Good morning!
I'm looking into getting a Z-Wave Thermostat, but I could use some recommendattions. There are a lot out there. What works well with Hubitat?
Thanks!
Good morning!
Thanks!
Just installed the Honeywell T6 Z-Wave. Seems to be working great. Easy Install, paired with no issues.
I realize you are asking for Z-Wave, but in case Zigbee would work for you, I have recently changed all my baseboard heater thermostats to the Sinopé Zigbee and am very satisfied.
I have tested a handful of ZWave and Zigbee thermostats. The favorite was the Zen thermostat, which is Zigbee. Other family members like the simple, modern look of it on the wall. It doesn't have any scheduling features of its own, but if you are connecting to Hubitat, that is not an issue. Among ZWave thermostats, I have GoControl and CT-100 which are both ok. I don't have complaints about them, but don't find any reason to make a strong endorsement either. Don't take this as a knock against any that I haven't listed. I have seen many favorable reviews of Honeywell T6. If you go with T6, be aware that there are several versions of it, so make sure you get the ZWave version.
Thank you! I ordered the T6 as I'm pretty set on getting something Z-Wave and it has all the features I need.
I got This one used on ebay about a year ago for pretty cheap. It's not fancy, no touchscreen or fancy features. But it looks decent enough and has worked flawlessly for me. The battery is life seems good too, assuming the 92% it is reporting is at all accurate.
