Z-wave Topology does not update
C7
2.3.8.140
My information in Z-Wave Details and what is reflected in Topology and new Graph views are very different. I thought the views do not update very often and would eventually synchronize but this has been for months. The current graph view shows an impossible routes. For example everything is shown to connect through "Sparen Zlink" node, which is shown as a regular ( not a repeater) node, In ZVave Detail table Laundry Room is connected directly to the hub. "Main Valve" also is shown connected through two battery powered nodes, which again cannot be correct. I repaired and updated Z-wave several times over the course of few months and install updates regularly but the topology is never correct.
I think this known. I would not rely on it. Stick with the normal topology map
Normal Topology is wrong too. The only information that looks more correct is z-wave table with -> type routes.
