Hello
I have two devices from Eurotronic company. This is an air quality sensor and a heat exchanger. TRV supports a mode in which the air temperature is provided by another device, and the air quality sensor can provide the temperature to other devices. It would be an ideal combination for controlling heating in a home. I've tested this idea with z-way-server and it works great. at the time of the implementation of this idea, there were no drivers for these devices yet. I wrote them. In order for the sensor to provide the temperature of the TRV, it is necessary to add the node-ID from the TRV to the association-group 2 from sensor. To do this, I wrote drivers for both the sensor and the trv. They work great. The node-ID is added to the association, only there is no information exchange between the devices. I repeat, everything works on Z-Way-Server. Hubitat doesn't work. The reason for the Hubitat?
Driver: GitHub - Aelfot/Aelfot
