Z Wave topology
Hi
I've read there must be cholons that are only red.
How do I fix the columns that are red? Aeotec z wave range extender 7 is installed in the housing to amplify the signal. But that doesn't seem to help :thinking:
Regarding aeotec z wave range extender 7, I don't seem to see it's active inside the device. I can only see I've connected it to the hub.
Looks like a quite unhappy mesh, did you have a lot of failed incusions?
Please share your Z-Wave details page with us.
Regarding Aeon Range Extender, my devices are also very picky using it, it mostly just idles around.
If these are sleepy (battery powered) devices, you may not be able to do anything here (and if the devices are working, there probably isn't any problem).
They are all battery units, with the exception of aeotec z wave range extender 7, and aeotec doorbell
Could that be why?
Just wanted to make sure that all devices have included well and that no ghost nodes are present.
If everything works fine, you may just follow @tony.fleisher's advice and simply relax.
But I would recommend to get some more mains-powered devices to create a stable mesh, also I think it would make your topology matrix look better.
What is the device with ID 0x0e? Just curious, as it shows a lot of route changes.
It's a thermostat from Fibaro. "Termostat Nulle".
Ah, I see, I have four of them and each has a place in the Top 5 list of route changes. :wink:
