Z-Wave Outlet with Power Monitoring
Does anyone know of a z-wave in-wall outlet that supports Power Monitoring? I've tried Google & Amazon and all I find are plug-in addons (like the Aeotec SmartSwitch 6, etc). I want something to replace the outlet itself (a combination of aesthetics and space issues).
Tim B
While power monitoring is matter to device handler in most of cases, I use 2 brand devices and I am happy with: Fibaro Smart Wall Plug (supported, with aesthetic RGB LED ) and Qubino 16A(not yet supported,my own device handler). Main use cases: Fibaro up to 2.5kW, Qubino up to 4kW (Qubino shows power meter, but also voltage and current). Hope it helps.
Unfortunately those 2 solutions do not fit my use case (a replacement for the Outlet, not an add-on). There are several Z-Wave outlets, but none of the ones I have found have the ability to do power monitoring.
Enerwave makes one:
aaiyar:
looks good, however all my searches turn up "currently unavailable, unknown when more will be available". Will make a note to check every couple of weeks or so.
