Looked here and online but can’t seem to find a good alternative to the Minimotes.
I have 3 that are 10 years old. I even have new internal batteries I bought that are unused and about that old; they are probably toast now.
I figured I might replace the ZW remotes with a power saving ZB ones with a replaceable batteries but there are no small, 4 button remotes like it, that I can find.
The layout and size are a bit different (though I actually prefer the shape -- standard decorator switch size, at least if you're in the US), but the Zooz ZEN37 is a four-button, USB-rechargeable Z-Wave remote. Unlike the Minimote, it's also not intended to be a Z-Wave controller, so they aren't quite as finicky to get included.
There's also the ZEN34, which looks more like an actual paddle switch. While it doesn't have the same number of buttons, keep in mind that all of these support multi-taps (plus hold and release), so you can get more out of one button than a single action.
Third Reality also has a few Zigbee remotes, but I'm not sure there are built-in drivers for anything currently in stock (just got one to play around with myself!), and they aren't really like any of the above.
I have tried numerous 4 gang Zigbee scene switches, and the one I like most is below. it has a good battery life, reports battery life, and has good tactile feedback on button presses.
That one and the 3 button version, my wife loves them, and that says alot.
We know with Tuya you’ll likely get a different firmware version, and hopefully the driver picks up the clusters correctly, assuming they are the same clusters
