So when you use RM to poll on some set interval, it only polls a single time? It is not adding the device to the Z-waving Polling app that will continue to poll that device at the default interval?
My example in previous post will poll every 5 minutes "to infiniti and beyond". If you create a rule like this, you should probably not also have Poller app running. When I had non-plus devices, I polled one set every five minutes using one rule another set every 10 minutes using a separate rule.
Why do you suggest not also running the polling app? I have moved 15 devices into a Rule at 5 minutes, but there are still 4 devices that I want polled at the default 10 seconds, so I left them in the polling app.
Memory says that poller app is restricted to switches/dimmers; i.e. devices that can be operated manually leading to a discrepancy between their state in Hubitat and actual state.
I donβt think a discrepancy of state can happen very easily with sensors like your smoke alarm.
