Z-Wave Pause / Disruption Every 30 minutes
I installed 2.3.8.139 and it still did not fix my issue. Here is how I tested it:
  1. Update to 2.3.8.139 - Hub reboots automatically as a resut
  2. Enable Z-Wave statistics again by hitting the /hub/zwaveStatsEnable endpoint
  3. Reboot hub to finish process of enabling Z-Wave statistics
  4. Check Z-Wave device(s) at the 30 minute mark.
After doing this, I still noted the disruption. I was able to eliminate the disruption again by disabling Z-Wave statistics by hitting the /hub/zwaveStatsDisable endpoint and rebooting the hub. Everything worked correctly again after this.
