26.344debugHVAC Fan (101) SPM01 frequency : 5998 raw (59.98) Hz
dev:9452024-07-04 12:57:26.337debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002B650200040000176E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2B, 65, 02, 00, 04, 00, 00, 17, 6E]]
dev:9452024-07-04 12:57:26.319debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002B650200040000176E
dev:9452024-07-04 12:57:26.300debugHVAC Fan ignored powerFactorEvent (1) - reportPowerFactor is disabled
dev:9452024-07-04 12:57:26.298debugHVAC Fan (110) SPM01 power_factor : 1 raw (100)
dev:9452024-07-04 12:57:26.282debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002A0F02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 2A, 0F, 02, 00, 04, 00, 00, 00, 64]]
dev:9452024-07-04 12:57:26.241debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002A0F02000400000064
dev:9452024-07-04 12:57:26.225debugHVAC Fan ignored power 40371.2 W (exceeds maximum power cap 15000 W)
dev:9452024-07-04 12:57:26.223debugHVAC Fan SPM01 Active. Power : 40371.2 W (raw 403712)
dev:9452024-07-04 12:57:26.213debugHVAC Fan SPM01 Current : 524.288 A (raw 524288)
dev:9452024-07-04 12:57:26.070infoHVAC Fan voltage is 5146 V
dev:9452024-07-04 12:57:26.067debugHVAC Fan SPM01 Voltage : 5146 V (raw 51460)
dev:9452024-07-04 12:57:26.065debugHVAC Fan SPM01 combined reporting data: [00, 29, 06, 00, 00, 08, 04, C9, 00, 00, 00, 00, 00, 00]
dev:9452024-07-04 12:57:26.056debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00290600000804C9000000000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 29, 06, 00, 00, 08, 04, C9, 00, 00, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:26.050debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00290600000804C9000000000000
dev:9452024-07-04 12:57:25.928debugHVAC Fan (02) Reverse Energy : 0 raw
dev:9452024-07-04 12:57:25.901debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00280202000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 28, 02, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:25.897debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00280202000400000000
dev:9452024-07-04 12:57:25.839debugHVAC Fan HVAC Fan energy is 5.15 kWh (no change)
dev:9452024-07-04 12:57:25.835debugHVAC Fan energy_total=5.15, state.lastResetEnergy=0.0
dev:9452024-07-04 12:57:25.829debugHVAC Fan (01) Forward/Real Energy : 515 raw
dev:9452024-07-04 12:57:25.823debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00270102000400000203, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 27, 01, 02, 00, 04, 00, 00, 02, 03]]
dev:9452024-07-04 12:57:25.813debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00270102000400000203
dev:9452024-07-04 12:57:21.343debugHVAC Fan ignored power 0 W (change from 0.0 is less than 1 W)
dev:9452024-07-04 12:57:21.341debugHVAC Fan (104) SPM01 power : 0 raw (0)
dev:9452024-07-04 12:57:21.336debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00256802000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 25, 68, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:21.332debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00256802000400000000
dev:9452024-07-04 12:57:21.259debugHVAC Fan ignored amperage 0.0 A (change from 0.0 is less than 25 mA)
dev:9452024-07-04 12:57:21.256debugHVAC Fan (103) Amperage HOCH : 0.0 A (raw 0)
dev:9452024-07-04 12:57:21.252debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00246702000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 24, 67, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:21.248debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00246702000400000000
dev:9452024-07-04 12:57:21.172infoHVAC Fan voltage is 122 V
dev:9452024-07-04 12:57:21.170debugHVAC Fan (102) SPM01 voltage : 122.5 raw (1225)
dev:9452024-07-04 12:57:21.165debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002366020004000004C9, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 23, 66, 02, 00, 04, 00, 00, 04, C9]]
dev:9452024-07-04 12:57:21.161debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 002366020004000004C9
dev:9452024-07-04 12:57:21.086debugHVAC Fan ignored frequencyEvent (59.98) - reportFrequency is disabled
dev:9452024-07-04 12:57:21.084debugHVAC Fan (101) SPM01 frequency : 5998 raw (59.98) Hz
dev:9452024-07-04 12:57:21.080debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0022650200040000176E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 22, 65, 02, 00, 04, 00, 00, 17, 6E]]
dev:9452024-07-04 12:57:21.075debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0022650200040000176E
dev:9452024-07-04 12:57:20.982debugHVAC Fan ignored powerFactorEvent (1) - reportPowerFactor is disabled
dev:9452024-07-04 12:57:20.980debugHVAC Fan (110) SPM01 power_factor : 1 raw (100)
dev:9452024-07-04 12:57:20.976debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00210F02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 21, 0F, 02, 00, 04, 00, 00, 00, 64]]
dev:9452024-07-04 12:57:20.972debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00210F02000400000064
dev:9452024-07-04 12:57:20.922debugHVAC Fan ignored power 40140.8 W (exceeds maximum power cap 15000 W)
dev:9452024-07-04 12:57:20.920debugHVAC Fan SPM01 Active. Power : 40140.8 W (raw 401408)
dev:9452024-07-04 12:57:20.918debugHVAC Fan SPM01 Current : 524.288 A (raw 524288)
dev:9452024-07-04 12:57:20.895infoHVAC Fan voltage is 5146 V
dev:9452024-07-04 12:57:20.892debugHVAC Fan SPM01 Voltage : 5146 V (raw 51460)
dev:9452024-07-04 12:57:20.890debugHVAC Fan SPM01 combined reporting data: [00, 20, 06, 00, 00, 08, 04, C9, 00, 00, 00, 00, 00, 00]
dev:9452024-07-04 12:57:20.886debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00200600000804C9000000000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 20, 06, 00, 00, 08, 04, C9, 00, 00, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:20.882debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00200600000804C9000000000000
dev:9452024-07-04 12:57:20.802debugHVAC Fan (02) Reverse Energy : 0 raw
dev:9452024-07-04 12:57:20.799debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 001F0202000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 1F, 02, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:20.794debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 001F0202000400000000
dev:9452024-07-04 12:57:20.747debugHVAC Fan HVAC Fan energy is 5.15 kWh (no change)
dev:9452024-07-04 12:57:20.744debugHVAC Fan energy_total=5.15, state.lastResetEnergy=0.0
dev:9452024-07-04 12:57:20.742debugHVAC Fan (01) Forward/Real Energy : 515 raw
dev:9452024-07-04 12:57:20.738debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 001E0102000400000203, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 1E, 01, 02, 00, 04, 00, 00, 02, 03]]
dev:9452024-07-04 12:57:20.688debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 001E0102000400000203
dev:9452024-07-04 12:57:17.603warnHVAC Fan Power polling is not supported! -> Power polling will be disabled.
dev:9452024-07-04 12:57:17.599debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0B04 01 01 0040 00 2DBE 00 00 0000 01 01 0B0586, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[0B, 05, 86]]
dev:9452024-07-04 12:57:17.596debugHVAC Fan parse: description is catchall: 0104 0B04 01 01 0040 00 2DBE 00 00 0000 01 01 0B0586
dev:9452024-07-04 12:57:17.459debugHVAC Fan pollPower()..
dev:9452024-07-04 12:57:16.286debugHVAC Fan ignored power 0 W (change from 0.0 is less than 1 W)
dev:9452024-07-04 12:57:16.284debugHVAC Fan (104) SPM01 power : 0 raw (0)
dev:9452024-07-04 12:57:16.280debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 001C6802000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 1C, 68, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:16.275debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 001C6802000400000000
dev:9452024-07-04 12:57:16.200debugHVAC Fan ignored amperage 0.0 A (change from 0.0 is less than 25 mA)
dev:9452024-07-04 12:57:16.197debugHVAC Fan (103) Amperage HOCH : 0.0 A (raw 0)
dev:9452024-07-04 12:57:16.193debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 001B6702000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 1B, 67, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:16.189debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 001B6702000400000000
dev:9452024-07-04 12:57:16.113infoHVAC Fan voltage is 122 V
dev:9452024-07-04 12:57:16.110debugHVAC Fan (102) SPM01 voltage : 122.5 raw (1225)
dev:9452024-07-04 12:57:16.105debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 001A66020004000004C9, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 1A, 66, 02, 00, 04, 00, 00, 04, C9]]
dev:9452024-07-04 12:57:16.101debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 001A66020004000004C9
dev:9452024-07-04 12:57:16.023debugHVAC Fan ignored frequencyEvent (59.98) - reportFrequency is disabled
dev:9452024-07-04 12:57:16.022debugHVAC Fan (101) SPM01 frequency : 5998 raw (59.98) Hz
dev:9452024-07-04 12:57:16.017debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0019650200040000176E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 19, 65, 02, 00, 04, 00, 00, 17, 6E]]
dev:9452024-07-04 12:57:16.013debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0019650200040000176E
dev:9452024-07-04 12:57:15.882debugHVAC Fan ignored powerFactorEvent (1) - reportPowerFactor is disabled
dev:9452024-07-04 12:57:15.880debugHVAC Fan (110) SPM01 power_factor : 1 raw (100)
dev:9452024-07-04 12:57:15.874debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00180F02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 18, 0F, 02, 00, 04, 00, 00, 00, 64]]
dev:9452024-07-04 12:57:15.870debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00180F02000400000064
dev:9452024-07-04 12:57:15.844debugHVAC Fan ignored power 39910.4 W (exceeds maximum power cap 15000 W)
dev:9452024-07-04 12:57:15.842debugHVAC Fan SPM01 Active. Power : 39910.4 W (raw 399104)
dev:9452024-07-04 12:57:15.840debugHVAC Fan SPM01 Current : 524.288 A (raw 524288)
dev:9452024-07-04 12:57:15.792infoHVAC Fan voltage is 5146 V
dev:9452024-07-04 12:57:15.787debugHVAC Fan SPM01 Voltage : 5146 V (raw 51460)
dev:9452024-07-04 12:57:15.785debugHVAC Fan SPM01 combined reporting data: [00, 17, 06, 00, 00, 08, 04, C9, 00, 00, 00, 00, 00, 00]
dev:9452024-07-04 12:57:15.781debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00170600000804C9000000000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 17, 06, 00, 00, 08, 04, C9, 00, 00, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:15.776debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00170600000804C9000000000000
dev:9452024-07-04 12:57:15.688debugHVAC Fan (02) Reverse Energy : 0 raw
dev:9452024-07-04 12:57:15.684debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00160202000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 16, 02, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:15.680debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00160202000400000000
dev:9452024-07-04 12:57:15.608debugHVAC Fan HVAC Fan energy is 5.15 kWh (no change)
dev:9452024-07-04 12:57:15.606debugHVAC Fan energy_total=5.15, state.lastResetEnergy=0.0
dev:9452024-07-04 12:57:15.603debugHVAC Fan (01) Forward/Real Energy : 515 raw
dev:9452024-07-04 12:57:15.599debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00150102000400000203, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 15, 01, 02, 00, 04, 00, 00, 02, 03]]
dev:9452024-07-04 12:57:15.595debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00150102000400000203
dev:9452024-07-04 12:57:11.939debugHVAC Fan skipped dp=18 for SPM01 data = [00, 13, 12, 00, 00, 14, 01, 01, 00, 3C, 03, 01, 00, FD, 04, 00, 00, B4, 07, 01, 00, 00, 09, 00, 00, 00]
dev:9452024-07-04 12:57:11.933debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0013120000140101003C030100FD040000B40701000009000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 13, 12, 00, 00, 14, 01, 01, 00, 3C, 03, 01, 00, FD, 04, 00, 00, B4, 07, 01, 00, 00, 09, 00, 00, 00]]
dev:9452024-07-04 12:57:11.927debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0013120000140101003C030100FD040000B40701000009000000
dev:9452024-07-04 12:57:11.811debugHVAC Fan skipped dp=17 for SPM01 data = [00, 12, 11, 00, 00, 08, 07, 01, 00, 0D, 08, 00, 00, 00]
dev:9452024-07-04 12:57:11.796debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0012110000080701000D08000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 12, 11, 00, 00, 08, 07, 01, 00, 0D, 08, 00, 00, 00]]
dev:9452024-07-04 12:57:11.785debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0012110000080701000D08000000
dev:9452024-07-04 12:57:11.676infoHVAC Fan HVAC Fan HVAC Fan switch is on
dev:9452024-07-04 12:57:11.433debugHVAC Fan Switch state changed from unknown to on
dev:9452024-07-04 12:57:11.427debugHVAC Fan (16) switch : 1
dev:9452024-07-04 12:57:11.424debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00111001000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 11, 10, 01, 00, 01, 01]]
dev:9452024-07-04 12:57:11.419debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00111001000101
dev:9452024-07-04 12:57:11.343debugHVAC Fan dp=09 value=0
dev:9452024-07-04 12:57:11.339debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00100905000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 10, 09, 05, 00, 01, 00]]
dev:9452024-07-04 12:57:11.334debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00100905000100
dev:9452024-07-04 12:57:11.268debugHVAC Fan ignored power 0 W (change from 0.0 is less than 1 W)
dev:9452024-07-04 12:57:11.265debugHVAC Fan (104) SPM01 power : 0 raw (0)
dev:9452024-07-04 12:57:11.260debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000F6802000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0F, 68, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:11.255debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000F6802000400000000
dev:9452024-07-04 12:57:11.246debugHVAC Fan ignored amperage 0.0 A (change from 0.0 is less than 25 mA)
dev:9452024-07-04 12:57:11.231debugHVAC Fan (103) Amperage HOCH : 0.0 A (raw 0)
dev:9452024-07-04 12:57:11.223debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000E6702000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0E, 67, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:11.218debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000E6702000400000000
dev:9452024-07-04 12:57:11.133infoHVAC Fan voltage is 122 V
dev:9452024-07-04 12:57:11.129debugHVAC Fan (102) SPM01 voltage : 122.4 raw (1224)
dev:9452024-07-04 12:57:11.123debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000D66020004000004C8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0D, 66, 02, 00, 04, 00, 00, 04, C8]]
dev:9452024-07-04 12:57:11.118debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000D66020004000004C8
dev:9452024-07-04 12:57:11.107debugHVAC Fan ignored frequencyEvent (59.98) - reportFrequency is disabled
dev:9452024-07-04 12:57:11.100debugHVAC Fan (101) SPM01 frequency : 5998 raw (59.98) Hz
dev:9452024-07-04 12:57:11.091debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000C650200040000176E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0C, 65, 02, 00, 04, 00, 00, 17, 6E]]
dev:9452024-07-04 12:57:11.086debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000C650200040000176E
dev:9452024-07-04 12:57:11.074debugHVAC Fan ignored powerFactorEvent (1) - reportPowerFactor is disabled
dev:9452024-07-04 12:57:11.066debugHVAC Fan (110) SPM01 power_factor : 1 raw (100)
dev:9452024-07-04 12:57:11.060debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000B0F02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0B, 0F, 02, 00, 04, 00, 00, 00, 64]]
dev:9452024-07-04 12:57:11.050debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000B0F02000400000064
dev:9452024-07-04 12:57:11.038debugHVAC Fan ignored power 39577.6 W (exceeds maximum power cap 15000 W)
dev:9452024-07-04 12:57:11.028debugHVAC Fan SPM01 Active. Power : 39577.6 W (raw 395776)
dev:9452024-07-04 12:57:11.022debugHVAC Fan SPM01 Current : 524.288 A (raw 524288)
dev:9452024-07-04 12:57:10.962infoHVAC Fan voltage is 5120 V
dev:9452024-07-04 12:57:10.951debugHVAC Fan SPM01 Voltage : 5120.4 V (raw 51204)
dev:9452024-07-04 12:57:10.947debugHVAC Fan SPM01 combined reporting data: [00, 0A, 06, 00, 00, 08, 04, C8, 00, 00, 00, 00, 00, 00]
dev:9452024-07-04 12:57:10.868debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000A0600000804C8000000000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 0A, 06, 00, 00, 08, 04, C8, 00, 00, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:10.863debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 000A0600000804C8000000000000
dev:9452024-07-04 12:57:10.850debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 00 00 0000 0B 01 2400, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[24, 00]]
dev:9452024-07-04 12:57:10.843debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 00 00 0000 0B 01 2400
dev:9452024-07-04 12:57:10.831debugHVAC Fan (02) Reverse Energy : 0 raw
dev:9452024-07-04 12:57:10.813debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00090202000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 09, 02, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:10.806debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00090202000400000000
dev:9452024-07-04 12:57:10.792infoHVAC Fan energy is 5.15 kWh, energyCost=$1.1 (rate=$0.21326), duration=0.42 Mins
dev:9452024-07-04 12:57:10.581debugHVAC Fan energy_total=5.15, state.lastResetEnergy=0.0
dev:9452024-07-04 12:57:10.563debugHVAC Fan (01) Forward/Real Energy : 515 raw
dev:9452024-07-04 12:57:10.535debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00080102000400000203, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 08, 01, 02, 00, 04, 00, 00, 02, 03]]
dev:9452024-07-04 12:57:10.528debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00080102000400000203
dev:9452024-07-04 12:57:10.500debugHVAC Fan sending time data : [he cmd 0x2DBE 0x01 0xEF00 0x24 {00086686E27666869C26}, delay 2000]
dev:9452024-07-04 12:57:10.498debugHVAC Fan now is: 1720115830484
dev:9452024-07-04 12:57:10.472debugHVAC Fan time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 24 01 0003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 03]]
dev:9452024-07-04 12:57:10.466debugHVAC Fan Tuya time sync
dev:9452024-07-04 12:57:10.458debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 24 01 0003, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 03]]
dev:9452024-07-04 12:57:10.453debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 24 01 0003
dev:9452024-07-04 12:57:05.227debugHVAC Fan attribute report: cluster=0000 attrId=FFE4 value=01 status=null data=null
dev:9452024-07-04 12:57:05.225debugHVAC Fan attribute report: cluster=0000 attrId=FFE2 value=1F status=null data=null
dev:9452024-07-04 12:57:05.224debugHVAC Fan attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9452024-07-04 12:57:05.220debugHVAC Fan parse: Desc Map: [raw:2DBE0100001801002044E2FF201FE4FF2001, dni:2DBE, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:44, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:01, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:9452024-07-04 12:57:05.214debugHVAC Fan Cluster 0000 Tuya specific attrId FFE4 value 01)
dev:9452024-07-04 12:57:05.213debugHVAC Fan Cluster 0000 Tuya specific attrId FFE2 value 1F)
dev:9452024-07-04 12:57:05.207debugHVAC Fan parse: description is read attr - raw: 2DBE0100001801002044E2FF201FE4FF2001, dni: 2DBE, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF201FE4FF2001
dev:9452024-07-04 12:56:56.505infoHVAC Fan Initialization finished
dev:9452024-07-04 12:56:56.503infoHVAC Fan energyPollingSupported = false
dev:9452024-07-04 12:56:56.502infoHVAC Fan powerPollingSupported = false
dev:9452024-07-04 12:56:56.500infoHVAC Fan currentPollingSupported = true
dev:9452024-07-04 12:56:56.499infoHVAC Fan voltagePollingSupported = true
dev:9452024-07-04 12:56:56.497infoHVAC Fan switchPollingSupported = false
dev:9452024-07-04 12:56:56.412infoHVAC Fan Not Found (0x8b) Read Reporting Configuration Response for cluster:0006 attribute:0000, data=[86, 00, 00, 00] (Status: Failure)
dev:9452024-07-04 12:56:56.409debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 2DBE 00 00 0000 09 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:09, direction:01, data:[86, 00, 00, 00]]
dev:9452024-07-04 12:56:56.405debugHVAC Fan parse: description is catchall: 0104 0006 01 01 0040 00 2DBE 00 00 0000 09 01 86000000
dev:9452024-07-04 12:56:56.170infoHVAC Fan Received Configure Reporting Response for cluster:0006 , data=[86, 00, 00, 00] (Status: Failure)
dev:9452024-07-04 12:56:56.168debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 2DBE 00 00 0000 07 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 00, 00]]
dev:9452024-07-04 12:56:56.163debugHVAC Fan parse: description is catchall: 0104 0006 01 01 0040 00 2DBE 00 00 0000 07 01 86000000
dev:9452024-07-04 12:56:55.989infoHVAC Fan Received bind response, data=[D5, 00] (Sequence Number:D5, Status: Success)
dev:9452024-07-04 12:56:55.987debugHVAC Fan parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 2DBE 00 00 0000 00 00 D500, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[D5, 00]]
dev:9452024-07-04 12:56:55.982debugHVAC Fan parse: description is catchall: 0000 8021 00 00 0040 00 2DBE 00 00 0000 00 00 D500
dev:9452024-07-04 12:56:55.866infoHVAC Fan Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:9452024-07-04 12:56:55.862debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 2DBE 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:9452024-07-04 12:56:55.858debugHVAC Fan parse: description is catchall: 0104 0000 01 01 0040 00 2DBE 00 00 0000 04 01 00
dev:9452024-07-04 12:56:55.818debugHVAC Fan attribute report: cluster=0000 attrId=0005 value=TS0601 status=null data=null
dev:9452024-07-04 12:56:55.817debugHVAC Fan attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9452024-07-04 12:56:55.815debugHVAC Fan attribute report: cluster=0000 attrId=0000 value=03 status=null data=null
dev:9452024-07-04 12:56:55.814debugHVAC Fan attribute report: cluster=0000 attrId=0004 value=_TZE200_qhlxve78 status=null data=null
dev:9452024-07-04 12:56:55.809debugHVAC Fan parse: Desc Map: [raw:2DBE01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni:2DBE, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_qhlxve78, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:9452024-07-04 12:56:55.801warnHVAC Fan parse: exception caught while trying to getEvent... description: read attr - raw: 2DBE01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 2DBE, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9452024-07-04 12:56:55.759debugHVAC Fan parse: description is read attr - raw: 2DBE01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 2DBE, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9452024-07-04 12:56:55.570traceHVAC Fan sendZigbeeCommands : [he raw 0x2DBE 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x2DBE 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0x2DBE 0x01 0x01 0x0006 {B43522FFFE75D4DE} {}, delay 251, he cr 0x2DBE 0x01 6 0 16 0 900 {}, delay 251, he raw 0x2DBE 1 0x01 0x0006 {10 00 08 00 0000}, delay 251]
dev:9452024-07-04 12:56:55.566infoHVAC Fan Automatic reporting configuration is disabled and will be skipped!
dev:9452024-07-04 12:56:55.562debugHVAC Fan configureReporting operation=Write, measurement=Switch, minTime=0, maxTime=900, delta=0 )
dev:9452024-07-04 12:56:55.545debugHVAC Fan ep=01 isF2=false
dev:9452024-07-04 12:56:55.465infoHVAC Fan configure()..
dev:9452024-07-04 12:56:55.461infoHVAC Fan configuring the switch and energy reporting..
dev:9452024-07-04 12:56:55.457infoHVAC Fan Auto polling is disabled
dev:9452024-07-04 12:56:55.430infoHVAC Fan Debug logging will be automatically switched off after 24 hours
dev:9452024-07-04 12:56:55.402infoHVAC Fan Debug logging is true Description text logging is true
dev:9452024-07-04 12:56:55.400infoHVAC Fan Updating HVAC Fan (Tuya Zigbee Metering Plug) model TS0601
dev:9452024-07-04 12:56:50.812debugHVAC Fan Cluster 0000 Tuya specific attrId FFDF value )
dev:9452024-07-04 12:56:50.806debugHVAC Fan parse: description is read attr - raw: 2DBE01000026DFFF420F000000000500000000120000000012, dni: 2DBE, endpoint: 01, cluster: 0000, size: 26, attrId: FFDF, encoding: 42, command: 0A, value: 0F000000000500000000120000000012
dev:9452024-07-04 12:56:50.670debugHVAC Fan attribute report: cluster=0000 attrId=FFE4 value=00 status=null data=null
dev:9452024-07-04 12:56:50.668debugHVAC Fan attribute report: cluster=0000 attrId=FFE2 value=1F status=null data=null
dev:9452024-07-04 12:56:50.667debugHVAC Fan attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9452024-07-04 12:56:50.663debugHVAC Fan parse: Desc Map: [raw:2DBE0100001801002044E2FF201FE4FF2000, dni:2DBE, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:44, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:9452024-07-04 12:56:50.657debugHVAC Fan Cluster 0000 Tuya specific attrId FFE4 value 00)
dev:9452024-07-04 12:56:50.655debugHVAC Fan Cluster 0000 Tuya specific attrId FFE2 value 1F)
dev:9452024-07-04 12:56:50.644debugHVAC Fan parse: description is read attr - raw: 2DBE0100001801002044E2FF201FE4FF2000, dni: 2DBE, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 44E2FF201FE4FF2000
dev:9452024-07-04 12:56:48.472debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 00 00 0000 0B 01 2400, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[24, 00]]
dev:9452024-07-04 12:56:48.468debugTuya Zigbee Metering Plug parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 00 00 0000 0B 01 2400
dev:9452024-07-04 12:56:48.315debugTuya Zigbee Metering Plug sending time data : [he cmd 0x2DBE 0x01 0xEF00 0x24 {00086686E26066869C10}, delay 2000]
dev:9452024-07-04 12:56:48.313debugTuya Zigbee Metering Plug now is: 1720115808313
dev:9452024-07-04 12:56:48.307debugTuya Zigbee Metering Plug time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 24 01 0006, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 06]]
dev:9452024-07-04 12:56:48.305debugTuya Zigbee Metering Plug Tuya time sync
dev:9452024-07-04 12:56:48.302debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 24 01 0006, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 06]]
dev:9452024-07-04 12:56:48.298debugTuya Zigbee Metering Plug parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 24 01 0006
dev:9452024-07-04 12:56:46.984warnTuya Zigbee Metering Plug Switch polling is not supported -> Switch polling will be disabled.
dev:9452024-07-04 12:56:46.981debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 2DBE 00 00 0000 01 01 000086, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 00, 86]]
dev:9452024-07-04 12:56:46.977debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0006 01 01 0040 00 2DBE 00 00 0000 01 01 000086
dev:9452024-07-04 12:56:46.873warnTuya Zigbee Metering Plug Energy measurement is not supported! -> Energy polling will be disabled.
dev:9452024-07-04 12:56:46.869debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0702 01 01 0040 00 2DBE 00 00 0000 01 01 000086, profileId:0104, clusterId:0702, clusterInt:1794, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 00, 86]]
dev:9452024-07-04 12:56:46.865debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0702 01 01 0040 00 2DBE 00 00 0000 01 01 000086
dev:9452024-07-04 12:56:46.588warnTuya Zigbee Metering Plug Power polling is not supported! -> Power polling will be disabled.
dev:9452024-07-04 12:56:46.579debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0B04 01 01 0040 00 2DBE 00 00 0000 01 01 0B0586050586080586, profileId:0104, clusterId:0B04, clusterInt:2820, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[0B, 05, 86, 05, 05, 86, 08, 05, 86]]
dev:9452024-07-04 12:56:46.574debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0B04 01 01 0040 00 2DBE 00 00 0000 01 01 0B0586050586080586
dev:9452024-07-04 12:56:46.424traceTuya Zigbee Metering Plug sendZigbeeCommands : [he raw 0x2DBE 1 0x01 0x0B04 {10 00 00 0B 05 05 05 08 05}, delay 200, he raw 0x2DBE 1 0x01 0x0702 {10 00 00 00 00}, delay 200, he rattr 0x2DBE 0x01 6 0 {}, delay 2000]
dev:9452024-07-04 12:56:46.378debugTuya Zigbee Metering Plug polling all 0x0B04 attributes
dev:9452024-07-04 12:56:46.376debugTuya Zigbee Metering Plug polling.. refreshAll is true
dev:9452024-07-04 12:56:46.369infoTuya Zigbee Metering Plug refresh()...
dev:9452024-07-04 12:56:45.662infoTuya Zigbee Metering Plug Energy (total:0.0 kWh) was reset on 2024-07-04 12:56:45.327
dev:9452024-07-04 12:56:45.600infoTuya Zigbee Metering Plug hourlyEnergy is 0 kWh
dev:9452024-07-04 12:56:45.594infoTuya Zigbee Metering Plug energy is 0.0 kWh (refresh), energyCost=$0.0 (rate=$0.21326), duration=0.0 Mins
dev:9452024-07-04 12:56:45.465debugTuya Zigbee Metering Plug energy_total=0, state.lastResetEnergy=0.0
dev:9452024-07-04 12:56:45.326debugresetEnergy() : state.lastEnergyRaw = 0.0
dev:9452024-07-04 12:56:44.299debugTuya Zigbee Metering Plug destinationEP = 01
dev:9452024-07-04 12:56:44.129debugTuya Zigbee Metering Plug state.lastResetEnergy = null, resetting it back to 0.0!
dev:9452024-07-04 12:56:44.127debugTuya Zigbee Metering Plug model = TS0601
dev:9452024-07-04 12:56:44.125debugTuya Zigbee Metering Plug preservedResetEnergy = 0.0
dev:9452024-07-04 12:56:44.124debugTuya Zigbee Metering Plug clearing states and preferences ...
dev:9452024-07-04 12:56:44.122infoTuya Zigbee Metering Plug InitializeVars()... fullInit = true
dev:9452024-07-04 12:56:44.094debugTuya Zigbee Metering Plug Initialize()...
dev:9452024-07-04 12:56:40.136infoTuya Zigbee Metering Plug Not Found (0x8b) Read Reporting Configuration Response for cluster:0006 attribute:0000, data=[86, 00, 00, 00] (Status: Failure)
dev:9452024-07-04 12:56:40.132debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 2DBE 00 00 0000 09 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:09, direction:01, data:[86, 00, 00, 00]]
dev:9452024-07-04 12:56:40.127debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0006 01 01 0040 00 2DBE 00 00 0000 09 01 86000000
dev:9452024-07-04 12:56:39.854infoTuya Zigbee Metering Plug Received Configure Reporting Response for cluster:0006 , data=[86, 00, 00, 00] (Status: Failure)
dev:9452024-07-04 12:56:39.850debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0006 01 01 0040 00 2DBE 00 00 0000 07 01 86000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 00, 00]]
dev:9452024-07-04 12:56:39.845debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0006 01 01 0040 00 2DBE 00 00 0000 07 01 86000000
dev:9452024-07-04 12:56:39.702infoTuya Zigbee Metering Plug Received bind response, data=[CA, 00] (Sequence Number:CA, Status: Success)
dev:9452024-07-04 12:56:39.694debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0000 8021 00 00 0040 00 2DBE 00 00 0000 00 00 CA00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[CA, 00]]
dev:9452024-07-04 12:56:39.690debugTuya Zigbee Metering Plug parse: description is catchall: 0000 8021 00 00 0040 00 2DBE 00 00 0000 00 00 CA00
dev:9452024-07-04 12:56:39.680infoTuya Zigbee Metering Plug Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:9452024-07-04 12:56:39.672debugTuya Zigbee Metering Plug parse: Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 2DBE 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:9452024-07-04 12:56:39.667debugTuya Zigbee Metering Plug parse: description is catchall: 0104 0000 01 01 0040 00 2DBE 00 00 0000 04 01 00
dev:9452024-07-04 12:56:39.654debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0005 value=TS0601 status=null data=null
dev:9452024-07-04 12:56:39.650debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0001 value=44 status=null data=null
dev:9452024-07-04 12:56:39.646debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0000 value=03 status=null data=null
dev:9452024-07-04 12:56:39.642debugTuya Zigbee Metering Plug attribute report: cluster=0000 attrId=0004 value=_TZE200_qhlxve78 status=null data=null
dev:9452024-07-04 12:56:39.631debugTuya Zigbee Metering Plug parse: Desc Map: [raw:2DBE01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni:2DBE, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_qhlxve78, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:9452024-07-04 12:56:39.467warnTuya Zigbee Metering Plug parse: exception caught while trying to getEvent... description: read attr - raw: 2DBE01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 2DBE, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9452024-07-04 12:56:39.370debugTuya Zigbee Metering Plug parse: description is read attr - raw: 2DBE01000068040042105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000, dni: 2DBE, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F71686C78766537380000002003010000204405000042065453303630310700003001FEFF003000
dev:9452024-07-04 12:56:39.221traceTuya Zigbee Metering Plug sendZigbeeCommands : [he raw 0x2DBE 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x2DBE 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, zdo bind 0x2DBE 0x01 0x01 0x0006 {B43522FFFE75D4DE} {}, delay 251, he cr 0x2DBE 0x01 6 0 16 0 900 {}, delay 251, he raw 0x2DBE 1 0x01 0x0006 {10 00 08 00 0000}, delay 251]
dev:9452024-07-04 12:56:39.216infoTuya Zigbee Metering Plug Automatic reporting configuration is disabled and will be skipped!
dev:9452024-07-04 12:56:39.211debugTuya Zigbee Metering Plug configureReporting operation=Write, measurement=Switch, minTime=0, maxTime=900, delta=0 )
dev:9452024-07-04 12:56:39.164debugTuya Zigbee Metering Plug ep=01 isF2=false
dev:9452024-07-04 12:56:39.113infoTuya Zigbee Metering Plug configure()..
dev:9452024-07-04 12:56:38.884infoTuya Zigbee Metering Plug Installed()...
Top half of the log:
Summary
dev:9452024-07-04 12:58:01.777infoHVAC Fan power is 9.4 W
dev:9452024-07-04 12:58:01.775debugHVAC Fan (104) SPM01 power : 9.4 raw (94)
dev:9452024-07-04 12:58:01.770debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 006D680200040000005E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 6D, 68, 02, 00, 04, 00, 00, 00, 5E]]
dev:9452024-07-04 12:58:01.766debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 006D680200040000005E
dev:9452024-07-04 12:58:01.712infoHVAC Fan amperage is 1.297 A
dev:9452024-07-04 12:58:01.709debugHVAC Fan (103) Amperage HOCH : 1.297 A (raw 1297)
dev:9452024-07-04 12:58:01.705debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 006C6702000400000511, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 6C, 67, 02, 00, 04, 00, 00, 05, 11]]
dev:9452024-07-04 12:58:01.700debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 006C6702000400000511
dev:9452024-07-04 12:58:01.644infoHVAC Fan voltage is 122 V
dev:9452024-07-04 12:58:01.641debugHVAC Fan (102) SPM01 voltage : 122.2 raw (1222)
dev:9452024-07-04 12:58:01.637debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 006B66020004000004C6, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 6B, 66, 02, 00, 04, 00, 00, 04, C6]]
dev:9452024-07-04 12:58:01.633debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 006B66020004000004C6
dev:9452024-07-04 12:58:01.607debugHVAC Fan ignored frequencyEvent (59.95) - reportFrequency is disabled
dev:9452024-07-04 12:58:01.606debugHVAC Fan (101) SPM01 frequency : 5995 raw (59.95) Hz
dev:9452024-07-04 12:58:01.602debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 006A650200040000176B, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 6A, 65, 02, 00, 04, 00, 00, 17, 6B]]
dev:9452024-07-04 12:58:01.597debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 006A650200040000176B
dev:9452024-07-04 12:58:01.569debugHVAC Fan ignored powerFactorEvent (0.59) - reportPowerFactor is disabled
dev:9452024-07-04 12:58:01.567debugHVAC Fan (110) SPM01 power_factor : 0.59 raw (59)
dev:9452024-07-04 12:58:01.563debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00690F0200040000003B, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 69, 0F, 02, 00, 04, 00, 00, 00, 3B]]
dev:9452024-07-04 12:58:01.559debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00690F0200040000003B
dev:9452024-07-04 12:58:01.549debugHVAC Fan ignored power 41984 W (exceeds maximum power cap 15000 W)
dev:9452024-07-04 12:58:01.547debugHVAC Fan SPM01 Active. Power : 41984 W (raw 419840)
dev:9452024-07-04 12:58:01.545debugHVAC Fan SPM01 Current : 524.288 A (raw 524288)
dev:9452024-07-04 12:58:01.509infoHVAC Fan voltage is 5069 V
dev:9452024-07-04 12:58:01.506debugHVAC Fan SPM01 Voltage : 5069.2 V (raw 50692)
dev:9452024-07-04 12:58:01.504debugHVAC Fan SPM01 combined reporting data: [00, 68, 06, 00, 00, 08, 04, C6, 00, 05, 11, 00, 00, 5E]
dev:9452024-07-04 12:58:01.500debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00680600000804C600051100005E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 68, 06, 00, 00, 08, 04, C6, 00, 05, 11, 00, 00, 5E]]
dev:9452024-07-04 12:58:01.495debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00680600000804C600051100005E
dev:9452024-07-04 12:58:01.430debugHVAC Fan (02) Reverse Energy : 0 raw
dev:9452024-07-04 12:58:01.426debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00670202000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 67, 02, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:58:01.422debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00670202000400000000
dev:9452024-07-04 12:58:01.400debugHVAC Fan HVAC Fan energy is 5.15 kWh (no change)
dev:9452024-07-04 12:58:01.398debugHVAC Fan energy_total=5.15, state.lastResetEnergy=0.0
dev:9452024-07-04 12:58:01.396debugHVAC Fan (01) Forward/Real Energy : 515 raw
dev:9452024-07-04 12:58:01.392debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00660102000400000203, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 66, 01, 02, 00, 04, 00, 00, 02, 03]]
dev:9452024-07-04 12:58:01.387debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00660102000400000203
dev:9452024-07-04 12:57:56.780infoHVAC Fan power is 2.6 W
dev:9452024-07-04 12:57:56.777debugHVAC Fan (104) SPM01 power : 2.6 raw (26)
dev:9452024-07-04 12:57:56.773debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0064680200040000001A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 64, 68, 02, 00, 04, 00, 00, 00, 1A]]
dev:9452024-07-04 12:57:56.768debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0064680200040000001A
dev:9452024-07-04 12:57:56.712infoHVAC Fan amperage is 0.35 A
dev:9452024-07-04 12:57:56.710debugHVAC Fan (103) Amperage HOCH : 0.35 A (raw 350)
dev:9452024-07-04 12:57:56.706debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0063670200040000015E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 63, 67, 02, 00, 04, 00, 00, 01, 5E]]
dev:9452024-07-04 12:57:56.702debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0063670200040000015E
dev:9452024-07-04 12:57:56.648infoHVAC Fan voltage is 122 V
dev:9452024-07-04 12:57:56.646debugHVAC Fan (102) SPM01 voltage : 122.3 raw (1223)
dev:9452024-07-04 12:57:56.641debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 006266020004000004C7, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 62, 66, 02, 00, 04, 00, 00, 04, C7]]
dev:9452024-07-04 12:57:56.637debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 006266020004000004C7
dev:9452024-07-04 12:57:56.605debugHVAC Fan ignored frequencyEvent (59.98) - reportFrequency is disabled
dev:9452024-07-04 12:57:56.603debugHVAC Fan (101) SPM01 frequency : 5998 raw (59.98) Hz
dev:9452024-07-04 12:57:56.599debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0061650200040000176E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 61, 65, 02, 00, 04, 00, 00, 17, 6E]]
dev:9452024-07-04 12:57:56.595debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0061650200040000176E
dev:9452024-07-04 12:57:56.587debugHVAC Fan ignored powerFactorEvent (0.6) - reportPowerFactor is disabled
dev:9452024-07-04 12:57:56.585debugHVAC Fan (110) SPM01 power_factor : 0.6 raw (60)
dev:9452024-07-04 12:57:56.578debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00600F0200040000003C, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 60, 0F, 02, 00, 04, 00, 00, 00, 3C]]
dev:9452024-07-04 12:57:56.522debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00600F0200040000003C
dev:9452024-07-04 12:57:56.513debugHVAC Fan ignored power 41753.6 W (exceeds maximum power cap 15000 W)
dev:9452024-07-04 12:57:56.511debugHVAC Fan SPM01 Active. Power : 41753.6 W (raw 417536)
dev:9452024-07-04 12:57:56.509debugHVAC Fan SPM01 Current : 524.288 A (raw 524288)
dev:9452024-07-04 12:57:56.467infoHVAC Fan voltage is 5094 V
dev:9452024-07-04 12:57:56.464debugHVAC Fan SPM01 Voltage : 5094.8 V (raw 50948)
dev:9452024-07-04 12:57:56.462debugHVAC Fan SPM01 combined reporting data: [00, 5F, 06, 00, 00, 08, 04, C7, 00, 02, 85, 00, 00, 1A]
dev:9452024-07-04 12:57:56.458debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005F0600000804C700028500001A, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 5F, 06, 00, 00, 08, 04, C7, 00, 02, 85, 00, 00, 1A]]
dev:9452024-07-04 12:57:56.454debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005F0600000804C700028500001A
dev:9452024-07-04 12:57:56.413debugHVAC Fan (02) Reverse Energy : 0 raw
dev:9452024-07-04 12:57:56.409debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005E0202000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 5E, 02, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:56.405debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005E0202000400000000
dev:9452024-07-04 12:57:56.371debugHVAC Fan HVAC Fan energy is 5.15 kWh (no change)
dev:9452024-07-04 12:57:56.369debugHVAC Fan energy_total=5.15, state.lastResetEnergy=0.0
dev:9452024-07-04 12:57:56.365debugHVAC Fan (01) Forward/Real Energy : 515 raw
dev:9452024-07-04 12:57:56.361debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005D0102000400000203, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 5D, 01, 02, 00, 04, 00, 00, 02, 03]]
dev:9452024-07-04 12:57:56.357debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005D0102000400000203
dev:9452024-07-04 12:57:51.881debugHVAC Fan ignored power 0 W (change from 0.0 is less than 1 W)
dev:9452024-07-04 12:57:51.879debugHVAC Fan (104) SPM01 power : 0 raw (0)
dev:9452024-07-04 12:57:51.875debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005B6802000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 5B, 68, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:51.871debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005B6802000400000000
dev:9452024-07-04 12:57:51.791debugHVAC Fan ignored amperage 0.0 A (change from 0.0 is less than 25 mA)
dev:9452024-07-04 12:57:51.788debugHVAC Fan (103) Amperage HOCH : 0.0 A (raw 0)
dev:9452024-07-04 12:57:51.784debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005A6702000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 5A, 67, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:51.780debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005A6702000400000000
dev:9452024-07-04 12:57:51.704infoHVAC Fan voltage is 122 V
dev:9452024-07-04 12:57:51.701debugHVAC Fan (102) SPM01 voltage : 122.5 raw (1225)
dev:9452024-07-04 12:57:51.697debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005966020004000004C9, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 59, 66, 02, 00, 04, 00, 00, 04, C9]]
dev:9452024-07-04 12:57:51.693debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005966020004000004C9
dev:9452024-07-04 12:57:51.616debugHVAC Fan ignored frequencyEvent (59.98) - reportFrequency is disabled
dev:9452024-07-04 12:57:51.615debugHVAC Fan (101) SPM01 frequency : 5998 raw (59.98) Hz
dev:9452024-07-04 12:57:51.610debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0058650200040000176E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 58, 65, 02, 00, 04, 00, 00, 17, 6E]]
dev:9452024-07-04 12:57:51.606debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0058650200040000176E
dev:9452024-07-04 12:57:51.518debugHVAC Fan ignored powerFactorEvent (1) - reportPowerFactor is disabled
dev:9452024-07-04 12:57:51.516debugHVAC Fan (110) SPM01 power_factor : 1 raw (100)
dev:9452024-07-04 12:57:51.512debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00570F02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 57, 0F, 02, 00, 04, 00, 00, 00, 64]]
dev:9452024-07-04 12:57:51.508debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00570F02000400000064
dev:9452024-07-04 12:57:51.478debugHVAC Fan ignored power 41523.2 W (exceeds maximum power cap 15000 W)
dev:9452024-07-04 12:57:51.475debugHVAC Fan SPM01 Active. Power : 41523.2 W (raw 415232)
dev:9452024-07-04 12:57:51.473debugHVAC Fan SPM01 Current : 524.288 A (raw 524288)
dev:9452024-07-04 12:57:51.436infoHVAC Fan voltage is 5146 V
dev:9452024-07-04 12:57:51.433debugHVAC Fan SPM01 Voltage : 5146 V (raw 51460)
dev:9452024-07-04 12:57:51.431debugHVAC Fan SPM01 combined reporting data: [00, 56, 06, 00, 00, 08, 04, C9, 00, 00, 00, 00, 00, 00]
dev:9452024-07-04 12:57:51.427debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00560600000804C9000000000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 56, 06, 00, 00, 08, 04, C9, 00, 00, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:51.422debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00560600000804C9000000000000
dev:9452024-07-04 12:57:51.398debugHVAC Fan (02) Reverse Energy : 0 raw
dev:9452024-07-04 12:57:51.338debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00550202000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 55, 02, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:51.334debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00550202000400000000
dev:9452024-07-04 12:57:51.261debugHVAC Fan HVAC Fan energy is 5.15 kWh (no change)
dev:9452024-07-04 12:57:51.258debugHVAC Fan energy_total=5.15, state.lastResetEnergy=0.0
dev:9452024-07-04 12:57:51.256debugHVAC Fan (01) Forward/Real Energy : 515 raw
dev:9452024-07-04 12:57:51.252debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00540102000400000203, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 54, 01, 02, 00, 04, 00, 00, 02, 03]]
dev:9452024-07-04 12:57:51.248debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00540102000400000203
dev:9452024-07-04 12:57:46.812debugHVAC Fan ignored power 0 W (change from 0.0 is less than 1 W)
dev:9452024-07-04 12:57:46.810debugHVAC Fan (104) SPM01 power : 0 raw (0)
dev:9452024-07-04 12:57:46.806debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00526802000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 52, 68, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:46.802debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00526802000400000000
dev:9452024-07-04 12:57:46.773debugHVAC Fan ignored amperage 0.0 A (change from 0.0 is less than 25 mA)
dev:9452024-07-04 12:57:46.771debugHVAC Fan (103) Amperage HOCH : 0.0 A (raw 0)
dev:9452024-07-04 12:57:46.696debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00516702000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 51, 67, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:46.691debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00516702000400000000
dev:9452024-07-04 12:57:46.614infoHVAC Fan voltage is 122 V
dev:9452024-07-04 12:57:46.611debugHVAC Fan (102) SPM01 voltage : 122.5 raw (1225)
dev:9452024-07-04 12:57:46.607debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005066020004000004C9, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 50, 66, 02, 00, 04, 00, 00, 04, C9]]
dev:9452024-07-04 12:57:46.603debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 005066020004000004C9
dev:9452024-07-04 12:57:46.527debugHVAC Fan ignored frequencyEvent (59.98) - reportFrequency is disabled
dev:9452024-07-04 12:57:46.525debugHVAC Fan (101) SPM01 frequency : 5998 raw (59.98) Hz
dev:9452024-07-04 12:57:46.521debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004F650200040000176E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 4F, 65, 02, 00, 04, 00, 00, 17, 6E]]
dev:9452024-07-04 12:57:46.517debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004F650200040000176E
dev:9452024-07-04 12:57:46.435debugHVAC Fan ignored powerFactorEvent (1) - reportPowerFactor is disabled
dev:9452024-07-04 12:57:46.434debugHVAC Fan (110) SPM01 power_factor : 1 raw (100)
dev:9452024-07-04 12:57:46.429debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004E0F02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 4E, 0F, 02, 00, 04, 00, 00, 00, 64]]
dev:9452024-07-04 12:57:46.425debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004E0F02000400000064
dev:9452024-07-04 12:57:46.401debugHVAC Fan ignored power 41292.8 W (exceeds maximum power cap 15000 W)
dev:9452024-07-04 12:57:46.399debugHVAC Fan SPM01 Active. Power : 41292.8 W (raw 412928)
dev:9452024-07-04 12:57:46.397debugHVAC Fan SPM01 Current : 524.288 A (raw 524288)
dev:9452024-07-04 12:57:46.350infoHVAC Fan voltage is 5146 V
dev:9452024-07-04 12:57:46.347debugHVAC Fan SPM01 Voltage : 5146 V (raw 51460)
dev:9452024-07-04 12:57:46.345debugHVAC Fan SPM01 combined reporting data: [00, 4D, 06, 00, 00, 08, 04, C9, 00, 00, 00, 00, 00, 00]
dev:9452024-07-04 12:57:46.340debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004D0600000804C9000000000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 4D, 06, 00, 00, 08, 04, C9, 00, 00, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:46.336debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004D0600000804C9000000000000
dev:9452024-07-04 12:57:46.260debugHVAC Fan (02) Reverse Energy : 0 raw
dev:9452024-07-04 12:57:46.256debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004C0202000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 4C, 02, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:46.252debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004C0202000400000000
dev:9452024-07-04 12:57:46.180debugHVAC Fan HVAC Fan energy is 5.15 kWh (no change)
dev:9452024-07-04 12:57:46.178debugHVAC Fan energy_total=5.15, state.lastResetEnergy=0.0
dev:9452024-07-04 12:57:46.175debugHVAC Fan (01) Forward/Real Energy : 515 raw
dev:9452024-07-04 12:57:46.171debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004B0102000400000203, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 4B, 01, 02, 00, 04, 00, 00, 02, 03]]
dev:9452024-07-04 12:57:46.166debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004B0102000400000203
dev:9452024-07-04 12:57:41.942debugHVAC Fan ignored power 0 W (change from 0.0 is less than 1 W)
dev:9452024-07-04 12:57:41.940debugHVAC Fan (104) SPM01 power : 0 raw (0)
dev:9452024-07-04 12:57:41.936debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00496802000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 49, 68, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:41.876debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00496802000400000000
dev:9452024-07-04 12:57:41.791debugHVAC Fan ignored amperage 0.0 A (change from 0.0 is less than 25 mA)
dev:9452024-07-04 12:57:41.789debugHVAC Fan (103) Amperage HOCH : 0.0 A (raw 0)
dev:9452024-07-04 12:57:41.785debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00486702000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 48, 67, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:41.781debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00486702000400000000
dev:9452024-07-04 12:57:41.706infoHVAC Fan voltage is 122 V
dev:9452024-07-04 12:57:41.703debugHVAC Fan (102) SPM01 voltage : 122.4 raw (1224)
dev:9452024-07-04 12:57:41.699debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004766020004000004C8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 47, 66, 02, 00, 04, 00, 00, 04, C8]]
dev:9452024-07-04 12:57:41.695debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 004766020004000004C8
dev:9452024-07-04 12:57:41.595debugHVAC Fan ignored frequencyEvent (59.98) - reportFrequency is disabled
dev:9452024-07-04 12:57:41.593debugHVAC Fan (101) SPM01 frequency : 5998 raw (59.98) Hz
dev:9452024-07-04 12:57:41.589debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0046650200040000176E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 46, 65, 02, 00, 04, 00, 00, 17, 6E]]
dev:9452024-07-04 12:57:41.584debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0046650200040000176E
dev:9452024-07-04 12:57:41.489debugHVAC Fan ignored powerFactorEvent (1) - reportPowerFactor is disabled
dev:9452024-07-04 12:57:41.488debugHVAC Fan (110) SPM01 power_factor : 1 raw (100)
dev:9452024-07-04 12:57:41.484debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00450F02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 45, 0F, 02, 00, 04, 00, 00, 00, 64]]
dev:9452024-07-04 12:57:41.479debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00450F02000400000064
dev:9452024-07-04 12:57:41.447debugHVAC Fan ignored power 41062.4 W (exceeds maximum power cap 15000 W)
dev:9452024-07-04 12:57:41.444debugHVAC Fan SPM01 Active. Power : 41062.4 W (raw 410624)
dev:9452024-07-04 12:57:41.437debugHVAC Fan SPM01 Current : 524.288 A (raw 524288)
dev:9452024-07-04 12:57:41.399infoHVAC Fan voltage is 5120 V
dev:9452024-07-04 12:57:41.396debugHVAC Fan SPM01 Voltage : 5120.4 V (raw 51204)
dev:9452024-07-04 12:57:41.394debugHVAC Fan SPM01 combined reporting data: [00, 44, 06, 00, 00, 08, 04, C8, 00, 00, 00, 00, 00, 00]
dev:9452024-07-04 12:57:41.390debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00440600000804C8000000000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 44, 06, 00, 00, 08, 04, C8, 00, 00, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:41.385debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00440600000804C8000000000000
dev:9452024-07-04 12:57:41.374debugHVAC Fan (02) Reverse Energy : 0 raw
dev:9452024-07-04 12:57:41.234debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00430202000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 43, 02, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:41.202debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00430202000400000000
dev:9452024-07-04 12:57:41.084debugHVAC Fan HVAC Fan energy is 5.15 kWh (no change)
dev:9452024-07-04 12:57:41.082debugHVAC Fan energy_total=5.15, state.lastResetEnergy=0.0
dev:9452024-07-04 12:57:41.079debugHVAC Fan (01) Forward/Real Energy : 515 raw
dev:9452024-07-04 12:57:41.075debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00420102000400000203, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 42, 01, 02, 00, 04, 00, 00, 02, 03]]
dev:9452024-07-04 12:57:41.068debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00420102000400000203
dev:9452024-07-04 12:57:36.613debugHVAC Fan ignored power 0 W (change from 0.0 is less than 1 W)
dev:9452024-07-04 12:57:36.610debugHVAC Fan (104) SPM01 power : 0 raw (0)
dev:9452024-07-04 12:57:36.606debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00406802000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 40, 68, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:36.602debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00406802000400000000
dev:9452024-07-04 12:57:36.526debugHVAC Fan ignored amperage 0.0 A (change from 0.0 is less than 25 mA)
dev:9452024-07-04 12:57:36.523debugHVAC Fan (103) Amperage HOCH : 0.0 A (raw 0)
dev:9452024-07-04 12:57:36.519debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003F6702000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3F, 67, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:36.514debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003F6702000400000000
dev:9452024-07-04 12:57:36.438infoHVAC Fan voltage is 122 V
dev:9452024-07-04 12:57:36.435debugHVAC Fan (102) SPM01 voltage : 122.4 raw (1224)
dev:9452024-07-04 12:57:36.431debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003E66020004000004C8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3E, 66, 02, 00, 04, 00, 00, 04, C8]]
dev:9452024-07-04 12:57:36.427debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003E66020004000004C8
dev:9452024-07-04 12:57:36.352debugHVAC Fan ignored frequencyEvent (59.98) - reportFrequency is disabled
dev:9452024-07-04 12:57:36.350debugHVAC Fan (101) SPM01 frequency : 5998 raw (59.98) Hz
dev:9452024-07-04 12:57:36.346debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003D650200040000176E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3D, 65, 02, 00, 04, 00, 00, 17, 6E]]
dev:9452024-07-04 12:57:36.340debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003D650200040000176E
dev:9452024-07-04 12:57:36.263debugHVAC Fan ignored powerFactorEvent (1) - reportPowerFactor is disabled
dev:9452024-07-04 12:57:36.262debugHVAC Fan (110) SPM01 power_factor : 1 raw (100)
dev:9452024-07-04 12:57:36.258debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003C0F02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3C, 0F, 02, 00, 04, 00, 00, 00, 64]]
dev:9452024-07-04 12:57:36.253debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003C0F02000400000064
dev:9452024-07-04 12:57:36.221debugHVAC Fan ignored power 40832 W (exceeds maximum power cap 15000 W)
dev:9452024-07-04 12:57:36.219debugHVAC Fan SPM01 Active. Power : 40832 W (raw 408320)
dev:9452024-07-04 12:57:36.216debugHVAC Fan SPM01 Current : 524.288 A (raw 524288)
dev:9452024-07-04 12:57:36.174infoHVAC Fan voltage is 5120 V
dev:9452024-07-04 12:57:36.172debugHVAC Fan SPM01 Voltage : 5120.4 V (raw 51204)
dev:9452024-07-04 12:57:36.170debugHVAC Fan SPM01 combined reporting data: [00, 3B, 06, 00, 00, 08, 04, C8, 00, 00, 00, 00, 00, 00]
dev:9452024-07-04 12:57:36.165debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003B0600000804C8000000000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3B, 06, 00, 00, 08, 04, C8, 00, 00, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:36.161debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003B0600000804C8000000000000
dev:9452024-07-04 12:57:36.078debugHVAC Fan (02) Reverse Energy : 0 raw
dev:9452024-07-04 12:57:36.074debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003A0202000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 3A, 02, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:36.070debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003A0202000400000000
dev:9452024-07-04 12:57:35.994debugHVAC Fan HVAC Fan energy is 5.15 kWh (no change)
dev:9452024-07-04 12:57:35.992debugHVAC Fan energy_total=5.15, state.lastResetEnergy=0.0
dev:9452024-07-04 12:57:35.990debugHVAC Fan (01) Forward/Real Energy : 515 raw
dev:9452024-07-04 12:57:35.986debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00390102000400000203, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 39, 01, 02, 00, 04, 00, 00, 02, 03]]
dev:9452024-07-04 12:57:35.981debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00390102000400000203
dev:9452024-07-04 12:57:31.499debugHVAC Fan ignored power 0 W (change from 0.0 is less than 1 W)
dev:9452024-07-04 12:57:31.497debugHVAC Fan (104) SPM01 power : 0 raw (0)
dev:9452024-07-04 12:57:31.493debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00376802000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 37, 68, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:31.489debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00376802000400000000
dev:9452024-07-04 12:57:31.415debugHVAC Fan ignored amperage 0.0 A (change from 0.0 is less than 25 mA)
dev:9452024-07-04 12:57:31.412debugHVAC Fan (103) Amperage HOCH : 0.0 A (raw 0)
dev:9452024-07-04 12:57:31.408debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00366702000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 36, 67, 02, 00, 04, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:31.404debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00366702000400000000
dev:9452024-07-04 12:57:31.326infoHVAC Fan voltage is 122 V
dev:9452024-07-04 12:57:31.323debugHVAC Fan (102) SPM01 voltage : 122.4 raw (1224)
dev:9452024-07-04 12:57:31.319debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003566020004000004C8, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 35, 66, 02, 00, 04, 00, 00, 04, C8]]
dev:9452024-07-04 12:57:31.315debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 003566020004000004C8
dev:9452024-07-04 12:57:31.236debugHVAC Fan ignored frequencyEvent (59.98) - reportFrequency is disabled
dev:9452024-07-04 12:57:31.234debugHVAC Fan (101) SPM01 frequency : 5998 raw (59.98) Hz
dev:9452024-07-04 12:57:31.230debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0034650200040000176E, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 34, 65, 02, 00, 04, 00, 00, 17, 6E]]
dev:9452024-07-04 12:57:31.226debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 0034650200040000176E
dev:9452024-07-04 12:57:31.202debugHVAC Fan ignored powerFactorEvent (1) - reportPowerFactor is disabled
dev:9452024-07-04 12:57:31.200debugHVAC Fan (110) SPM01 power_factor : 1 raw (100)
dev:9452024-07-04 12:57:31.142debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00330F02000400000064, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 33, 0F, 02, 00, 04, 00, 00, 00, 64]]
dev:9452024-07-04 12:57:31.138debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00330F02000400000064
dev:9452024-07-04 12:57:31.114debugHVAC Fan ignored power 40601.6 W (exceeds maximum power cap 15000 W)
dev:9452024-07-04 12:57:31.112debugHVAC Fan SPM01 Active. Power : 40601.6 W (raw 406016)
dev:9452024-07-04 12:57:31.110debugHVAC Fan SPM01 Current : 524.288 A (raw 524288)
dev:9452024-07-04 12:57:31.066infoHVAC Fan voltage is 5120 V
dev:9452024-07-04 12:57:31.064debugHVAC Fan SPM01 Voltage : 5120.4 V (raw 51204)
dev:9452024-07-04 12:57:31.062debugHVAC Fan SPM01 combined reporting data: [00, 32, 06, 00, 00, 08, 04, C8, 00, 00, 00, 00, 00, 00]
dev:9452024-07-04 12:57:31.058debugHVAC Fan parse: Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00320600000804C8000000000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:2DBE, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 32, 06, 00, 00, 08, 04, C8, 00, 00, 00, 00, 00, 00]]
dev:9452024-07-04 12:57:31.053debugHVAC Fan parse: description is catchall: 0104 EF00 01 01 0040 00 2DBE 01 00 0000 01 01 00320600000804C8000000000000
That’s great, we are one more step closer!
